Skip Navigation Links
Exit Print View
Oracle Switch ES1-24
Configuration Guide
search filter icon
search icon
Document Information
Using This Documention
Product Notes
Related Documentation
CLI Command Modes
Feedback
Support and Accessibility
Administering the Switch
Log In to the Oracle ILOM CLI
Create a SEFOS User
Change a SEFOS User Privilege Level
Configure Network Management From the Web Interface
Configure Network Management From the CLI
Log Out of the Oracle ILOM CLI
Update the Firmware
Administering SEFOS
SEFOS Setup Tasks
Understanding SEFOS Basics
Basic SEFOS Topology
Default Configurations
Connect to SEFOS
Disconnect From SEFOS
Configuring the SEFOS Environment
Enable or Disable the Timeout for Line Connections
Configure the Default IP Address
Configure the IP Address for an Interface
Configure the Name of the Configuration File
Configure the Default VLAN ID
Enable or Disable Trap Generation on an Interface
Configure Debug Logging
Configure ACL Filters
Configure QoS
Configure Port Mirroring
Configure Rate Limiting
Configuring Save Parameters
Managing Configuration Files
Save the Configuration to a File
Erase a Configuration File
Copy a Configuration File to a Remote Location
Copy a Configuration File From a Remote Location to Flash
Copy a Configuration File From One Remote Location or Flash to Another Remote Location or Flash
Managing Log Files
View a System Log
Copy a System Log to a Remote Location
View Debug Logs
Configuring the Switching Feature
Switching Feature Topology
Configure Initial Settings
Verify the Configuration
Configure VLAN Forwarding
Verify VLAN Membership
Configure RSTP
Configure LA
Save a Configuration
Configuring the Routing Feature
Routing Feature Topology
Configuring Static Routing
Configure Static Unicast Route Entries
Add Static Routes
Configuring Dynamic Routing
Configure RIP Dynamic Routing
Configure OSPF Dynamic Routing
Disabling Routing
Remove Static Routes
Disable RIP Dynamic Routing
Disable OSPF Dynamic Routing
Glossary
Index
  1. Verify the connections between the switches and hosts.
    See Switching Feature Topology.
    1. For the SEFOS-1 switch, verify:
      • Port 1 – Connected to host server A (IP address 20.0.0.10)
      • Port 2 – Connected to host server B (IP address 20.0.0.20)
      • Ports 21-22 – Connected to ports 21-22 on the SEFOS-2 switch
    2. For the SEFOS-2 switch, verify that port 1 is connected to host server C (IP address 20.0.0.30).
  2. Connect to SEFOS.
    See Connect to SEFOS.
  3. Create a VLAN and add the host ports as member ports of the VLAN.
    SEFOS-1# configure terminal
    SEFOS-1(config)# vlan 101
    SEFOS-1(config-vlan)# ports extreme-ethernet 0/1-2 untagged extreme-ethernet 0/1-2
    SEFOS-1(config-vlan)# vlan active
    SEFOS-1(config-vlan)# exit
  4. Bring up the interfaces on which the hosts are connected.
    SEFOS-1(config)# interface range extreme-ethernet 0/1-2
    SEFOS-1(config-if-range)# switchport pvid 101
    SEFOS-1(config-if-range)# no shutdown
    SEFOS-1(config-if-range)# exit
  5. Configure the IP address on VLAN 101 and bring up the interface.
    SEFOS-1(config-int)# interface vlan 101
    SEFOS-1(config-int)# ip address 20.0.0.1 255.0.0.0
    SEFOS-1(config-int)# no shutdown
    SEFOS-1(config-int)# exit
  6. Verify that the VLAN 101 interface is up.
    SEFOS-1# show ip interface
    vlan1 is down, line protocol is down
    Internet Address is 10.0.0.1/8
    Broadcast Address 10.255.255.255
    vlan101 is up, line protocol is up
    Internet Address is 20.0.0.1/8
  7. Check the status of the interfaces.
    SEFOS-1# show interface status
    Port Status Duplex Speed Negotiation
    Ex0/1 connected Full 10 Gbps Auto-Negotiation
    Ex0/2 connected Full 10 Gbps Auto-Negotiation
    Ex0/4 not connected Full 10 Gbps Auto-Negotiation
    SEFOS-1# show interface description
    Interface Status Protocol
    Ex0/1     up     up
    Ex0/2     up     up
    Ex0/3     down   down
    Ex0/4     down   down
    vlan101 up up
  8. Ping host A (20.0.0.10) from the SEFOS-1 switch.
    The ping should be successful.
  9. Check the MAC address entry.
    SEFOS-1# show mac-address-table
    Vlan    Mac Address         Type     Ports
    101     00:14:4f:6c:7d:e9   Learnt   Ex0/1
    Total Mac Addresses displayed: 1
    Note - The MAC address displayed must correspond to the MAC address of host A.
  10. Repeat Step 3 through Step 5 on the SEFOS-2 switch to bring up the required ports and configure the IP address of VLAN 101 to 20.0.0.2.
  11. Configure the topology.
    To configure the topology, all of the interfaces should be up. If they are not up, use the no shutdown command to bring up the ports.
    SEFOS-1(config)# interface range ex 0/21-22
    SEFOS-1(config-if-range)# end
    In both switches, ensure that the following interfaces are up: 0/1, 0/2, 0/21, 0/22.
Related Information
