Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
ONET Configuration
ONET Example Topology
Default Settings
ONET and Oracle ILOM
Start ONET From Oracle ILOM
Start the ONET CLI
Stopping SEFOS Before Starting ONET
Stop SEFOS
Start ONET
Stop ONET
Configuring an ONET
Configure an ONET
Common Configuration Errors
ONET CLI Commands
help Command
show onet Command
show onets Command
show interfaces description Command
show vlan Command
show lldp Command
show mac-address-table Command
speed port Command
exit Command
write startup-config Command
no onet Command
onet Command
set onet Command
-> stop /NEM/sefos stop: Unsaved SEFOS configuration will be lost Are you sure you want to stop /NEM/sefos (y/n)? y stop: SEFOS stopped successfully.
