Siebel Security Guide > Communications and Data Encryption > Security Considerations for Unicode SupportSiebel Business Applications support Unicode. For comprehensive Unicode compliance, consider the following encryption and authentication issues. Using Non-ASCII Characters in a Unicode Environment
Logging In to a Siebel ApplicationMake sure that the characters used in the login form are supported by the Siebel database. Encrypted DataSiebel Business Applications provide AES encryption to encrypt data for sensitive information such as credit card numbers. For encryption with Unicode, you must use AES encryption, rather than the Standard Encryptor, which is no longer supported. For more information, see About Data Encryption. |
Siebel Security Guide | Copyright © 2014, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
