Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
SLB Administration Guide
PDF
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
SLB Overview
Configuring the SLB Topology Example
SLB Description
SLB Configuration Guidelines and Prerequisites
Default Settings
Configuring the SLB-L2 Topology Example
SLB-L2 Description
SLB-L2 Configuration Guidelines and Prerequisites
Default Settings
Conditions for a Member Participating in Load Distribution
Configuring SLB Entries
Create SLB Server Members
Remove SLB Server Members
Set the Traffic Distribution Policy
Restore the Default Traffic Distribution Policy
Create Multiple LBGs
Set the ICMP Parameters
Set the Health-Monitor Parameters
Server Health-Check Function
Configuring SLB-L2 Entries
Create SLB-L2 Server Members
Remove SLB-L2 Port Members
View the Traffic Distribution Policy
Set the Failover Method
Restore the Default Failover Method
Create Multiple SLB-L2 Groups
Creating Example SLB Configurations
Creating a Basic SLB Configuration
Basic SLB Configuration Steps
Set Up the Switch (Basic SLB)
Set Up the Client (Basic SLB)
Set Up the Server (Basic SLB)
Enable the Switch Ports (Basic SLB)
Save the Current Configuration (Basic SLB)
Creating a Separate VLAN SLB Configuration
Configuration With Separate VLANs Steps
Set Up the Switch (Separate VLAN SLB)
Set Up the Client (Separate VLAN SLB)
Set Up the Server (Separate VLAN SLB)
Enable the Switch Ports (Separate VLAN SLB)
Save the Current Configuration (Separate VLAN SLB)
Creating a Multiple SLB Group Configuration
Multiple-SLB-Group Configuration
Configuration With Multiple SLB Groups Steps
Set Up Switch A
Set Up Switch B
Set Up the Client (Multiple SLB Group)
Set Up the Servers in SLB Group 1
Set Up the Servers in SLB Group 2
Enable the Switch Ports (Multiple SLB Group)
Save the Current Configuration (Multiple SLB Group)
Creating a Failover Example
Failover Example
Trigger a Failover
Restart the Server Following Failure
Creating SLB-L2 Configuration Examples
Bump-In-The-Wire Configuration
Creating a Single-Switch Configuration
Basic Single-Switch Configuration
Create a Single-Switch Configuration
Creating a Dual-Switch Configuration
Create a Dual-Switch Configuration
Creating an SLB-L2 Failover Example
Trigger a Failover
Restart the Interface Following Failure
Feedback
Provide feedback on this documentation at:
http://www.oracle.com/goto/docfeedback
