Hardware and Software Requirements
Installing InfiniBand on Oracle Solaris OS
InfiniBand for Oracle Solaris OS
Verify the Installation (Oracle Solaris)
Update the Firmware (Oracle Solaris)
InfiniBand Devices (Oracle Solaris)
Installing InfiniBand on Oracle Linux OS
InfiniBand for Oracle Linux OS
Enable Ethernet Over Oracle IB Gateway
Verify the Installation (Oracle Linux)
Replacing a Short Bracket With a Tall Bracket
Remove the Short Bracket From the Adapter
Refer to the installation or service manual that applies to your server for detailed instructions for the following procedure.
Caution - Electronic components on printed circuit boards are extremely sensitive to static electricity. Ordinary amounts of static electricity generated by your clothing or work environment can damage electronic equipment. When installing the adapter in a system, use antistatic grounding straps and antistatic mats to help prevent damage due to electrostatic discharge. |
Note - Hot-swapping is not supported with Oracle Solaris 11.1 SRU9.
An alternative tall bracket is supplied with the adapter. If you need to use a different bracket, perform the instructions in Replacing a Short Bracket With a Tall Bracket.
Product documentation for Sun servers is available at: http://docs.oracle.com.
Caution - Avoid putting unnecessary stress on the connection. Do not bend or twist the cable near the connectors, and avoid cable bends of more than 90 degrees. |
The IB-HCA ports can be connected to different ports on the same switch or to a port on different switches.
This step completes the hardware installation.
See Verify the Installation (Oracle Solaris) or Verify the Installation (Oracle Linux).
