Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System MLDS Administration Guide |
Enable MLDS in a Specific VLAN
Configure the Multicast Forwarding Mode
Configure the Snooping Version
Configuring Multicast Router Ports
Configure a Static Multicast Router Port
Delete Configured Router Ports
Configure Dynamically Learned Multicast Router Port Time-Out
Restore the Port-Purge Interval
Configure an MLDS Switch as a Querier
Configuring the Port-Purge Interval
Configure the Port-Purge Interval
Configuring Fast-Leave Processing
Forward MLD Reports to All Ports
Forward MLD Reports Only to Router Ports
Restore the Default MLD Report-Forwarding Status
Configure the Report Forward Suppression Interval
Restore the Default Report Forward Suppression Interval
Configuring Group Query Interval
Restore the Default Query Interval
Configure Group Query Retry Count
Configuring Snooping Statistics
Enable Snooping Statistics for a Specific VLAN
Clear Snooping Statistics for a Specific VLAN
Clear Snooping Statistics for All VLANs
Configuring Query Transmission on Topology Change
Enable Query Transmission on Topology Change
The group query interval default value is 2 seconds. This example changes the interval to 3 seconds.
SEFOS# configure terminal SEFOS(config)# ipv6 mld snooping group-query-interval 3 SEFOS(config)# end
SEFOS# show ipv6 mld snooping globals Snooping Configuration ----------------------------- MLD Snooping globally enabled MLD Snooping is operationally enabled Multicast forwarding mode is MAC based Proxy reporting globally enabled Router port purge interval is 125 seconds Port purge interval is 130 seconds Report forward interval is 8 seconds Group specific query interval is 3 seconds Reports are forwarded on router ports Group specific query retry count is 2
