Go to main content
SPARC T7-2 Server Service Manual
Exit Print View
Updated: July 2019
Power On the Server (System Power Button)
Caution
Caution  - Do not operate the server without all fans, component heat sinks, air baffles, fillers, and the cover installed. Severe damage to server components can occur if the server is operated without adequate cooling mechanisms.
  1. Verify that the power cords are connected and that standby power is on.
    Shortly after power is applied to the server, the SPM Fault LED blinks as the SPM boots. The SP Fault LED is illuminated solid green when the SPM has successfully booted. After the SPM has booted, the Power LED on the front panel begins flashing slowly, indicating that the host is in standby power mode.
    image:Figure showing power button and LEDs related to power on the front panel.
  2. Press and release the recessed system Power button on the server front panel.
    No.
    Description
    1
    Power LED
    2
    Power button
    3
    SP Fault LED
    When main power is applied to the server, the main Power LED begins to blink more quickly, while the server boots and lights solidly once the OS boots.
    Each time the server powers on, POST can take several minutes to complete tests.
Related Information
