Go to main content
Oracle® Developer Studio 12.5: Performance Library User's Guide
Exit Print View
Updated: June 2016
SPSOLVE Interface
SPSOLVE computes the solution of a sparse system through a sequence of steps: Initialization, ordering to reduce fill-in, symbolic factorization, numeric factorization, and triangular solve. A user code can call individual routines or make use of a one-call interface to perform these steps.
SPSOLVE Routines
Listed in the table below are user-accessible routines in SPSOLVE and their purposes.
Table 4  SPSOLVE Sparse Solver Routines
Routine Name
Description
DGSSFS()
One-call interface to sparse solver
DGSSIN()
Sparse solver initialization
DGSSOR()
Fill reducing ordering and symbolic factorization
DGSSUO()
Sets user-specified ordering permutation and performs symbolic factorization (called in place of DGSSOR)
DGSSFA()
Matrix value input and numeric factorization
DGSSSL()
Triangular solve
DGSSRP()
Returns permutation used by solver
DGSSCO()
Returns condition number estimate of coefficient matrix
DGSSDA()
De-allocates sparse solver
DGSSPS()
Prints solver statistics
Matrices with the same structure but with different numerical values can be solved by calling SPSOLVE routines in the following order shown:
call dgssin() ! initialization, input coefficient matrix structure
call dgssor() ! fill-reducing ordering, symbolic factorization
              ! (or call dgssuo() to specify a user ordering,
              ! and perform symbolic factorization)
do m = 1, number_of_structurally_identical_matrices
   call dgssfa() ! input coefficient matrix values, numeric                  ! factorization
   do r = 1, number_of_right_hand_sides
      call dgsssl() ! triangular solve
   enddo
enddo
The one-call interface is not as flexible as the regular interface, but it covers the most common case of factoring a single matrix and solving some number of right-hand sides. Additional calls to dgsssl() are used to solve for additional right-hand sides, as shown in the following example.
call dgssfs() ! initialization, input coefficient matrix structure
              ! input coefficient matrix values, numeric factorization
              ! triangular solve
enddo
SPSOLVE Routine Calling Order
To use SPSOLVE, you must call its routines in the following order shown:
  1. One-Call Interface: For solving single matrix
    1. DGSSFS() - Initialize, order, factor, solve
    2. DGSSSL() - Additional solves (optional): repeat DGSSSL() as needed
    3. DGSSDA() - Deallocate working storage
  2. Regular Interface: For solving multiple matrices with the same structure
    1. DGSSIN() - Initialize
    2. DGSSOR() or DGSSUO() - Order and symbolically factor
    3. DGSSFA() - Factor
    4. DGSSSL() - Solve: repeat DGSSFA() or DGSSSL() as needed
    5. DGSSDA() - Deallocate working storage
SPSOLVE Examples
The following examples show solving a symmetric system using the one-call interface, and solving a symmetric system using the regular interface.
In Example 1, the one-call interface is used to solve a symmetric system, and in Example 2, individual routines are called to solve a symmetric system.
Example 5 shows how the Fortran SPSOLVE interface can be called from a C program. For more information on how to call Fortran routines from C programs, see the Oracle Solaris Studio 12.4: Fortran Programming Guide.
Example 1  Solving a Symmetric System-One-Call Interface
my_system% cat example_1call.f
      program example_1call
c
c  This program is an example driver that calls the sparse solver.
c    It factors and solves a symmetric system, by calling the
c    one-call interface.
c
      implicit none
      integer           neqns, ier, msglvl, outunt, ldrhs, nrhs
      character         mtxtyp*2, pivot*1, ordmthd*3
      double precision  handle(150)
      integer           colstr(6), rowind(9)
      double precision  values(9), rhs(5), xexpct(5)
      integer           i
c
c  Sparse matrix structure and value arrays.  From George and Liu,
c  page 3.
c    Ax = b, (solve for x) where:
c
c      4.0   1.0   2.0   0.5   2.0       2.0       7.0
c      1.0   0.5   0.0   0.0   0.0       2.0       3.0
c  A = 2.0   0.0   3.0   0.0   0.0   x = 1.0   b = 7.0
c      0.5   0.0   0.0   0.625 0.0      -8.0      -4.0
c      2.0   0.0   0.0   0.0  16.0      -0.5      -4.0
c
      data colstr / 1, 6, 7, 8, 9, 10 /
      data rowind / 1, 2, 3, 4, 5, 2, 3, 4, 5 /
      data values / 4.0d0, 1.0d0, 2.0d0, 0.5d0, 2.0d0, 0.5d0, 3.0d0,
     &              0.625d0, 16.0d0 /
      data rhs    / 7.0d0, 3.0d0, 7.0d0, -4.0d0, -4.0d0 /
      data xexpct / 2.0d0, 2.0d0, 1.0d0, -8.0d0, -0.5d0 /
c
c  set calling parameters
c
      mtxtyp= 'ss'
      pivot = 'n'
      neqns  = 5
      nrhs   = 1
      ldrhs  = 5
      outunt = 6
      msglvl = 0
      ordmthd = 'mmd'
c
c  call single call interface
c
      call dgssfs ( mtxtyp, pivot,  neqns , colstr, rowind,
     &              values, nrhs  , rhs,    ldrhs , ordmthd,
     &              outunt, msglvl, handle, ier             )
      if ( ier .ne. 0 ) goto 110
c
c  deallocate sparse solver storage
c
      call dgssda ( handle, ier )
c
c  print values of sol
c
      write(6,200) 'i', 'rhs(i)', 'expected rhs(i)', 'error'
      do i = 1, neqns
        write(6,300) i, rhs(i), xexpct(i), (rhs(i)-xexpct(i))
      enddo
      stop
  110 continue
c
c call to sparse solver returns an error
c
      write ( 6 , 400 )
     &      ' example: FAILED sparse solver error number = ', ier
      stop
  200 format(a5,3a20)
  300 format(i5,3d20.12) ! i/sol/xexpct values
  400 format(a60,i20) ! fail message, sparse solver error number
      end
my_system% f95 -dalign example_1call.f -library=sunperf
my_sytem% a.out
    i              rhs(i)     expected rhs(i)               error
    1  0.200000000000D+01  0.200000000000D+01 -0.528466159722D-13
    2  0.200000000000D+01  0.200000000000D+01  0.105249142734D-12
    3  0.100000000000D+01  0.100000000000D+01  0.350830475782D-13
    4 -0.800000000000D+01 -0.800000000000D+01  0.426325641456D-13
    5 -0.500000000000D+00 -0.500000000000D+00  0.660582699652D-14
Example 2  Solving a Symmetric System – Regular Interface
my_system% cat example_ss.f
      program example_ss
c
c  It factors and solves a symmetric system.
      implicit none
      integer           i
c
c  page 3.
c
c
     &             3.0d0, 0.625d0, 16.0d0 /
c
c  initialize solver
c
      mtxtyp= 'ss'
      pivot = 'n'
      neqns  = 5
      outunt = 6
      msglvl = 0
c
c  call regular interface
c
      call dgssin ( mtxtyp, pivot,  neqns , colstr, rowind,
c
c  ordering and symbolic factorization
c
      ordmthd = 'mmd'
      call dgssor ( ordmthd, handle, ier )
c
c  numeric factorization
c
      call dgssfa ( neqns, colstr, rowind, values, handle, ier )
c
c  solution
c
      nrhs   = 1
      ldrhs  = 5
      call dgsssl ( nrhs, rhs, ldrhs, handle, ier )
c
c
c
c
      do i = 1, neqns
      enddo
      stop
  110 continue
c
c
      write ( 6 , 400 )
      stop
  200 format(a5,3a20)
      end
my_system% f95 -dalign example_ss.f -library=sunperf
my_sytem% a.out
Example 3  Solving a Structurally Symmetric System With Unsymmetric Values – Regular Interface
my_system% cat example_su.f
      program example_su
c
c    It factors and solves a structurally symmetric system
c    (w/unsymmetric values).
c
      implicit none
      integer           colstr(5), rowind(8)
      double precision  values(8), rhs(4), xexpct(4)
      integer           i
c
c  Sparse matrix structure and value arrays.  Coefficient matrix
c    has a symmetric structure and unsymmetric values.
c
c      1.0   3.0   0.0   0.0       1.0        7.0
c      2.0   4.0   0.0   7.0       2.0       38.0
c  A = 0.0   0.0   6.0   0.0   x = 3.0   b = 18.0
c      0.0   5.0   0.0   8.0       4.0       42.0
c
      data colstr / 1, 3, 6, 7, 9 /
      data rowind / 1, 2, 1, 2, 4, 3, 2, 4 /
      data values / 1.0d0, 2.0d0, 3.0d0, 4.0d0, 5.0d0, 6.0d0, 7.0d0,
     &              8.0d0 /
      data rhs    / 7.0d0, 38.0d0, 18.0d0, 42.0d0 /
      data xexpct / 1.0d0, 2.0d0, 3.0d0, 4.0d0 /
c
c  initialize solver
c
      mtxtyp= 'su'
      pivot = 'n'
      neqns  = 4
      outunt = 6
      msglvl = 0
c
c
c
c
      ordmthd = 'mmd'
c
c
c
c  solution
c
      nrhs   = 1
      ldrhs  = 4
c
c
c
c
      do i = 1, neqns
      enddo
      stop
  110 continue
c
c
      write ( 6 , 400 )
      stop
  200 format(a5,3a20)
      end
my_system% f95 -dalign example_su.f -library=sunperf
my_system% a.out
    1  0.100000000000D+01  0.100000000000D+01  0.000000000000D+00
    2  0.200000000000D+01  0.200000000000D+01  0.000000000000D+00
    3  0.300000000000D+01  0.300000000000D+01  0.000000000000D+00
    4  0.400000000000D+01  0.400000000000D+01  0.000000000000D+00
Example 4  Solving an Unsymmetric System – Regular Interface
my_system% cat example_uu.f
      program example_uu
c
c    It factors and solves an unsymmetric system.
c
      implicit none
      integer           colstr(6), rowind(10)
      double precision  values(10), rhs(5), xexpct(5)
      integer           i
c
c  Sparse matrix structure and value arrays.  Unsummetric matrix A.
c
c      1.0   0.0   0.0   0.0   0.0       1.0        1.0
c      2.0   6.0   0.0   0.0   9.0       2.0       59.0
c  A = 3.0   0.0   7.0   0.0   0.0   x = 3.0   b = 24.0
c      4.0   0.0   0.0   8.0   0.0       4.0       36.0
c      5.0   0.0   0.0   0.0  10.0       5.0       55.0
c
      data colstr / 1, 6, 7, 8, 9, 11 /
      data rowind / 1, 2, 3, 4, 5, 2, 3, 4, 2, 5 /
     &              8.0d0, 9.0d0, 10.0d0 /
      data rhs    / 1.0d0, 59.0d0, 24.0d0, 36.0d0, 55.0d0 /
      data xexpct / 1.0d0, 2.0d0, 3.0d0, 4.0d0, 5.0d0 /
c
c  initialize solver
c
      mtxtyp= 'uu'
      pivot = 'n'
      neqns  = 5
      outunt = 6
      msglvl = 3
c
c
      ordmthd = 'mmd'
c
c
c
c  solution
c
      nrhs   = 1
      ldrhs  = 5
c
c
c
c
      do i = 1, neqns
      enddo
      stop
  110 continue
c
c
      write ( 6 , 400 )
      stop
  200 format(a5,3a20)
      end
my_system% f95 -dalign example_uu.f -library=sunperf
my_system% a.out
    5  0.500000000000D+01  0.500000000000D+01  0.000000000000D+00
Example 5  Calling SPSOLVE Routines from C
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include <sys/time.h>
#include <sunperf.h>
int main() {
 is a general unsymmetric sparse matrix.
     1.0  0.0  7.0   9.0   0.0        1.0           17.0
     2.0  4.0  0.0   0.0   0.0        1.0            6.0
 A = 0.0  5.0  8.0   0.0   0.0    x = 1.0       b = 13.0
     0.0  0.0  0.0  10.0  11.0        1.0           21.0
     3.0  6.0  0.0   0.0  12.0        1.0           21.0
/* Array indices must be one-based for calling SPSOLVE routines */
int colstr[]    = {1, 4, 7, 9, 11, 13};
int rowind[]    = {1, 2, 5, 2, 3, 5, 1, 3, 1, 4, 4, 5};
double values[] = {1.0, 2.0, 3.0, 4.0, 5.0, 6.0,
                   7.0, 8.0, 9.0, 10.0, 11.0, 12.0};
double rhs[]    = {17.0, 6.0, 13.0, 21.0, 21.0};
double xexpct[] = {1.0, 1.0, 1.0, 1.0, 1.0};
    int n = 5, nnz = 12, nrhs = 1, msglvl = 0, outunt = 6, ierr,
          i,j,k, int_ierr;
    double t[4], handle[150];
    char type[] = "uu", piv = 'n';
/* Last two parameters in argument list indicate lengths of
 * character arguments type and piv
    dgssin_(type, &piv, &n, colstr, rowind, &outunt, &msglvl,
               handle, &ierr,2,1);
    if (ierr != 0) {
      int_ierr = ierr;
      printf("dgssin err = %d\n", int_ierr);
      return -1;
    char ordmth[] = "mmd";
    dgssor_(ordmth, handle, &ierr, 3);
    if (ierr != 0) {
      int_ierr = ierr;
      printf("dgssor err = %d\n", int_ierr);
      return -1;
    dgssfa_(&n, colstr, rowind, values, handle, &ierr);
    if (ierr != 0) {
      int_ierr = ierr;
      printf("dgssfa err = %d\n", int_ierr);
      return -1;
    dgsssl_(&nrhs, rhs, &n, handle, &ierr);
    if (ierr != 0) {
      int_ierr = ierr;
      printf("dgsssl err = %d\n", int_ierr);
      return -1;
    printf("i   computed solution      expected solution\n");
    for (i=0; i<n; i++)
      printf("%d         %lf            %lf\n", i,rhs[i], 1.0);
my_system%  cc -m32 -xmemalign=8s dr.c -library=sunperf
my_system%  ./a.out
0         1.000000            1.000000
1         1.000000            1.000000
2         1.000000            1.000000
3         1.000000            1.000000
4         1.000000            1.000000
