Go to main content
SPARC T7-2 Server Service Manual
Exit Print View
Updated: July 2019
Locate a Faulty DIMM (Oracle ILOM)
The Oracle ILOM show faulty command displays current faults, including DIMM failures.
  1. At the Oracle ILOM prompt, type:
    -> show faulty
    Target              | Property          | Value
    /SP/faultmgmt/0     | fru               | /SYS/MB/CM0/CMP/MR0/BOB1/CH0/DIMM
    /SP/faultmgmt/0     | timestamp         | Dec 21 16:40:56
    /SP/faultmgmt/0/    | timestamp         | Dec 21 16:40:56 faults/0
    /SP/faultmgmt/0/    | sp_detected_fault | /SYS/MB/CM0/CMP/MR0/BOB1/CH0/DIMM
    faults/0            |                   | Forced fail(POST)
  2. Locate the DIMM that corresponds to the listed name.
    See Memory Riser and DIMM FRU Names.
    In this example, /SYS/MB/CM0/CMP/MR1/BOB1/CH0/DIMM indicates the memory riser that is second farthest from the power supplies and the DIMM in a slot with white handles and a black slot.
Related Information
