Skip Navigation Links
Exit Print View
Oracle Switch ES1-24 Documentation
search filter icon
search icon
Document Information
Using This Documention
Product Notes
Related Documentation
CLI Command Modes
Feedback
Support and Accessibility
Installation
Understanding the Installation
Installation Task Overview
Front Panel Components
Rear Panel Components
Confirming Specifications
Physical Specifications
Electrical Specifications
Environmental Specifications
Understanding Cabling
Understanding Management and Power Cabling
Understanding Data Cabling
Single-Switch Location Guidelines
Preparing for Installation
ESD Precautions
Tools Needed for Installation
Verify Switch Kit Contents
Verify Rack Rail Kit Contents
Assemble an SFP+ Data Cable
Route Cables
Installing the Switch
Assemble a Filler
Attach the Rails to the Switch
Attach Telco Adapters to the Rack Slides
Attach the Rack Slides to the Rack
Install the Switch Into the Rack
Attach Power Cords
Install the Air Duct and Front Support
Attach Data and Management Cables
Prepare the Front Support and Small Air Duct
Powering On the Switch
Power On the Switch
Oracle ILOM Overview
Verify the DHCP-Assigned IP Address and Host Name
Configure Network Management From the CLI (SER MGT)
Log Into the Oracle ILOM Web (NET MGT)
Log Into the Oracle ILOM CLI (NET MGT)
Log Into the Oracle ILOM CLI (SER MGT)
Configuration
Administering the Switch
Log In to the Oracle ILOM CLI
Create a SEFOS User
Change a SEFOS User Privilege Level
Configure Network Management From the Web Interface
Log Out of the Oracle ILOM CLI
Update the Firmware
Administering SEFOS
SEFOS Setup Tasks
Understanding SEFOS Basics
Configuring the SEFOS Environment
Managing Configuration Files
Managing Log Files
Configuring the Switching Feature
Switching Feature Topology
Configure Initial Settings
Verify the Configuration
Configure VLAN Forwarding
Verify VLAN Membership
Configure RSTP
Configure LA
Save a Configuration
Configuring the Routing Feature
Routing Feature Topology
Configuring Static Routing
Configuring Dynamic Routing
Disabling Routing
Service
Detecting and Managing Faults
Front Panel LEDs
Rear Panel LEDs
Check Switch Status (LEDs)
Sensors Overview
Check Switch Status (Oracle ILOM)
Component Sensor Targets
Motherboard Sensor Targets
Preparing for Service
ESD Precautions
Tools Needed for Service
Replaceable Components
Remove the Front Support and Air Duct
Remove the CMA
Install the CMA
Servicing Power Supplies
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing the Fan Module
Remove the Fan Module
Install the Fan Module
Glossary
Index
Configure LA
This task describes how to configure and test the LA feature of SEFOS running on a switch target.
See Switching Feature Topology for the topology of this task.
  1. Configure the initial settings.
    See Configure Initial Settings.
  2. Create a port-channel group 100 on SEFOS-1 and link the ports in the group.
    SEFOS-1# configure terminal
    SEFOS-1(config)# set port-channel enable
    SEFOS-1(config)# interface port-channel 100
    SEFOS-1(config-if)# no shutdown
    SEFOS-1(config-if)# exit
    SEFOS-1(config)# interface range extreme-ethernet 0/21-22
    SEFOS-1(config-if)# channel-group 100 mode active
    SEFOS-1(config)# vlan 101
    SEFOS-1(config-vlan)# ports extreme-ethernet 0/1-2 port-channel
    100 untagged extreme-ethernet 0/1-2 port-channel 100
  3. Repeat Step 2 on SEFOS-2.
  4. Verify the VLAN membership.
    SEFOS-1# show vlan
    Vlan database
    Vlan ID : 101
    Member Ports : Ex0/1,Ex0/2,po100
    Untagged Ports : Ex0/1,Ex0/2,po100
    Forbidden Ports : None
    Reflective-Relay : Disabled
    Name :
    Status : Other
  5. Verify the STP port status on SEFOS-1.
    SEFOS-1# show spanning-tree
    Root Id         Priority   32768
                    Address    00:14:4f:6c:69:ee
                    Cost       0
                    Port       0 [0]
                    Max age 20 Sec, forward delay 15 Sec
                    Hello Time 2 Sec
    MST00
    Spanning tree Protocol has been enabled
    MST00 is executing the mstp compatible Multiple Spanning Tree Protocol
    Bridge Id       Priority  32768
                    Max age is 20 sec, forward delay is 15 sec
                    Hello Time is 2 sec
                    Dynamic Path Cost is Disabled
                    Dynamic Path Cost Lag-Speed Change is Disabled
    Name              Role         State        Cost     Prio   Type
    Ex0/1                    Designated      Forwarding   2000      128      P2P
    Ex0/2                   Designated    Forwarding   2000      128     P2P
    po100                    Designated      Forwarding   2000      128      P2P
  6. Ping continuously from host A to host C.
    There should not be any data loss during traffic forwarding.
  7. Verify the port channel summary.
    SEFOS-1# show etherchannel summary
    Port-channel Module Admin Status is enabled
    Port-channel Module Oper Status is enabled
    Port-channel System Identifier is  00:14:4f:6c:69:ee
    Flags:
    D - down             P - in port-channel
    I - stand-alone      H - Hot-standby (LACP only)
    AD - Admin Down      AU - Admin Up
    OD - Operative Down  OU - Operative Up
    Number of channel-groups in use: 1
    Number of aggregators: 1
    Group  Port-channel        Protocol   Ports
    100    Po100(P)[AU,OD]     LACP       Ex0/21(P),Ex0/22(P)
  8. Shut down the port extreme-ethernet 0/21 and verify the port channel summary.
    SEFOS-1(config)# int ext 0/21
    SEFOS-1(config-if)# shut
    SEFOS-1(config-if)# end
    Flags:
    100    Po100(P)[AU,OD]     LACP       Ex0/21(D),Ex0/22(P)
    LA was configured properly if traffic flows through the port channel group.
Related Information
