This section provides the procedure for testing cluster interconnect redundancy.
Before You Begin
To perform this procedure, become an administrator that provides solaris.cluster.read and solaris.cluster.modify authorization.
Messages similar to the following appear on the consoles of each node and are logged in the /var/adm/messages file.
Nov 4 08:27:21 node1 genunix: WARNING: ce1: fault detected external to device; service degraded Nov 4 08:27:21 node1 genunix: WARNING: ce1: xcvr addr:0x01 - link down Nov 4 08:27:31 node1 genunix: NOTICE: clcomm: Path node1:ce1 - node1:ce0 being cleaned up Nov 4 08:27:31 node1 genunix: NOTICE: clcomm: Path node1:ce1 - node1:ce0 being drained Nov 4 08:27:31 node1 genunix: NOTICE: clcomm: Path node1:ce1 - node1:ce0 being constructed Nov 4 08:28:31 node1 genunix: NOTICE: clcomm: Path node1:ce1 - node1:ce0 errors during initiation Nov 4 08:28:31 node1 genunix: WARNING: Path node1:ce1 - node1:ce0 initiation encountered errors, errno = 62. Remote node may be down or unreachable through this path.
Use the following command to verify that the interconnect path displays as Faulted.
# clinterconnect status
Nov 4 08:30:26 node1 genunix: NOTICE: ce1: fault cleared external to device; service available Nov 4 08:30:26 node1 genunix: NOTICE: ce1: xcvr addr:0x01 - link up 1000 Mbps full duplex Nov 4 08:30:26 node1 genunix: NOTICE: clcomm: Path node1:ce1 - node1:ce0 being initiated Nov 4 08:30:26 node1 genunix: NOTICE: clcomm: Path node1:ce1 - node1:ce0 online
Use the following command to verify that the interconnect path displays as Online.
