Go to main content
SPARC T7-1 Server Service Manual
Exit Print View
Updated: February 2019
Locate a Faulty DIMM (Oracle ILOM)
The Oracle ILOM show faulty command displays current faults, including DIMM failures.
  1. Type show faulty at the Oracle ILOM prompt.
    If a DIMM is faulty, the show faulty output is similar to this example.
    -> show faulty
    Target              | Property          | Value
    /SP/faultmgmt/0     | fru               | /SYS/MB/CM/CMP/BOB21/CH0
    /SP/faultmgmt/0     | timestamp         | Dec 21 16:40:56
    /SP/faultmgmt/0/    | timestamp         | Dec 21 16:40:56 faults/0
    /SP/faultmgmt/0/    | sp_detected_fault | /SYS/MB/CM/CMP/BOB21/CH0
    faults/0            |                   | Forced fail(POST)
  2. Locate the DIMM that corresponds to the listed FRU name.
    In this example, /SYS/MB/CM/CMP/BOB21/CH0 indicates the DIMM slot on the motherboard that is farthest from the power supplies.
Related Information
