Go to main content
SPARC T7-2 Server Service Manual
Exit Print View
Updated: July 2019
Reactivate RAID Volumes
Perform this task only if your server had RAID volumes prior to replacing the motherboard.
  1. Prior to powering on the server, log in to the SPM.
    Refer to Servers Administration for instructions.
  2. At the Oracle ILOM prompt, disable auto-boot so that the server will not boot the OS when the server powers on.
    -> set /HOST/bootmode script="setenv auto-boot? false"
  3. Power on the server.
    See Power On the Server (Oracle ILOM) or Power On the Server (System Power Button).
  4. At the OpenBoot prompt, list the device paths on the server.
    ok show-devs
    /pci@301/pci@1/scsi@0
    /pci@303/pci@1/scsi@0
    You can also use the devalias command to locate device paths specific to your server.
    ok devalias
    SAS0                    /pci@301/pci@1/scsi@0
    SAS1                   /pci@303/pci@1/scsi@0
  5. Choose the RAID module on the motherboard.
    ok select scsi
    Instead of using the alias name scsi, you could type the full device path name (such as /pci@400/pci@2/pci@0/pci@e/scsi@0).
  6. List all connected logical RAID volumes to determine which volumes are in an inactive state.
    ok show-volumes
    For example, the following output shows an inactive volume:
    ok show-volumes
    Volume 0 Target 389  Type RAID1 (Mirroring)
      WWID 03b2999bca4dc677
      Optimal  Enabled  Inactive
      2 Members                    583983104 Blocks, 298 GB
    Disk 1
       Member 0  Optimal
       Target a      HGST     H101860SFSUN600G A770   PhyNum 1
     Disk 0
       Member 1  Optimal
       Target b      HGST     H101860SFSUN600G A770   PhyNum 2
  7. For each RAID volume listed as inactive, type the following command to activate that volume.
    ok inactive_volume activate-volume
    where inactive_volume is the name of the RAID volume that you are activating. For example:
    ok 0 activate-volume
    Volume 0 is now activated
    Note - For more information on configuring hardware RAID on the server, refer to Servers Administration.
  8. Unselect the SCSI device.
    ok unselect-dev
  9. Confirm that you reactivated the volume.
    ok probe-scsi-all
    /pci@308/pci@1/usb@0/hub@1/storage@3
     Unit 0   Disk     smiMICRON  eUSB DISK       1112
    /pci@308/pci@1/usb@0/hub@1/storage@1
     Unit 0   Removable Read Only device    SUNRemote ISO CDROM1.01
    /pci@308/pci@1/usb@0/hub@5/device@4/storage@0
     Unit 0   Removable Read Only device    TEAC    DV-W28S-C       LT11
    FCode Version 1.00.64, MPT Version 2.05, Firmware Version 5.05.00.00
    Target 9
     Unit 0   Disk   HGST     H101860SFSUN600G A770    1172123568 Blocks, 600 GB
     SASDeviceName 5000cca02f0a1560  SASAddress 5000cca02f0a1561  PhyNum 0
    Target 389 Volume 0
      Unit 0   Disk   LSI      Logical Volume   3000    583983104 Blocks, 298 GB
      VolumeDeviceName 33b2999bca4dc677  VolumeWWID 03b2999bca4dc677
  10. Set the auto-boot? OpenBoot PROM variable to true so the server boots the OS when powered on.
    ok setenv auto-boot? true
  11. Reboot the server.
    See Server Administration.
Related Information
