Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
OSPFv3 Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
OSPFv3 Overview
Protocol Description
OSPFv3 Topologies
Configuration and Testing Topologies
IPv6 Example Topology Interface and Host Addresses
OSPFv3 Configurations
Default Configuration Values
SNMP MIB Files
Creating the Base Configuration
Access Global Configuration Mode
Access Interface Configuration Mode
Enabling IPv6 Support and Assigning IPv6 Addresses
Enable IPv6
Disable IPv6
Delete an IPv6 Address
Configuring IPv6 Static Routes
Configure Static Routes
Delete a Static Route
Creating the Base Configuration for Example Topologies
Configure SEFOS1
Configure SEFOS2
Configure SEFOS3
Configure SEFOS4
Configure SEFOS5
Configure SEFOS6
Configure SEFOS7
Configure SEFOS8
Configure SEFOS9
Configuring OSPFv3 Features
OSPFv3 Features
Configuring Basic OSPFv3
Enable OSPFv3
Disable OSPFv3
Creating an OSPFv3 Interface
Configure an OSPFv3 Interface
Configuring Neighbors
Configure an OSPFv3 Neighbor
Configuring OSPFv3 Interface Parameters
Configure Interface Priority
Restore the Default Interface Priority
Configure the Retransmission Interval
Restore the Default Retransmission Value
Configure Transmission Delay
Restore the Default Transmission Delay
Configure the Hello Interval
Restore the Default Hello Interval
Configure the Dead Interval
Restore the Default Dead Interval
Configure the Network Type
Restore the Default OSPF Network Type
Configure the Interface Cost
Restore the Default Interface Cost
Configuring a Demand Circuit
Enable a Demand Circuit
Remove the Demand Circuit Setting
Enable Neighbor Probing on a Demand Circuit
Remove Neighbor Probing on a Demand Circuit
Configuring Neighbor Probe Values
Configure the Neighbor Probe Retransmission Limit
Restore the Default Neighbor Probe Retransmission Limit
Configure the Neighbor Probe Interval
Restore the Default Neighbor Probe Interval
Configuring a Passive Interface
Configure All Interfaces To Be Passive
Configure Specified Interfaces To Be Passive
Restore the Default Routing Updates
Configuring Route Redistribution
Configure an ASBR Router
Disable the ASBR Router
Configure Route Redistribution
Disable Route Redistribution
Configure the Stub Area, ASBR, and Route Distribution
Configuring Attributes for Redistributed Routes
Configure Redistributed Route Attributes
Delete Redistributed Route Attributes
Configuring the Redistribution of Routes
Restore the Default Redistribution Configuration
Configuring Area Route Summarization
Area Route Overview
Configure Address Range Aggregation
Disable an Address Range
Configure an Internal Address Range
Disable an Internal Address Range
Configuring a Stub Area
Configure a Stub Area
Convert a Stub Area to a Normal Area
Configure a Default Summary Route for a Stub Area
Configure the Default Summary Route Cost for a Stub Area
Configuring an NSSA
Configure the Stability Interval for NSSA
Restore the Default Stability Interval
Configure an NSSA Translation Role
Restore the Default Translation Role
Configure Default Summary Route for an NSSA
Configure the Metric Type for an NSSA
Configuring the Capability in an NSSA Internal Border Router
Configure NSSA Type-7/-5 Conversion
Configuring Virtual Links
Configure a Virtual Link
Delete a Virtual Link
Configure Virtual Link and Route Summarization
Configuring External Database Limit
Configure the External Database Limit
Restore the Default External Database Limit
Configuring the Overflow Exit Interval
Configure the Overflow Exit Interval
Configuring a Demand Extension
Disable a Demand Extension
Re-Enable Demand Extensions
Configuring the Host
Configure the Host
Test the Host
Configuring Route Calculation SPF Timers
Configure SPF Timers
Restore the Default Delay Time
See NSSA Type-7/-5 Conversion Topology for the NSSA Type-7/-5 conversion topology created in this example.
  1. Configure the interfaces with their corresponding IPv6 address.
    See IPv6 Example Topology Interface and Host Addresses.
  2. Configure OSPFv3 by enabling OSPFv3 routing protocol in VLAN 2 (area 0.0.0.2) on SEFOS9 (router ID 10.0.0.9).
    SEFOS(config)# ipv6 router ospf
    SEFOS(config-router)# router-id  10.0.0.9
    SEFOS(config-router)# ASBR Router
    SEFOS(config-router)# redistribute static
    SEFOS(config-router)# exit
    SEFOS(config)# interface vlan 2
    SEFOS(config-if)# ipv6 ospf area 0.0.0.2
    SEFOS(config-if)# exit
  3. Configure the area as an NSSA.
    SEFOS(config-router)# area 0.0.0.2 nssa
    SEFOS(config-router)# end
  4. Enable OSPFv3 routing protocol in VLAN 2 (area 0.0.0.2) on SEFOS2 (router ID 10.0.0.2).
    SEFOS(config-router)# router-id  10.0.0.2
    SEFOS(config)# interface vlan 11
    SEFOS(config-if)# ipv6 ospf area 0.0.0.0
  5. Configure area 0.0.0.2 as an NSSA.
  6. Enable OSPFv3 routing protocol on VLAN 11 (area 0.0.0.0) on SEFOS1 (router ID 10.0.0.1).
    SEFOS(config-router)# router-id  10.0.0.1
  7. Configure the static route.
    Add a static route to 4444::/96 through VLAN 1, where the IPv6 address for VLAN 1 on SEFOS9 is 3333::2222:0:1/96, with a next hop of 3333::2222:0:10/96.
    SEFOS(config)# ipv6 route 4444:: 96 3333::2222:0:10
    SEFOS(config)# exit
  8. View the Type-7 and Type-5 LSA. By default the P-bit will be in clear state. Type-7 LSAs will be converted into a Type-5 LSA.
    • In SEFOS9, type.
      SEFOS# show ipv6 ospf database nssa detail
      Age: 42  Seconds            LS Type: Type-7 Lsa
      Link State Id: 0.0.0.0      Adv Rtr Id: 10.0.0.2
      Sequence: 0x80000002        Checksum: 0x0d20    Length: 28
      Metric: 0x1
      Metric Type: Ext Type1      Prefix Length: 0             Prefix Options: 0x00
      Referenced LS Type: 0
      Address Prefix: ::10:10f8:5830:300:e450
      Fw Address Prefix: 3ddf:c7e8:3ddf:c738:ff4:324:3d50:10
      External Route Tag: 0
      Age: 0   Seconds            LS Type: Type-7 Lsa
      Link State Id: 0.0.0.1      Adv Rtr Id: 10.0.0.9
      Sequence: 0x80000001        Checksum: 0xe6e5    Length: 56
      Metric: 0xa
      Metric Type: Ext Type2      Prefix Length: 96            Prefix Options: 0x08
      Address Prefix: 4444::300:e450
    • In SEFOS2, type.
      Metric: 0x1
      Address Prefix: ::10:10f8:5920:300:2450
      Fw Address Prefix: 3621:828:3621:778:ff4:324:fe4:2988
      Age: 3   Seconds            LS Type: Type-7 Lsa
      Metric: 0xa
      Address Prefix: 4444::300:2450
    • In SEFOS1, type.
      SEFOS# show ipv6 ospf database as-external detail
      Age: 3   Seconds            LS Type: External Lsa
      Link State Id: 0.0.0.1      Adv Rtr Id: 10.0.0.2
      Sequence: 0x80000001        Checksum: 0x0bb2    Length: 56
      Metric Type: Ext Type2      Metric: 0xa
      Prefix Length: 96            Prefix Options: 0x00
      Addres Prefix: 4444::
      Fw Addres Prefix: 4444::fec0:0
  9. In SEFOS9, set the P-bit in the default Type-7 LSA generated by an NSSA internal ASBR.
    SEFOS(config-router)# no nssaAsbrDfRtTrans
  10. Configure aggregation, if necessary.
    SEFOS(config-router)# area 0.0.0.0 summary-prefix 4444::64 translation disabled
  11. View the results in SEFOS1.
    Note - No external LSA is sent to 10.0.0.1.
