Go to main content
Sun Flash Accelerator F80 PCIe Card Product Notes
Exit Print View
Updated: March 2017
Supported Servers and Operating Systems
This section describes servers that support the Sun Flash Accelerator F80 PCIe Card. For detailed information about using this card with your server, see the product notes for your server, available at:
https://docs.oracle.com
The following servers are supported for the Sun Flash Accelerator F80 PCIe Card:
SPARC Servers
Number of Cards
Slots Supported and Preferred Order for Installing F80 Card
Supported Operating Systems
SPARC T4-1
1 to 2
5, 3
  • Oracle Solaris 11.1
  • Oracle Solaris 10 8/11 OS with required patchsets
  • Oracle Solaris 10 9/10 OS with the Solaris 10 8/11 SPARC Bundle and required patchsets
SPARC T4-2
1 to 4
9, 8, 7, 0 (Slot 6 if Slot 0 is unavailable)
SPARC T5-2
1 to 6
1, 8 ,2, 7, 3, 6, 4, 5
SPARC T5-4
1 to 8
1, 3, 5, 7, 9, 11, 13, 15
Requires a doublewide carrier to facilitate air flow.
SPARC T5-8
1 to 8
SPARC M5-32
1 to 60
Slot 8 in each I/O unit (IOU) is not supported.
SPARC M6-32
1 to 60
Fujitsu M10-1
1 to 3
2, 0, 1
  • Oracle Solaris 11.1 SRU 1.4
  • Oracle Solaris 10 1/13 OS with required patchsets
Fujitsu M10-4
1 to 11
10, 6, 2, 8, 4, 9, 5, 1, 7, 3, 0
Fujitsu M10-4S
1 to 8
6, 2, 4, 5, 1, 7, 3, 0
Note -  Direct I/O support (DIO) is available for SPARC T4-1 and T4-2 servers.
x86 Servers
Number of F80 Cards
Slots Supported for Installing F80 Card
Sun Server X4-8
4 processors:
8 processors:
1-4
1-8
7, 5, 3, 1
11, 9, 7, 5, 3, 1, 15, 13
  • Oracle Solaris 11.1 (SRU 12)
  • Oracle Linux 6.5, based on UEK3 (Unbreakable Linux Kernel Release 3)
  • Oracle Linux 5.10, based on UEK3 (Unbreakable Linux Kernel Release 3)
  • Oracle Virtual Machine 3.2.7
Sun Server X4-4
2 processors:
4 processors:
1-4
1-6
6, 4, 5, 3
10, 7, 6, 3, 8, 5
Sun Server X4-2L
1 to 4
1, 2, 4, 5
  • Oracle Linux 5.9, based on UEK2 (Unbreakable Linux Kernel Release 2)
  • Oracle Linux 6.4, based on UEK2 (Unbreakable Linux Kernel Release 2)
Note -  Sun Server X4-2L with pre-installed Oracle VM 3.2 is not supported for Sun Flash Accelerator F80 PCIe Card operation.
Other servers and processors may be added to this list in the future, if they qualify. Check your server product notes for confirmation that your server has subsequently been qualified.
Caution
Caution  -  Any unsupported configuration causes the host to power off as soon as it is powered on. A fault is generated on the service processor when an unsupported configuration is detected. The fault clears after the unsupported configuration is fixed and the host is powered on.
Note -  Refer to the server's product notes for up-to date information on supported servers, operating systems and required patchsets.
