Skip Navigation Links
Exit Print View
Oracle Ethernet Switches
L2 and L3 Deployment Best Practices
search filter icon
search icon
Document Information
Using This Documention
Product Notes
Related Documentation
CLI Command Modes
Feedback
Support and Accessibility
Switches Overview
Oracle Switch ES1-24
Sun Network 10GbE Switch 72p
Sun Blade 6000 Ethernet Switched NEM 24p 10GbE
Understanding L2 and L3 Implementations
L2 and L3 Configuration Task Overview
L2 and L3 Topology
L2 and L3 VLAN Best Practices
Adding VLANs
Add an Untagged VLAN
Add a Tagged VLAN
L2 Based Configuration Example Using PVRST Protocol
L2 PVRST Example Overview
L2 PVRST Configuration Task Overview
Configuring a Basic L2 PVRST Based Topology
Configure Switch ToR72p-1 for L2 PVRST
Configure Switch ToR72p-2 for L2 PVRST
Configure Switch ES1-24p-1 for L2 PVRST
Configure Switch ES1-24p-2 for L2 PVRST
Verify the L2 PVRST Configuration
Configuring an L2 PVRST Based Topology With Active/Standby Bond on the Servers
Prepare Switch ToR72p-1 for L2 PVRST Active/Standby on the Servers
Prepare Switch ToR72p-2 for L2 PVRST Active/Standby on the Servers
Configure Switch ES1-24p-1 for L2 PVRST Active/Standby on the Servers
Configure Switch ES1-24p-2 for L2 PVRST Active/Standby on the Servers
Verify the L2 PVRST Active/Standby Configuration on the Servers
Configuring an L2 PVRST and LLA Based Topology With Active/Active Bond on the Servers
Configure Switch ES1-24p-1 for L2 PVRST LLA Active/Active on the Servers
Configure Switch ES1-24p-2 for L2 PVRST LLA Active/Active on the Servers
Configure Switch ToR72p-1 for L2 PVRST LLA Active/Active on the Servers
Configure Switch ToR72p-2 for L2 PVRST LLA Active/Active on the Servers
Verify the L2 PVRST LLA Active/Active Configuration on the Servers
L3 RIP and OSPF Configuration Overview
L3 Implementations Overview
L3 RIP and OSPF Configuration Task Overview
Configuring L3 Routing Based Topology Using RIP
Configure Switch TOR72p-1 for L3 Routing Using RIP
Configure Switch TOR72p-2 for L3 Routing Using RIP
Configure Switch ES1-24p-1 for L3 Routing Using RIP
Configure Switch ES1-24p-2 for L3 Routing Using RIP
Verify the L3 RIP Configuration
Configuring L3 Routing Based Topology Using OSPF
Configure Switch TOR72p-1 for L3 Routing Using OSPF
Configure Switch TOR72p-2 for L3 Routing Using OSPF
Configure Switch ES1-24p-1 for L3 Routing Using OSPF
Configure Switch ES1-24p-2 for L3 Routing Using OSPF
Verify the L3 OSPF Configuration
Glossary
Index
  1. Start the configuration with all ports and the default VLAN shutdown.
    Disable GVRP and GMRP.
    ES1-24p-2 SEFOS# configure terminal
    ES1-24p-2 SEFOS(config)# set gvrp disable
    ES1-24p-2 SEFOS(config)# set gmrp disable
    ES1-24p-2 SEFOS(config)# set port-channel enable
    ES1-24p-2 SEFOS(config)# interface vlan 1
    ES1-24p-2 SEFOS(config-if)# shutdown
    ES1-24p-2 SEFOS(config-if)# no ip address
    ES1-24p-2 SEFOS(config-if)# exit
    ES1-24p-2 SEFOS(config)# interface range extreme-ethernet 0/1-24
    ES1-24p-2 SEFOS(config-if-range)# shutdown
    ES1-24p-2 SEFOS(config-if-range)# end
  2. Create and enable port-channels between switches per the topology.
    See L2 and L3 Topology.
    ES1-24p-2 SEFOS(config)# interface port-channel 14
    ES1-24p-2 SEFOS(config-if)# no shutdown
    ES1-24p-2 SEFOS(config)# interface port-channel 15
    ES1-24p-2 SEFOS(config)# interface port-channel 100
    ES1-24p-2 SEFOS(config)# end
  3. Configure VLANs manually.
    You must add at least one port to the VLAN before you can assign the VLAN a name.
    ES1-24p-2 SEFOS(config)# vlan 300
    ES1-24p-2 SEFOS(config-vlan)# ports add extreme-ethernet 0/2 name external-vlan-1
    ES1-24p-2 SEFOS(config-vlan)# vlan active
    ES1-24p-2 SEFOS(config-vlan)# exit
    ES1-24p-2 SEFOS(config)# vlan 301
    ES1-24p-2 SEFOS(config-vlan)# ports add extreme-ethernet 0/2 name external-vlan-2
    ES1-24p-2 SEFOS(config)# vlan 302
    ES1-24p-2 SEFOS(config-vlan)# ports add extreme-ethernet 0/2 name external-vlan-3
    ES1-24p-2 SEFOS(config)# vlan 303
    ES1-24p-2 SEFOS(config-vlan)# ports add extreme-ethernet 0/2 name external-vlan-4
    ES1-24p-2 SEFOS(config)# vlan 200
    ES1-24p-2 SEFOS(config-vlan)# ports add extreme-ethernet 0/2 name internal-vlan-1
    ES1-24p-2 SEFOS(config)# vlan 201
    ES1-24p-2 SEFOS(config-vlan)# ports add extreme-ethernet 0/2 name internal-vlan-2
    ES1-24p-2 SEFOS(config)# vlan 202
    ES1-24p-2 SEFOS(config-vlan)# ports add extreme-ethernet 0/2 name internal-vlan-3
    ES1-24p-2 SEFOS(config)# vlan 203
    ES1-24p-2 SEFOS(config-vlan)# ports add extreme-ethernet 0/2 name internal-vlan-4
  4. Configure the port-channels to allow all VLANs.
    ES1-24p-2 SEFOS(config-if)# switchport mode trunk
  5. Enable the ports and add them to the appropriate port-channels.
    Configure the host port to allow all VLANs.
    ES1-24p-2 SEFOS(config)# interface extreme-ethernet 0/2
    ES1-24p-2 SEFOS(config-if)# description "connected to eth2 Host-6, bond0"
    ES1-24p-2 SEFOS(config)# interface range extreme-ethernet 0/19-20
    ES1-24p-2 SEFOS(config-if)# description "connected to ES1-24p-2 on ports 19-20"
    ES1-24p-2 SEFOS(config-if)# channel-group 100 mode active
    ES1-24p-2 SEFOS(config)# interface extreme-ethernet 0/23
    ES1-24p-2 SEFOS(config-if)# description "connected to ToR72p-1 on port68"
    ES1-24p-2 SEFOS(config-if)# channel-group 14 mode active
    ES1-24p-2 SEFOS(config)# interface extreme-ethernet 0/21
    ES1-24p-2 SEFOS(config-if)# description "connected to ToR72p-1 on port72"
    ES1-24p-2 SEFOS(config)# interface extreme-ethernet 0/24
    ES1-24p-2 SEFOS(config-if)# description "connected to ToR72p-2 on port67"
    ES1-24p-2 SEFOS(config-if)# channel-group 15 mode active
    ES1-24p-2 SEFOS(config)# interface extreme-ethernet 0/22
    ES1-24p-2 SEFOS(config-if)# description "connected to ToR72p-2 on port72"
  6. Change the spanning-tree mode to PVRST and configure the bridge priority.
    ES1-24p-2 SEFOS(config)# spanning-tree mode pvrst
    Spanning Tree enabled protocol is MSTP, now MSTP is being shutdown PVRST is started.
     PVRST Module status is changed
    ES1-24p-2 SEFOS(config)# spanning-tree vlan 200 brg-priority 61440
    ES1-24p-2 SEFOS(config)# spanning-tree vlan 201 brg-priority 61440
    ES1-24p-2 SEFOS(config)# spanning-tree vlan 202 brg-priority 61440
    ES1-24p-2 SEFOS(config)# spanning-tree vlan 203 brg-priority 61440
    ES1-24p-2 SEFOS(config)# spanning-tree vlan 300 brg-priority 40960
    ES1-24p-2 SEFOS(config)# spanning-tree vlan 301 brg-priority 40960
    ES1-24p-2 SEFOS(config)# spanning-tree vlan 302 brg-priority 40960
    ES1-24p-2 SEFOS(config)# spanning-tree vlan 303 brg-priority 40960
    ES1-24p-2 SEFOS(config)# spanning-tree vlan 1 brg-priority 40960
  7. Save the configuration.
    ES1-24p-2 SEFOS# copy run start
    Building configuration ...
    [OK]
    ES1-24p-2 SEFOS#
  8. Check the spanning tree for each VLAN and the role and state of each interface.
    ES1-24p-1 SEFOS# show spanning-tree
    Spanning-tree for VLAN 200
    Root Id         Priority   8392
                    Address    00:21:28:77:d2:1d
                    Cost       1900
                    Port       po14
                    Hello Time 2 Sec, Max Age 20 Sec, Forward Delay 15 Sec
    Spanning Tree Enabled Protocol PVRST
    Bridge Id       Priority 61640
                    Address 00:10:e0:2a:fd:41
                    Hello Time 2 sec, Max Age 20 sec, Forward Delay 15 sec
                    Dynamic Path Cost is Disabled
                    Dynamic Path Cost Lag-Speed Change is Disabled
    Name     Role         State        Cost     Prio   Type
    Ex0/2    Designated   Forwarding   2000     128    P2P
    po14     Root         Forwarding   1900     128    P2P
    po15     Designated   Forwarding   1900     128    P2P
    po100    Designated   Forwarding   1900     128    P2P
    Spanning-tree for VLAN 302
    Root Id         Priority   4096
                    Address    00:17:df:18:9d:2e
                    Cost       21800
                    Port       po14
    Bridge Id       Priority 61742
    po15     Alternate    Discarding   1900     128    P2P
Related Information
