Skip Navigation Links
Exit Print View
Oracle Switch ES1-24
Configuration Guide
search filter icon
search icon
Document Information
Using This Documention
Product Notes
Related Documentation
CLI Command Modes
Feedback
Support and Accessibility
Administering the Switch
Log In to the Oracle ILOM CLI
Create a SEFOS User
Change a SEFOS User Privilege Level
Configure Network Management From the Web Interface
Configure Network Management From the CLI
Log Out of the Oracle ILOM CLI
Update the Firmware
Administering SEFOS
SEFOS Setup Tasks
Understanding SEFOS Basics
Basic SEFOS Topology
Default Configurations
Connect to SEFOS
Disconnect From SEFOS
Configuring the SEFOS Environment
Enable or Disable the Timeout for Line Connections
Configure the Default IP Address
Configure the IP Address for an Interface
Configure the Name of the Configuration File
Configure the Default VLAN ID
Enable or Disable Trap Generation on an Interface
Configure Debug Logging
Configure ACL Filters
Configure QoS
Configure Port Mirroring
Configure Rate Limiting
Configuring Save Parameters
Managing Configuration Files
Save the Configuration to a File
Erase a Configuration File
Copy a Configuration File to a Remote Location
Copy a Configuration File From a Remote Location to Flash
Copy a Configuration File From One Remote Location or Flash to Another Remote Location or Flash
Managing Log Files
View a System Log
Copy a System Log to a Remote Location
View Debug Logs
Configuring the Switching Feature
Switching Feature Topology
Configure Initial Settings
Verify the Configuration
Configure VLAN Forwarding
Verify VLAN Membership
Configure RSTP
Configure LA
Save a Configuration
Configuring the Routing Feature
Routing Feature Topology
Configuring Static Routing
Configure Static Unicast Route Entries
Add Static Routes
Configuring Dynamic Routing
Configure RIP Dynamic Routing
Configure OSPF Dynamic Routing
Disabling Routing
Remove Static Routes
Disable RIP Dynamic Routing
Disable OSPF Dynamic Routing
Glossary
Index
This task describes how to configure dynamic routing using the redistribution feature of the OSPF protocol in SEFOS. This task verifies that the reachability between two hosts is established after learning the in-between routes dynamically through OSPF.
See Routing Feature Topology for the topology of this task.
  1. Verify that SEFOS-1 and SEFOS-2 still have the configuration information that you saved.
    See Configure Static Unicast Route Entries.
    The basic VLAN configuration for dynamic routing is similar to the basic VLAN configuration for static routing. If the configuration information was not saved on SEFOS-1 and SEFOS-2, follow Step 1 through Step 6 in Configure Static Unicast Route Entries.
    If SEFOS-1 or SEFOS-2 is a third-party switch, configure the basic VLAN and the dynamic routing as recommended by the switch's manufacturer.
  2. Enable OSPF on SEFOS-1.
    SEFOS-1# configure terminal
    SEFOS-1(config)# router ospf
    SEFOS-1(config-router)# asBR router
    SEFOS-1(config-router)# router-id 10.0.0.201
    SEFOS-1(config-router)# network 20.0.0.201 area 0.0.0.0
    SEFOS-1(config-router)# network 10.0.0.201 area 0.0.0.0
    SEFOS-1(config-router)# redistribute all
    SEFOS-1(config-router)# end
  3. Enable OSPF on SEFOS-2.
    SEFOS-2# configure terminal
    SEFOS-2(config)# router ospf
    SEFOS-2(config-router)# asBR router
    SEFOS-2(config-router)# router-id 40.0.0.200
    SEFOS-2(config-router)# network 20.0.0.200 area 0.0.0.0
    SEFOS-2(config-router)# network 40.0.0.200 area 0.0.0.0
    SEFOS-2(config-router)# redistribute all
    SEFOS-2(config-router)# end
    If SEFOS-2 is a third-party switch, verify that the OSPF protocol is enabled on SEFOS-2 and that related configurations are applied accordingly.
  4. Check the neighbor router status of SEFOS-1.
    SEFOS-1# show ip ospf neighbor
    Vrf default
    Neighbor-IDPriStateDeadTimeAddress    Interface
    40.0.0.2001FULL/DR  3920.0.0.200 vlan20
    SEFOS-1# show ip route
    Codes: C - connected, S - static, R - rip, B - bgp, O - ospf
    C 10.0.0.0/24 is directly connected, vlan10
    C 20.0.0.0/24 is directly connected, vlan20
    O 40.0.0.0/24 [2] via 20.0.0.200
  5. Verify the neighbor router status of SEFOS-2.
    SEFOS-2# show ip ospf neighbor
    Vrf default
    Neighbor-ID Pri State DeadTime Address Interface
    SEFOS-2# show ip route
    10.0.0.201 1 FULL/BACKUP 32 20.0.0.201 vlan20
    O 10.0.0.0/24 [2] via 20.0.0.201
    C 40.0.0.0/24 is directly connected, vlan40
    If SEFOS-2 is a third-party switch, use the appropriate command to verify the neighbor router status.
  6. Verify connectivity between SEFOS-1 and SEFOS-2 with the ping command.
Related Information
