Skip Navigation Links
Exit Print View
Oracle Switch ES1-24 Documentation
search filter icon
search icon
Document Information
Using This Documention
Product Notes
Related Documentation
CLI Command Modes
Feedback
Support and Accessibility
Installation
Understanding the Installation
Installation Task Overview
Front Panel Components
Rear Panel Components
Confirming Specifications
Physical Specifications
Electrical Specifications
Environmental Specifications
Understanding Cabling
Understanding Management and Power Cabling
Understanding Data Cabling
Single-Switch Location Guidelines
Preparing for Installation
ESD Precautions
Tools Needed for Installation
Verify Switch Kit Contents
Verify Rack Rail Kit Contents
Assemble an SFP+ Data Cable
Route Cables
Installing the Switch
Assemble a Filler
Attach the Rails to the Switch
Attach Telco Adapters to the Rack Slides
Attach the Rack Slides to the Rack
Install the Switch Into the Rack
Attach Power Cords
Install the Air Duct and Front Support
Attach Data and Management Cables
Prepare the Front Support and Small Air Duct
Powering On the Switch
Power On the Switch
Oracle ILOM Overview
Verify the DHCP-Assigned IP Address and Host Name
Configure Network Management From the CLI (SER MGT)
Log Into the Oracle ILOM Web (NET MGT)
Log Into the Oracle ILOM CLI (NET MGT)
Log Into the Oracle ILOM CLI (SER MGT)
Configuration
Administering the Switch
Log In to the Oracle ILOM CLI
Create a SEFOS User
Change a SEFOS User Privilege Level
Configure Network Management From the Web Interface
Log Out of the Oracle ILOM CLI
Update the Firmware
Administering SEFOS
SEFOS Setup Tasks
Understanding SEFOS Basics
Configuring the SEFOS Environment
Managing Configuration Files
Managing Log Files
Configuring the Switching Feature
Switching Feature Topology
Configure Initial Settings
Verify the Configuration
Configure VLAN Forwarding
Verify VLAN Membership
Configure RSTP
Configure LA
Save a Configuration
Configuring the Routing Feature
Routing Feature Topology
Configuring Static Routing
Configuring Dynamic Routing
Disabling Routing
Service
Detecting and Managing Faults
Front Panel LEDs
Rear Panel LEDs
Check Switch Status (LEDs)
Sensors Overview
Check Switch Status (Oracle ILOM)
Component Sensor Targets
Motherboard Sensor Targets
Preparing for Service
ESD Precautions
Tools Needed for Service
Replaceable Components
Remove the Front Support and Air Duct
Remove the CMA
Install the CMA
Servicing Power Supplies
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing the Fan Module
Remove the Fan Module
Install the Fan Module
Glossary
Index
Note - All ports in this topology are in VLAN 101.
image:Figure showing a sample topology for the switching feature.
Related Information
