Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
EVB Administration Guide
PDF
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
EVB Overview
Protocol Description
Supported CLI Commands
Configuring EVB
Example Configuration
Configuring EVB on the Switch
Configure and Enable EVB on an Oracle Solaris Host
Show Commands
CLI Command Modes
The following table lists the configuration modes used in this document with their access and exit methods.
Command Mode
Access Method
Prompt
Exit Method
User EXEC
Access SEFOS from Oracle ILOM with read-only rights (privilege level 1).
SEFOS>
Use the logout or exit command to return to the Oracle ILOM prompt.
Privileged EXEC
Access SEFOS from Oracle ILOM with full administrative rights (privilege level 15).
SEFOS#
Global Configuration
From Privileged EXEC mode, use the configure terminal command.
SEFOS(config)#
Use the end command to return to Privileged EXEC mode.
Interface Configuration
From Global Configuration mode, use the interface interface-type interface-id command.
SEFOS(config-if)#
Use the exit command to return to Global Configuration mode, or use the end command to return to Privileged EXEC mode.
