Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
Port Mirroring Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Port Mirroring Overview
Port Mirroring Description
Supported CLI Commands
Configuring Port Mirroring
Example Configuration
Configure Port Mirroring
Show Commands
Common Erroneous Configuration
Common Errors
  1. Assign the mirroring source interface.
    Enables packet forwarding for this interface.
    SEFOS-01# configure terminal
    SEFOS-01(config)# monitor session 1 source interface extreme-ethernet 0/1 both
    SEFOS-01(config)# end
    Note - The command allows to mirror either rx/tx or both packets. In this case we enable both ingress and egress packets to be forwarded.
  2. Assign the mirroring destination interfaces.
    These are the interfaces to which packets are forwarded.
    SEFOS-01(config)# monitor session 1 destination interface extreme-ethernet 0/3 secondary interface extreme-ethernet 0/4 vlan 100
    SEFOS-1 (config)# end
    Note - The use of the secondary interface is optional. You could use monitor session 1 destination interface Ex 0/3, and Ex 0/3 would be the only destination interface.
    Note - A maximum of three secondary destination interfaces are allowed per session.
    Note - You must assign a VLAN when you configure a secondary interface.
  3. Disable spanning tree on the primary destination interface.
    Note - This is only required when you configure a secondary destination interface.
    SEFOS-1 # configure terminal
    SEFOS-1 (config) # interface extreme-ethernet 0/3
    SEFOS-1 (config-if) # spanning-tree disable
  4. (Optional) Create multiple sessions (maximum 4).
    SEFOS-1 (config) # monitor session 2 destination interface extreme-ethernet 0/10
    SEFOS-1 (config) # monitor session 2 source interface extreme-ethernet 0/12 rx
    Source or destination ports of one session cannot be used in another session.
