Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
IEEE DCBX Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
DCB Overview
DCB Protocol
ETS Feature
PFC Feature
Application Priority Feature
Configuring DCB
DCB Example Topology
Configuration Specifications
Configuration Guidelines
Default Settings
Configure DCB Features
Verifying DCB and LLDP Configurations
Determine Whether Interfaces Are Active
Determine Whether LLDP is Running and Recognizing Peers
Enable DCB
Disable DCB
Enable DCB for Each Interface
Disable DCB for Each Interface
Enable and Disable a Specific DCB Feature
Configure the Mode for the DCB Feature
Configure DCB ETS Attributes
Configure DCB PFC Attributes
Configure DCB APP features
Configure LLDP DCBX TLVs
Show DCBX Feature Statistics and Control Information
Display Output of Unstarted DCBX Protocol Exchange
Clear Feature Statistics
Display Output Showing a Down Link
All the configurations explained in this document are based on the following topology.
image:Figure showing an example DCBX enabled switch topology
