Skip Navigation Links | |
Exit Print View | |
Sun Ethernet Fabric Operating System IEEE DCBX Administration Guide |
Verifying DCB and LLDP Configurations
Determine Whether Interfaces Are Active
Determine Whether LLDP is Running and Recognizing Peers
Disable DCB for Each Interface
Enable and Disable a Specific DCB Feature
Configure the Mode for the DCB Feature
Show DCBX Feature Statistics and Control Information
The topology in this document is configured with these specifications:
In a configuration using DCB with SEFOS switches, the host server (server 1) has the following specifications:
Sun Dual 10GbE PCIe 2.0 low profile adapter connected to the switch.
Oracle Solaris interface - net3 ixgbe1
Switch port number - 21
Host server running Oracle Solaris 11 or later.
SEFOS DCB only supports a server with a Sun Dual 10GbE SFP+ PCIe 2.0 Adapter installed.
Switch A has the following specifications:
Port 21 is connected to the host Oracle Solaris server.
