Go to main content
SPARC T7-2 Server Installation Guide
Exit Print View
Updated: July 2017
VGA Port
The server has two VGA video ports, one port on the front and one on the rear panel. See Front Panel Components (Installation) and Rear Panel Components (Installation).
Note - Only one of the two ports can be used at a time. The rear VGA port is disabled by default. To enable the rear port and disable the front port, you must enable the Oracle ILOM VGA_REAR_PORT policy: -> set /SP/policy VGA_REAR_PORT=enabled.
Note - The cable length used to connect between the monitor and the VGA port should not be over 6 meters.
image:Figure showing video connectors.
Pin
Signal Description
Pin
Signal Description
1
Red Video
9
[KEY]
2
Green Video
10
Sync Ground
3
Blue Video
11
Monitor ID - Bit 1
4
Monitor ID - Bit 2
12
VGA 12C Serial Data
5
Ground
13
Horizontal Sync
6
Red Ground
14
Vertical Sync
7
Green Ground
15
VGA 12C Serial Clock
8
Blue Ground
Related Information
