Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System RIPng Administration Guide |
Configuring the RIPng Topology Example
Enable and Configure RIPng on Desired IPv6 Interfaces
Disable the split-horizon Option
Use the following commands to configure VLAN 50, VLAN 40, and VLAN 30 on switch SEFOS1 in the example topology.
SEFOS 1 SEFOS# configure terminal SEFOS 1 SEFOS(config)# set gvrp disable SEFOS 1 SEFOS(config)# set gmrp disable SEFOS 1 SEFOS(config)# interface extreme-ethernet 0/15 SEFOS 1 SEFOS(config-if)# switchport access vlan 50 % Access VLAN does not exist.,Creating vlan SEFOS 1 SEFOS(config-if)# exit SEFOS 1 SEFOS(config)# interface vlan 50 SEFOS 1 SEFOS(config-if)# no shutdown SEFOS 1 SEFOS(config-if)# ipv6 enable SEFOS 1 SEFOS(config-if)# ipv6 address 5555::14 112 SEFOS 1 SEFOS(config-if)# exit SEFOS 1 SEFOS(config)# vlan 40 SEFOS 1 SEFOS(config-vlan)# port extreme-ethernet 0/3 SEFOS 1 SEFOS(config-vlan)# exit SEFOS 1 SEFOS(config)# interface extreme-ethernet 0/3 SEFOS 1 SEFOS(config-if)# no shut SEFOS 1 SEFOS(config-if)# exit SEFOS 1 SEFOS(config)# interface vlan 40 SEFOS 1 SEFOS(config-if)# no shut SEFOS 1 SEFOS(config-if)# ipv6 enable SEFOS 1 SEFOS(config-if)# ipv6 address 4444::14 112 SEFOS 1 SEFOS(config-if)# end SEFOS 1 SEFOS# configure terminal SEFOS 1 SEFOS(config)# vlan 30 SEFOS 1 SEFOS(config-vlan)# port extreme-ethernet 0/7 SEFOS 1 SEFOS(config-vlan)# exit SEFOS 1 SEFOS(config)# interface extreme-ethernet 0/7 SEFOS 1 SEFOS(config-if)# no shut SEFOS 1 SEFOS(config-if)# exit SEFOS 1 SEFOS(config)# interface vlan 30 SEFOS 1 SEFOS(config-if)# no shut SEFOS 1 SEFOS(config-if)# ipv6 enable SEFOS 1 SEFOS(config-if)# ipv6 address 3333::14 112 SEFOS 1 SEFOS(config-if)# end SEFOS 1 SEFOS#
SEFOS 1 SEFOS# show ipv6 interface vlan1 is up, line protocol is up IPv6 is Enabled Link local address: fe80::221:28ff:fe56:d7a9 Global unicast address(es): Not Configured. Joined group address(es): ff02::1 ff02::2 ff02::1:ff56:d7a9 MTU is 9216 ICMP redirects are enabled ND DAD is enabled, Number of DAD attempts: 1 ND router advertisement is disabled vlan50 is up, line protocol is up IPv6 is Enabled Link local address: fe80::221:28ff:fe56:d7a9 Global unicast address(es): 5555::14/112 Joined group address(es): ff02::1 ff02::2 ff02::1:ff00:14 ff02::1:ff56:d7a9 MTU is 9216 ICMP redirects are enabled ND DAD is enabled, Number of DAD attempts: 1 ND router advertisement is disabled vlan40 is up, line protocol is up IPv6 is Enabled Link local address: fe80::221:28ff:fe56:d7a9 Global unicast address(es): 4444::14/112 Joined group address(es): ff02::1 ff02::2 ff02::1:ff00:14 ff02::1:ff56:d7a9 MTU is 9216 ICMP redirects are enabled ND DAD is enabled, Number of DAD attempts: 1 ND router advertisement is disabled vlan30 is up, line protocol is up IPv6 is Enabled Link local address: fe80::221:28ff:fe56:d7a9 Global unicast address(es): 3333::14/112 Joined group address(es): ff02::1 ff02::2 ff02::1:ff00:14 ff02::1:ff56:d7a9 MTU is 9216 ICMP redirects are enabled ND DAD is enabled, Number of DAD attempts: 1 ND router advertisement is disabled
