Skip Navigation Links
Exit Print View
Oracle Switch ES1-24
Installation Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
CLI Command Modes
Feedback
Support and Accessibility
Understanding the Installation
Installation Task Overview
Front Panel Components
Rear Panel Components
Confirming Specifications
Physical Specifications
Electrical Specifications
Environmental Specifications
Understanding Cabling
Understanding Management and Power Cabling
Management Connection Overview
NET MGT Port
SER MGT Port
Power Cord Specifications
Understanding Data Cabling
SFP+ Data Cable Overview
10GBASE-T Data Cable Overview
Data Cable Cautions
Data Cable Guidelines
Single-Switch Location Guidelines
Preparing for Installation
ESD Precautions
Tools Needed for Installation
Verify Switch Kit Contents
Verify Rack Rail Kit Contents
Assemble an SFP+ Data Cable
Route Cables
Installing the Switch
Assemble a Filler
Attach the Rails to the Switch
Attach Telco Adapters to the Rack Slides
Attach the Rack Slides to the Rack
Install the Switch Into the Rack
Attach Power Cords
Install the Air Duct and Front Support
Attach Data and Management Cables
Prepare the Front Support and Small Air Duct
Powering On the Switch
Power On the Switch
Oracle ILOM Overview
Verify the DHCP-Assigned IP Address and Host Name
Configure Network Management From the CLI (SER MGT)
Log Into the Oracle ILOM Web (NET MGT)
Log Into the Oracle ILOM CLI (NET MGT)
Log Into the Oracle ILOM CLI (SER MGT)
Glossary
Index
image:Figure shows the components that are accessible from the front of the switch.
No.
Description
Links
1
NET MGT port
2
SER MGT port
3
10GBASE-T ports 1-20 (bottom left to right)
4
SFP+ ports 21-24 (bottom left to right)
Related Information
