Skip Navigation Links
Exit Print View
Oracle Switch ES1-24
Installation Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
CLI Command Modes
Feedback
Support and Accessibility
Understanding the Installation
Installation Task Overview
Front Panel Components
Rear Panel Components
Confirming Specifications
Physical Specifications
Electrical Specifications
Environmental Specifications
Understanding Cabling
Understanding Management and Power Cabling
Management Connection Overview
NET MGT Port
SER MGT Port
Power Cord Specifications
Understanding Data Cabling
SFP+ Data Cable Overview
10GBASE-T Data Cable Overview
Data Cable Cautions
Data Cable Guidelines
Single-Switch Location Guidelines
Preparing for Installation
ESD Precautions
Tools Needed for Installation
Verify Switch Kit Contents
Verify Rack Rail Kit Contents
Assemble an SFP+ Data Cable
Route Cables
Installing the Switch
Assemble a Filler
Attach the Rails to the Switch
Attach Telco Adapters to the Rack Slides
Attach the Rack Slides to the Rack
Install the Switch Into the Rack
Attach Power Cords
Install the Air Duct and Front Support
Attach Data and Management Cables
Prepare the Front Support and Small Air Duct
Powering On the Switch
Power On the Switch
Oracle ILOM Overview
Verify the DHCP-Assigned IP Address and Host Name
Configure Network Management From the CLI (SER MGT)
Log Into the Oracle ILOM Web (NET MGT)
Log Into the Oracle ILOM CLI (NET MGT)
Log Into the Oracle ILOM CLI (SER MGT)
Glossary
Index
Note - For single-switch configurations, follow these steps to install the filler as well.
  1. Identify the prerequisite and subsequent installation tasks that you must perform in conjunction with this procedure.
    See Installation Task Overview.
  2. Consider your next step.
    • If this is a single-switch configuration, install the filler.
      Go to Step 3.
    • If this is a dual-switch configuration, install the first switch.
      Go to Step 4.
  3. Lift the filler to the rack on the cold aisle.
    The rectangular opening at the end of the center rail should be toward you.
    Then go to Step 5.
  4. Consider your next step.
    • If you are installing the switch with the power supplies on the cold aisle, with the power supply end of the switch facing you, lift the switch to the rack on the cold aisle.
    • If you are installing the switch with the data connectors on the cold aisle, with the data connector end of the switch facing you, lift the switch to the rack on the cold aisle.
  5. Align the chassis rail on the switch or filler to the rack slide on the rack.
    image:Figure shows aligning the switch to the rack slide.
  6. If a filler or switch is already installed, align the center rail or center slide with the complementary component on the switch or filler.
  7. Supporting the weight of the switch or filler, slide the switch or filler into the rack.
  8. Continue to slide the switch or filler in all the way, so that the center slide or rail fits into the pocket in the CMA.
    image:Figure shows sliding the switch into the rack.
  9. Repeat Step 4 through Step 8 to install the switch or second switch.
  10. Attach the power cords.
    See Attach Power Cords.
Related Information
