Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
MLDS Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
MLDS Protocol Description
Joining a Multicast Group
MLDS Topology Example
Configuration Guidelines
Default Configurations
Configuring MLDS
Enabling and Disabling MLDS
Enable MLDS Globally
Enable MLDS in a Specific VLAN
Disable MLDS
Configure the Multicast Forwarding Mode
Configure the Snooping Version
Configuring Multicast Router Ports
Configure a Static Multicast Router Port
Delete Configured Router Ports
Configure Dynamically Learned Multicast Router Port Time-Out
Restore the Port-Purge Interval
Configure an MLDS Switch as a Querier
Configure MLDS Query Interval
Configuring Proxy Reporting
Configure Proxy Reporting
Disable Proxy Reporting
Configuring the Port-Purge Interval
Configure the Port-Purge Interval
Configuring Fast-Leave Processing
Enable Fast-Leave Processing
Disable Fast-Leave Processing
Configuring Report Forwarding
Forward MLD Reports to All Ports
Forward MLD Reports Only to Router Ports
Restore the Default MLD Report-Forwarding Status
Configure the Report Forward Suppression Interval
Restore the Default Report Forward Suppression Interval
Configuring Group Query Interval
Configure the Group Query Interval
Restore the Default Query Interval
Configure Group Query Retry Count
Configuring Snooping Statistics
Enable Snooping Statistics for a Specific VLAN
Clear Snooping Statistics for a Specific VLAN
Clear Snooping Statistics for All VLANs
Configuring Query Transmission on Topology Change
Enable Query Transmission on Topology Change
Disable Query Transmission on Topology Change
Display MLD Statistics
This example clears statistics for VLAN 1.
  1. Clear statistics for a specific VLAN.
    SEFOS# configure terminal
    SEFOS(config)# ipv6 mld snooping clear counters vlan 1
  2. Verify that snooping statistics have been cleared for VLAN 1.
    SEFOS# show ipv6 mld snooping statistics vlan 1
      Snooping Statistics for VLAN 1
      General queries received: 0
      Group specific queries received: 0
      Group and source specific queries received: 0
      ASM reports received: 0
      SSM reports received: 0
      IS_INCLUDE messages received: 0
      IS_EXCLUDE messages received: 0
      TO_INCLUDE messages received: 0
      TO_EXCLUDE messages received: 0
      ALLOW messages received: 0
      Block messages received: 0
      Leave messages received: 0
      General queries transmitted: 0
      Group specific queries transmitted: 0
      ASM reports transmitted: 0
      SSM reports transmitted: 0
      Leaves transmitted: 0
      Packets dropped: 0
