Go to main content
Oracle® SuperCluster M8 and SuperCluster M7 Administration Guide
Exit Print View
Updated: June 2020
Install STB (Oracle Solaris Only)
  1. If needed, download Services Tools Bundle from:
    https://www.oracle.com/support/premier/auto-service-request.html
    and click on the Download link.
  2. Untar the STB bundle and run the installation script (install_stb.sh).
    As part of the installation, select:
    • Type I for "install"
    • Type Y to replace existing SNEEP packages
    • Type Y to replace existing Service Tags packages
      Note -  See Doc ID 1153444.1 to download the latest STB bundle from My Oracle Support (log in required): https://support.oracle.com.
  3. Confirm that SNEEP is installed correctly:
    sneep -a
  4. Verify that Service Tags is reporting your system attributes correctly:
    stclient -E
    If the serial number does not display, then register the serial number manually:
    sneep -s serial-number
