Siebel Security Guide > Communications and Data Encryption >
Process of Upgrading Data to a Higher Encryption Level
To upgrade your data to a higher encryption level, perform the following tasks:
  1. Verify that all requirements are met.
    For information, see Requirements for Upgrading to a Higher Encryption Level.
  2. Make sure that the input file includes every column that you want to upgrade.
    For information, see Modifying the Input File.
  3. Run the Key Database Manager utility to change the password or add a new key to the database.
    For information, see Managing the Key File Using the Key Database Manager.
  4. Upgrade the data to a higher level of encryption.
    For information, see Running the Encryption Upgrade Utility.
Siebel Security Guide Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices.
