Go to main content
SPARC T7 Series Servers Administration Guide
Exit Print View
Updated: August 2017
Locate Device Paths (OpenBoot)
  1. Display the OpenBoot prompt.
    See Obtaining the OpenBoot Prompt.
  2. From the OpenBoot prompt, type:
    Note -  This document applies to several server products. The following example is based on the SPARC T7-1 server. Your output might vary from the examples based on your product.
    ok devalias
    screen                   /pci@300/pci@4/display@0
    rcdrom                   /pci@300/pci@2/usb@0/hub@3/storage@1/disk@0
    net3                     /pci@300/pci@3/network@0,1
    net2                     /pci@300/pci@3/network@0
    cdrom                    /pci@300/pci@2/usb@0/hub@8/device@1/storage@0/disk@0
    net1                     /pci@300/pci@1/network@0,1
    net                      /pci@300/pci@1/network@0
    net0                     /pci@300/pci@1/network@0
    disk7                    /pci@301/pci@2/scsi@0/disk@p7
    disk6                    /pci@301/pci@2/scsi@0/disk@p6
    disk5                    /pci@301/pci@2/scsi@0/disk@p5
    disk4                    /pci@301/pci@2/scsi@0/disk@p4
    disk3                    /pci@301/pci@2/scsi@0/disk@p3
    disk2                    /pci@301/pci@2/scsi@0/disk@p2
    disk1                    /pci@301/pci@2/scsi@0/disk@p1
    disk                     /pci@301/pci@2/scsi@0/disk@p0
    disk0                    /pci@301/pci@2/scsi@0/disk@p0
    scsi                     /pci@301/pci@2/scsi@0
    scsi0                    /pci@301/pci@2/scsi@0
    virtual-console          /virtual-devices/console@1
    name                     aliases
Related Information
