Skip Navigation Links
Exit Print View
Sun Storage Common Array Manager
Software Release Notes, Release 6.10 for Solaris OS Hosts
search filter icon
search icon
Document Information
1.  CAM 6.10 Release Notes for Solaris OS
What's New in CAM 6.10
Controller and Disk Firmware Updates
Service Advisor ASR Update
Clearing Controller Recovery Mode
About the CAM Software
How to Get the Software
What You Get With the Software
Documentation
For Product Information...
Mixing Drive Speeds and Capacities
System Requirements
Supported Arrays
Supported Host Operating Systems
Supported Web Browsers
Firefox Browser Issues
Best Practices for Browser Performance
Supported Languages
Solaris Patches for SAS HBAs
Upgrading Firmware
2500 Arrays Upgrade
2500 Array Support for VMware ESX 4.1 with Firmware 07.35.55.10 and later
6540, 6140, and FLX380 Arrays Upgrade
J4000 Arrays
Sun Blade 6000 Disk Module
Sun Storage F5100 Flash Array Notes
Supported Expansion Modules
Notable Fixes
Known Issues
Array Issues
Controller Smart battery replacement procedure
AIX host type for 6140 arrays
Battery nears expiration: 06.xx write back cache should not be disabled
Both RAID controllers reboot after 828.5 days--2500/6000 arrays
Communication Loss reported from Windows and Linux when registering JBODs on Oracle Enterprise Linux 6 proxy
Reboots occur due to ancient I/O being aborted in large configurations
Configuration Issues
Reregister Auto Service Request for CAM
Auto Service Request advisory note: DTS Listener transfer
Array name remains unchanged after a full array reset
Access Configuration: Cascaded J4400 issues
Access Configuration fails with error: java.util.HashMap cannot be cast to java.util.Properties
Access Configuration: non-zoned SAS2 wide port aggregation FRU Report display—F5100 + 6Gb/sec HBA
Array lock key must be set before configuration files are imported
ComponentInsertEvent not generated for disk drive inserted into J4200
Current Jobs page can take more than five minutes to display
Expander firmware 5.3.73 does not persist a SAS zone group
Replication status incorrect when primary volume fails
Service Advisor: replacing failed SIM with dual path configurations
Volumes not deleting from the Single Page window
Attempt to delete partner replication set on secondary array fails
Documentation Issues
Incorrect Windows server OS listed in CAM 6.9 Release Notes
Incorrect sscs add notification description in CLI guide
2500 Series Release Notes: Simplex vs. Duplex Configurations
Disk Locked description is inaccurate in online help
Firmware Update Issues
Firmware upgrade fails with error: FWR_UPGRADE_FAILURE,6 for J4200/J4400 arrays
Firmware upgrade fails on J4400 SATA drives
Firmware upgrade fails when expander and disks are upgraded together
Firmware upgrade not recognized by GUI until agent runs
Sun Blade 6000 firmware upgrade error: No such expander - 50800200006deabf SIGSEGV in Linux libSTORARC.so
Sun Blade 6000 firmware upgrade fails with down-level expander
Sun Blade 6250 and 6270—upgrading network expansion modules fails
Installation and Upgrade Issues
Error occurs when upgrading 2510 controller and drive firmware
Installation fails on SUSE 10.3 32-bit and 64-bit hosts
Solaris Issues
Solaris with Veritas DMP or other host type
Error—”no execute access to opt/SMgr/agent/ notifysmagent.sh”—occurs during system boot-up
UTM LUNs Controlled by “Solaris Traffic Manager” 6000/2500 arrays
Contacting Support
Intermixing drives in 61x0, CSM2, 25xx, and 25xx-M2 trays is supported. However, the following limitations apply to mixed drives within a pool.
