Go to main content
Oracle® Developer Studio 12.5: Performance Library User's Guide
Exit Print View
Updated: June 2016
Forward and Inverse FFT Routines
The following tables list the names of the FFT routines and their calling sequence. Double precision routine names are in square brackets. See the individual man pages for detailed information on the data type and size of the arguments.
Table 9  FFT Linear Routines and Their Arguments
Routine Name
Arguments
CFFTS [ZFFTD]
(OPT, N1, SCALE, X, Y, TRIGS, IFAC, WORK, LWORK, ERR)
SFFTC [DFFTZ]
CFFTSM [ZFFTDM]
(OPT, N1, N2, SCALE, X, LDX1, Y, LDY1, TRIGS, IFAC, WORK, LWORK, ERR)
SFFTCM [DFFTZM]
CFFTC [ZFFTZ]
CFFTCM [ZFFTZM]
Table 10  FFT Two-Dimensional Routines and Their Arguments
Routine Name
Arguments
CFFTS2 [ZFFTD2]
SFFTC2 [DFFTZ2]
CFFTC2 [ZFFTZ2]
Table 11  FFT Three-Dimensional Routines and Their Arguments
Routine Name
Arguments
CFFTS3 [ZFFTD3]
(OPT, N1, N2, N3, SCALE, X, LDX1, LDX2, Y, LDY1, LDY2, TRIGS, IFAC, WORK, LWORK, ERR)
SFFTC3 [DFFTZ3]
CFFTC3 [ZFFTZ3]
Oracle Developer Studio Performance Library FFT routines use the following arguments.
  • OPT: Flag indicating whether the routine is called to initialize or to compute the transform.
  • N1, N2, N3: Problem dimensions for one, two, and three dimensional transforms.
  • X: Input array where X is of type COMPLEX if the routine is a complex-to-complex transform or a complex-to-real transform. X is of type REAL for a real-to-complex transform.
  • Y: Output array where Y is of type COMPLEX if the routine is a complex-to-complex transform or a real-to-complex transform. Y is of type REAL for a complex-to-real transform.
  • LDX1, LDX2 and LDY1, LDY2: LDX1 and LDX2 are the leading dimensions of the input array, and LDY1 and LDY2 are the leading dimensions of the output array. The FFT routines allow the output to overwrite the input, which is an in-place transform, or to be stored in a separate array apart from the input array, which is an out‐of‐place transform. In complex-to-complex transforms, the input data is of the same size as the output data. However, real-to-complex and complex-to-real transforms have different memory requirements for input and output data. Care must be taken to ensure that the input array is large enough to accommodate the transform results when computing an in-place transform.
  • TRIGS: Array containing the trigonometric weights.
  • IFAC: Array containing factors of the problem dimensions. The problem sizes are as follows:
    • Linear FFT: Problem size of dimension N1
    • Two-dimensional FFT: Problem size of dimensions N1 and N2
    • Three-dimensional FFT: Problem size of dimensions N1, N2, and N3
    While N1, N2, and N3 can be of any size, a real-to-complex or a complex-to-real transform can be computed most efficiently when
    image:N1, N2, N3 = 2^p times 3^q times 4^r times 5^s ,
    and a complex-to-complex transform can be computed most efficiently when
    image:N1, N2, N3 = 2^p times 3^q times 4^r times 5^s times 7^t times                                 11^u times 13^v ,
    where p, q, r, s, t, u, and v are integers and p, q, r, s, t, u, v ≥ 0.
  • WORK: Workspace whose size depends on the routine and the number of threads that are being used to compute the transform if the routine is parallelized.
  • LWORK: Size of workspace. If LWORK is zero, the routine will allocate a workspace with the required size.
  • SCALE: A scalar with which the output is scaled. Occasionally in literature, the inverse transform is defined with a scaling factor of 1/N1 for one-dimensional transforms, 1/(N1 × N2) for two-dimensional transforms, and 1/(N1 × N2 × N3) for three-dimensional transforms. In such case, the inverse transform is said to be normalized. If a normalized FFT is followed by its inverse FFT, the result is the original input data. The Oracle Developer Studio Performance Library FFT routines are not normalized. However, normalization can be done easily by calling the inverse FFT routine with the appropriate scaling factor stored in SCALE.
  • ERR: A flag returning a nonzero value if an error is encountered in the routine and zero otherwise.
Linear FFT Routines
Linear FFT routines compute the FFT of real or complex data in one dimension only. The data can be one or more complex or real sequences. For a single sequence, the data is stored in a vector. If more than one sequence is being transformed, the sequences are stored column-wise in a two-dimensional array and a one-dimensional FFT is computed for each sequence along the column direction. The linear forward FFT routines compute: image:X(k) = sum to {N1 - 1} from {n = 0} x(n)e^{{-2%pi ink} over N1}                                 , k = 0, ..., N1 - 1, where image:i = the square root of -1 .
Or expressed in polar form: image:X(k) = sum to {N1 - 1} from {n = 0} x(n) left( cos left({2%pi                                 nk} over N1 right) -i sin left( {2%pi nk} over N1 right) right), k =                                 0, ...,N1 - 1 .
The inverse FFT routines compute image:x(n) = sum to {N1 - 1} from {k = 0} X(k)e^{{2%pi ink} over N1} , n                             = 0, ..., N1 - 1,
In polar form: image:x(n) = sum to {N1 - 1} from {n = 0} X(k) left( cos left({2%pi nk}                             over N1 right) + i sin left( {2%pi nk} over N1 right) right), k = 0,                             ...,N1 - 1
With the forward transform, if the input is one or more complex sequences of size N1, the result will be one or more complex sequences, each consisting of N1 unrelated data points. However, if the input is one or more real sequences, each containing N1 real data points, the result will be one or more complex sequences that are conjugate symmetric. That is:
image:x(n) = sum to {N1 - 1} from {n = 0} X(k) left( cos left({2%pi                                 nk} over N1 right) -i sin left( {2%pi nk} over N1 right) right), k =                                 0, ...,N1 - 1
The imaginary part of X(0) is always zero. If N1 is even, the imaginary part of image:X({N1 over 2}) is also zero. Both zeros are stored explicitly. Because the second half of each sequence can be derived from the first half, only image:(N1 over 2) + 1 complex data points are computed and stored in the output array. Here and elsewhere in this chapter, integer division is rounded down.
With the inverse transform, if an N1-point complex-to-complex transform is being computed, then N1 unrelated data points are expected in each input sequence and N1 data points will be returned in the output array. However, if an N1-point complex-to-real transform is being computed, only the first image:(N1 over 2) +  1 complex data points of each conjugate symmetric input sequence are expected in the input, and the routine will return N1 real data points in each output sequence.
For each value of N1, either the forward or the inverse routine must be called to compute the factors of N1 and the trigonometric weights associated with those factors before computing the actual FFT. The factors and trigonometric weights can be reused in subsequent transforms as long as N1 remains unchanged.
The following table Table 12 lists the single precision linear FFT routines and their purposes. For routines that have two-dimensional arrays as input and output, Table 12 also lists the leading dimension requirements. The same information applies to the corresponding double precision routines except that their data types are double precision and double complex. See Table 12 for the mapping. See the individual man pages for a complete description of the routines and their arguments.
Table 12  Single Precision Linear FFT Routines
Name
Purpose
Size and Type of Input
Size and Type of Output
Leading Dimension Requirements
SFFTC
OPT = 0 initialization
OPT = -1 real-to-complex forward linear FFT of a single vector
N1,
Real
image:N1 over 2 plus 1 ,
Complex
SFFTC
OPT = 1 complex-to-real inverse linear FFT of single vector
Complex
N1
Real
CFFTC
OPT = -1 complex-to-complex forward linear FFT of a single vector
N1,
Complex
N1,
Complex
OPT = 1 complex-to-complex inverse linear FFT of a single vector
N1,
Complex
N1,
Complex
SFFTCM
OPT = -1 real-to-complex forward linear FFT of M vectors
N1 × M,
Real
image:Open parens N1 over 2, plus 1 close parens                                                   times M ,
Complex
LDX1 = 2 × LDY1
LDX1N1
CFFTSM
OPT = 1 complex-to-real inverse linear FFT of M vectors
Complex
N1 × M,
Real
LDX1image:N1 over 2 plus 1
LDY1=2 × LDX1
LDY1N1
CFFTCM
OPT = -1 complex-to-complex forward linear FFT of M vectors
N1 × M,
Complex
N1 × M,
Complex
LDX1N1
LDY1N1
LDX1N1
LDY1N1
OPT = 1 complex-to-complex inverse linear FFT of M vectors
N1 × M,
Complex
N1 × M,
Complex
LDX1N1
LDY1N1
LDX1N1
LDY1N1
Note -  Note the following about the table Table 12:
  • LDX1 is the leading dimension of the input array.
  • LDY1 is the leading dimension of the output array.
  • N1 is the first dimension of the FFT problem.
  • N2 is the second dimension of the FFT problem.
  • When calling routines with OPT = 0 to initialize the routine, the only error checking that is done is to determine if N1 < 0
The following example shows how to compute the linear real-to-complex and complex-to-real FFT of a set of sequences.
Example 10  Linear Real-to-Complex FFT and Complex-to-Real FFT
my_system% cat testscm.f
       PROGRAM TESTSCM
       IMPLICIT NONE
       INTEGER :: LW, IERR, I, J, K, LDX, LDC
       INTEGER,PARAMETER :: N1 = 3, N2 = 2, LDZ = N1,
      $        LDC = N1, LDX = 2*LDC
       INTEGER, DIMENSION(:) :: IFAC(128)
       REAL :: SCALE
       REAL, PARAMETER :: ONE = 1.0
       REAL, DIMENSION(:) :: SW(N1), TRIGS(2*N1)
       REAL, DIMENSION(0:LDX-1,0:N2-1) :: X, V, Y
       COMPLEX, DIMENSION(0:LDZ-1, 0:N2-1) :: Z
* workspace size
       LW = N1
       SCALE = ONE/N1
       WRITE(*,*)
      $ 'Linear complex-to-real and real-to-complex FFT of a sequence'
       WRITE(*,*)
       X = RESHAPE(SOURCE = (/.1, .2, .3,0.0,0.0,0.0,7.,8.,9.,
      $    0.0, 0.0, 0.0/), SHAPE=(/6,2/))
       V = X
       WRITE(*,*) 'X = '
       DO I = 0,N1-1
         WRITE(*,'(2(F4.1,2x))') (X(I,J), J = 0, N2-1)
       END DO
       WRITE(*,*)
* intialize trig table and compute factors of N1
       CALL SFFTCM(0, N1, N2, ONE, X, LDX, Z, LDZ, TRIGS, IFAC,
      $ SW, LW, IERR)
       IF (IERR .NE. 0) THEN
          PRINT*,'ROUTINE RETURN WITH ERROR CODE = ', IERR
          STOP
       END IF
* Compute out-of-place forward linear FFT.
* Let FFT routine allocate memory.
       CALL SFFTCM(-1, N1, N2, ONE, X, LDX, Z, LDZ, TRIGS, IFAC,
      $            SW, 0, IERR)
        STOP
      END IF
      WRITE(*,*) 'out-of-place forward FFT of X:'
      WRITE(*,*)'Z ='
      DO I = 0, N1/2
         WRITE(*,'(2(A1, F4.1,A1,F4.1,A1,2x))') ('(',REAL(Z(I,J)),
     $ ',',AIMAG(Z(I,J)),')', J = 0, N2-1)
      END DO
      WRITE(*,*)
* Compute in-place forward linear FFT.
* X must be large enough to store N1/2+1 complex values
      CALL SFFTCM(-1, N1, N2, ONE, X, LDX, X, LDC, TRIGS, IFAC,
     $            SW, LW, IERR)
         STOP
      END IF
      WRITE(*,*) 'in-place forward FFT of X:'
      CALL PRINT_REAL_AS_COMPLEX(N1/2+1, N2, 1, X, LDC, N2)
      WRITE(*,*)
* Compute out-of-place inverse linear FFT.
      CALL CFFTSM(1, N1, N2, SCALE, Z, LDZ, X, LDX, TRIGS, IFAC,
     $            SW, LW, IERR)
         STOP
      END IF
      WRITE(*,*) 'out-of-place inverse FFT of Z:'
      DO I = 0, N1-1
         WRITE(*,'(2(F4.1,2X))') (X(I,J), J = 0, N2-1)
      END DO
      WRITE(*,*)
* Compute in-place inverse linear FFT.
      CALL CFFTSM(1, N1, N2, SCALE, Z, LDZ, Z, LDZ*2, TRIGS,
     $            IFAC, SW, 0, IERR)
         STOP
      END IF
      WRITE(*,*) 'in-place inverse FFT of Z:'
      CALL PRINT_COMPLEX_AS_REAL(N1, N2, 1, Z, LDZ*2, N2)
      WRITE(*,*)
      END PROGRAM TESTSCM
      SUBROUTINE PRINT_COMPLEX_AS_REAL(N1, N2, N3, A, LD1, LD2)
      INTEGER N1, N2, N3, I, J, K
      REAL A(LD1, LD2, *)
      DO K = 1, N3
         DO I = 1, N1
            WRITE(*,'(5(F4.1,2X))') (A(I,J,K), J = 1, N2)
         END DO
         WRITE(*,*)
      END DO
      END
      SUBROUTINE PRINT_REAL_AS_COMPLEX(N1, N2, N3, A, LD1, LD2)
      COMPLEX A(LD1, LD2, *)
      DO K = 1, N3
         DO I = 1, N1
            WRITE(*,'(5(A1, F4.1,A1,F4.1,A1,2X))') ('(',REAL(A(I,J,K)),
     $            ',',AIMAG(A(I,J,K)),')', J = 1, N2)
         END DO
         WRITE(*,*)
      END DO
      END
my_system% f95 -dalign testscm.f -xlibrary=sunperf
my_system% a.out
X =
0.1 7.0
0.2 8.0
0.3 9.0
Z =
( 0.6, 0.0) (24.0, 0.0)
(-0.2, 0.1) (-1.5, 0.9)
0.1 7.0
0.2 8.0
0.3 9.0
0.1 7.0
0.2 8.0
0.3 9.0
Example 7-1 Notes:
The forward FFT of X is actually:
( 0.6, 0.0) (24.0, 0.0) Z = (-0.2, 0.1) (-1.5, 0.9) (-0.2, 0.1) (-1.5, 0.9)
Because of symmetry, Z(2) is the complex conjugate of Z(1), and therefore only the first two image:(N1 over 2) plus 1 equals 2 complex values are stored. For the in-place forward transform, SFFTCM is called with real array X as the input and output. Because SFFTCM expects the output array to be of type COMPLEX, the leading dimension of X as an output array must be as if X were complex. Since the leading dimension of real array X is LDX = 2 × LDC, the leading dimension of X as a complex output array must be LDC. Similarly, in the in-place inverse transform, CFFTSM is called with complex array Z as the input and output. Because CFFTSM expects the output array to be of type REAL, the leading dimension of Z as an output array must be as if Z were real. Since the leading dimension of complex array Z is LDZ, the leading dimension of Z as a real output array must be LDZ × 2.
The following example Example 11 shows how to compute the linear complex-to-complex FFT of a set of sequences.
Example 11  Linear Complex-to-Complex FFT
my_system% cat testccm.f
       PROGRAM TESTCCM
       IMPLICIT NONE
       INTEGER :: LDX1, LDY1, LW, IERR, I, J, K, LDZ1, NCPUS,
      $           USING_THREADS, IFAC(128)
       INTEGER, PARAMETER :: N1 = 3, N2 = 4, LDX1 = N1, LDZ1 = N1,
      $                      LDY1 = N1+2
       REAL, PARAMETER :: ONE = 1.0, SCALE = ONE/N1
       COMPLEX :: Z(0:LDZ1-1,0:N2-1), X(0:LDX1-1,0:N2-1),
      $           Y(0:LDY1-1,0:N2-1)
       REAL :: TRIGS(2*N1)
       REAL, DIMENSION(:), ALLOCATABLE :: SW
* get number of threads
       NCPUS = USING_THREADS()
* workspace size
       LW = 2 * N1 * NCPUS
       WRITE(*,*)'Linear complex-to-complex FFT of one or more sequences'
       WRITE(*,*)
       ALLOCATE(SW(LW))
       X = RESHAPE(SOURCE =(/(.1,.2),(.3,.4),(.5,.6),(.7,.8),(.9,1.0),
      $ (1.1,1.2),(1.3,1.4),(1.5,1.6),(1.7,1.8),(1.9,2.0),(2.1,2.2),
      $ (1.2,2.0)/), SHAPE=(/LDX1,N2/))
       Z = X
       WRITE(*,*) 'X = '
       DO I = 0, N1-1
          WRITE(*,'(5(A1, F5.1,A1,F5.1,A1,2X))') ('(',REAL(X(I,J)),
      $           ',',AIMAG(X(I,J)),')', J = 0, N2-1)
       END DO
       WRITE(*,*)* intialize trig table and compute factors of N1
       CALL CFFTCM(0, N1, N2, SCALE, X, LDX1, Y, LDY1, TRIGS, IFAC,
      $            SW, LW, IERR)
         STOP
       END IF
       CALL CFFTCM(-1, N1, N2, ONE, X, LDX1, Y, LDY1, TRIGS, IFAC,
      $            SW, 0, IERR)
          STOP
       END IF
* Compute in-place forward linear FFT. LDZ1 must equal LDX1
       CALL CFFTCM(-1, N1, N2, ONE, Z, LDX1, Z, LDZ1, TRIGS,
       DO I = 0, N1-1
          WRITE(*,'(5(A1, F5.1,A1,F5.1,A1,2X))') ('(',REAL(Z(I,J)),
       END DO
       WRITE(*,*)
       WRITE(*,*) 'Y ='
       DO I = 0, N1-1
          WRITE(*,'(5(A1, F5.1,A1,F5.1,A1,2X))') ('(',REAL(Y(I,J)),
      $        ',',AIMAG(Y(I,J)),')', J = 0, N2-1)
       END DO
       WRITE(*,*)
       CALL CFFTCM(1, N1, N2, SCALE, Y, LDY1, Y, LDY1, TRIGS, IFAC,
      $            SW, LW, IERR)
          STOP
       END IF
       WRITE(*,*) 'in-place inverse FFT of Y:'
       WRITE(*,*) 'Y ='
       DO I = 0, N1-1
       END DO
       DEALLOCATE(SW)
       END PROGRAM TESTCCM
my_system% f95 -dalign testccm.f -library=sunperf
my_system% a.out
X =
( 0.1, 0.2) ( 0.7, 0.8) ( 1.3, 1.4) ( 1.9, 2.0)
( 0.3, 0.4) ( 0.9, 1.0) ( 1.5, 1.6) ( 2.1, 2.2)
( 0.5, 0.6) ( 1.1, 1.2) ( 1.7, 1.8) ( 1.2, 2.0)
(  0.9,  1.2) (  2.7,  3.0) (  4.5,  4.8) ( 5.2,  6.2)
( -0.5, -0.1) ( -0.5, -0.1) ( -0.5, -0.1) ( 0.4, -0.9)
( -0.1, -0.5) ( -0.1, -0.5) ( -0.1, -0.5) ( 0.1,  0.7)
Y =
Y =
Two-Dimensional FFT Routines
For the linear FFT routines, when the input is a two-dimensional array, the FFT is computed along one dimension only, namely, along the columns of the array. The two-dimensional FFT routines take a two-dimensional array as input and compute the FFT along both the column and row dimensions. Specifically, the forward two-dimensional FFT routines compute the following:
image:X(k,n) = sum to {N2 - 1} from {l = 0} sum to {N1 - 1} from {j =                                 0} x(j,l)e^{{-2%pi iln} over N2} e^{{-2%pi ijk} over N1} ,~ k = 0,                                 ..., N1 - 1, n = 0, ...,N2 - 1
The inverse two-dimensional FFT routines compute the following:
image:x(j,l) = sum to {N2 - 1} from {n = 0} sum to {N1 - 1} from {k = 0}                             X(k,n)e^{{2%pi iln} over N2} e^{{2%pi ijk} over N1} ,~ j = 0, ..., N1 -                             1, l = 0, ...,N2 - 1
For both the forward and inverse two-dimensional transforms, a complex-to-complex transform where the input problem is N1 × N2 will yield a complex array that is also N1 × N2.
When computing a real-to-complex two-dimensional transform (forward FFT), if the real input array is of dimensions N1 × N2, the result will be a complex array of dimensions image:((N1 over 2) + 1 ) times N2 .
Conversely, when computing a complex-to-real transform (inverse FFT) of dimensions N1 × N2, an image:((N1 over 2) + 1 ) times N2 complex array is required as input. As with the real-to-complex and complex-to-real linear FFT, because of conjugate symmetry, only the first image:N1 over 2 plus 1 complex data points need to be stored in the input or output array along the first dimension. The complex subarray image:X ((N1 over 2) + 1 ) : N1-1,:) can be obtained from image:X (0:{N1 over 2}, :) as follows:
image:X(k,n)=X * (N1 - k,n),{}newline{}k={N1 over 2} + 1,...,N1 - 1                             {}newline{}n= 0,...,N2 - 1
To compute a two-dimensional transform, an FFT routine must be called twice. One call initializes the routine and the second call actually computes the transform. The initialization includes computing the factors of N1 and N2 and the trigonometric weights associated with those factors. In subsequent forward or inverse transforms, initialization is not necessary as long as N1 and N2 remain unchanged.
IMPORTANT: Upon returning from a two-dimensional FFT routine, Y(0 : N - 1, :) contains the transform results and the original contents of Y(N : LDY-1, :) is overwritten. Here, N = N1 in the complex-to-complex and complex-to-real transforms and N = image:N1 over 2 plus 1 in the real-to-complex transform.
The following table Table 13 lists the single precision two-dimensional FFT routines and their purposes. The same information applies to the corresponding double precision routines except that their data types are double precision and double complex. See Table 13 for the mapping. Refer to the individual man pages for a complete description of the routines and their arguments.
Table 13  Single Precision Two-Dimensional FFT Routines
Name
Purpose
Size, Type of Input
Size, Type of Output
SFFTC2
OPT = -1 real-to-complex forward two-dimensional FFT
N1 × N2, Real
image:( N1 over 2) plus 1) times N2 ,
Complex
LDX1 = 2 × LDY1
LDY1image:( N1 over 2) + 1
LDX1N1
CFFTS2
OPT = 1 complex-to-real inverse two-dimensional FFT
image:((N1 over 2)+1) times N2 ,
Complex
N1 × N2, Real
LDX1image:(N1 over 2)+1
LDY1=2 × LDX1
LDY1≥ 2 × LDX1
LDY1 is even
CFFTC2
OPT = -1 complex-to-complex forward two-dimensional FFT
N1 × N2, Complex
N1 × N2, Complex
LDX1N1
LDY1 = LDX1
LDX1N1
LDY1N1
OPT = 1 complex-to-complex inverse two-dimensional FFT
N1 × N2, Complex
N1 × N2, Complex
LDX1N1
LDY1 = LDX1
LDX1N1
LDY1 = LDX1
Note -  Note the following about the table Table 13
  • LDX1 is leading dimension of input array.
  • LDY1 is leading dimension of output array.
  • N1 is first dimension of the FFT problem.
  • N2 is second dimension of the FFT problem.
  • When calling routines with OPT = 0 to initialize the routine, the only error checking that is done is to determine if N1, N2 < 0.
Example 12  Two-Dimensional Real-to-Complex FFT and Complex-to-Real FFT of a Two-Dimensional Array
The following example shows how to compute a two-dimensional real-to-complex FFT and complex-to-real FFT of a two-dimensional array.
my_system% cat testsc2.f
       PROGRAM TESTSC2
       IMPLICIT NONE
      $         LDY1 = N1/2+1, LDR1 = 2*(N1/2+1)
       INTEGER LW, IERR, I, J, K, IFAC(128*2)
       REAL, PARAMETER :: ONE = 1.0, SCALE = ONE/(N1*N2)
       REAL :: V(LDR1,N2), X(LDX1, N2), Z(LDR1,N2),
      $        SW(2*N2), TRIGS(2*(N1+N2))
       COMPLEX :: Y(LDY1,N2)
       WRITE(*,*) $'Two-dimensional complex-to-real and real-to-complex FFT'
       WRITE(*,*)
       X = RESHAPE(SOURCE = (/.1, .2, .3, .4, .5, .6, .7, .8,
      $            2.0,1.0, 1.1, 1.2/), SHAPE=(/LDX1,N2/))
       DO I = 1, N2
          V(1:N1,I) = X(1:N1,I)
       END DO
       WRITE(*,*) 'X ='
       DO I = 1, N1
          WRITE(*,'(5(F5.1,2X))') (X(I,J), J = 1, N2)
       END DO
       WRITE(*,*)
* Initialize trig table and get factors of N1, N2
       CALL SFFTC2(0,N1,N2,ONE,X,LDX1,Y,LDY1,TRIGS,
      $            IFAC,SW,0,IERR)
* Compute 2-dimensional out-of-place forward FFT.
* cannot do an in-place transform in X because LDX1 < 2*(N1/2+1)
       CALL SFFTC2(-1,N1,N2,ONE,X,LDX1,Y,LDY1,TRIGS,
      $            IFAC,SW,0,IERR)
       WRITE(*,*)'Y ='
       DO I = 1, N1/2+1
          WRITE(*,'(5(A1, F5.1,A1,F5.1,A1,2X))')('(',REAL(Y(I,J)),
      $           ',',AIMAG(Y(I,J)),')', J = 1, N2)
       END DO
       WRITE(*,*)
* Compute 2-dimensional in-place forward FFT.
* Use workspace already allocated.
* V which is real array containing input data is also
* used to store complex results; as a complex array, its first
* leading dimension is LDR1/2.
       CALL SFFTC2(-1,N1,N2,ONE,V,LDR1,V,LDR1/2,TRIGS,
      $            IFAC,SW,LW,IERR)
       CALL PRINT_REAL_AS_COMPLEX(N1/2+1, N2, 1, V, LDR1/2, N2)
* Compute 2-dimensional out-of-place inverse FFT.
* Leading dimension of Z must be even
       CALL CFFTS2(1,N1,N2,SCALE,Y,LDY1,Z,LDR1,TRIGS,
      $            IFAC,SW,0,IERR)
       WRITE(*,*) 'out-of-place inverse FFT of Y:'
       DO I = 1, N1
          WRITE(*,'(5(F5.1,2X))') (Z(I,J), J = 1, N2)
       END DO
       WRITE(*,*)
* Compute 2-dimensional in-place inverse FFT.
* Y which is complex array containing input data is also
* used to store real results; as a real array, its first
* leading dimension is 2*LDY1.
       CALL CFFTS2(1,N1,N2,SCALE,Y,LDY1,Y,2*LDY1,
      $            TRIGS,IFAC,SW,0,IERR)
       CALL PRINT_COMPLEX_AS_REAL(N1, N2, 1, Y, 2*LDY1, N2)
       END PROGRAM TESTSC2
       REAL A(LD1, LD2, *)
       DO K = 1, N3
          DO I = 1, N1
             WRITE(*,'(5(F5.1,2X))') (A(I,J,K), J = 1, N2)
          END DO
          WRITE(*,*)
       END DO
       END
       DO K = 1, N3
          DO I = 1, N1
             WRITE(*,'(5(A1, F5.1,A1,F5.1,A1,2X))') ('(',REAL(A(I,J,K)),
          END DO
          WRITE(*,*)
       END DO
       END
my_system% f95 -dalign testsc2.f -library=sunperf
my_system% a.out
x =
0.1 0.4 0.7 1.0
0.2 0.5 0.8 1.1
0.3 0.6 2.0 1.2
Y =
(  8.9, 0.0) ( -2.9,  1.8) ( -0.7, 0.0) ( -2.9, -1.8)
( -1.2, 1.3) (  0.5, -1.0) ( -0.5, 1.0) (  0.5, -1.0)
0.1 0.4 0.7 1.0
0.2 0.5 0.8 1.1
0.3 0.6 2.0 1.2
0.1 0.4 0.7 1.0
0.2 0.5 0.8 1.1
0.3 0.6 2.0 1.2
Three-Dimensional FFT Routines
Oracle Developer Studio Performance Library includes routines that compute three-dimensional FFT. In this case, the FFT is computed along all three dimensions of a three-dimensional array. The forward FFT computes
image:X(k,n,m) = sum to {N3 - 1} from {h = 0} sum to {N2 - 1} from {l =                             0} sum to {N1 - 1} from {j = 0} x(j,l,h) times e^{{-2%pi ihm} over N3}                             times e^((-2%pi iln) over N2) times e^((-2%pi ijk) over N1) ,{}newline{}                             k=0,...,N1 - 1 {}newline{} n=0,...,N2 - 1 {}newline{} m=0,...,N3                             -1 ,
and the inverse FFT computes
image:x(j,l,h) = sum to {N3 - 1} from {m = 0} sum to {N2 - 1} from {n =                             0} sum to {N1 - 1} from {k = 0} X(k,n,m) times e^((2%pi ihm) over N3)                             times e^((2%pi iln) over N2) times e^((2%pi ijk) over N1} ,{}newline{}                             j=0,...,N1 - 1 {}newline{} l=0,~...,N2 - 1 {}newline{} h=0,...,N3 -1
In the complex-to-complex transform, if the input problem is N1 × N2 × N3, a three-dimensional transform will yield a complex array that is also N1 × N2 × N3. When computing a real-to-complex three-dimensional transform, if the real input array is of dimensions N1 × N2 × N3, the result will be a complex array of dimensions image:(N1 over 2) + 1) times N2 times N3 . Conversely, when computing a complex-to-real FFT of dimensions N1 × N2 × N3, an image:(N1 over 2) + 1) times N2 times N3 complex array is required as input. As with the real-to-complex and complex-to-real linear FFT, because of conjugate symmetry, only the first image:(N1 over 2) + 1 complex data points need to be stored along the first dimension. The complex subarray image:X(N1 over 2) + 1: N1-1, :, :) can be obtained from image:X(0:(N1 over 2) + 1, :,  :) as follows:
image:X(k,n,m)=X * (N1 - k,n,m),{}newline{}k=~{N1 over 2} + 1,...,N1 - 1                         {}newline{}n= 0,~...,N2 - 1 {}newline{}m=0,...,N3 - 1
To compute a three-dimensional transform, an FFT routine must be called twice: Once to initialize and once more to actually compute the transform. The initialization includes computing the factors of N1, N2, and N3 and the trigonometric weights associated with those factors. In subsequent forward or inverse transforms, initialization is not necessary as long as N1, N2, and N3 remain unchanged.
IMPORTANT: Upon returning from a three-dimensional FFT routine, Y(0 : N - 1, :, :) contains the transform results and the original contents of Y(N:LDY1-1, :, :) is overwritten. Here, N=N1 in the complex-to-complex and complex-to-real transforms and N= image:N1 over 2 plus 1 in the real-to-complex transform.
Table 14 lists the single precision three-dimensional FFT routines and their purposes. The same information applies to the corresponding double precision routines except that their data types are double precision and double complex. See Table 14 for the mapping. See the individual man pages for a complete description of the routines and their arguments.
Table 14  Single Precision Three-Dimensional FFT Routines
Name
Purpose
Size, Type of Input
SFFTC3
OPT = -1 real-to-complex forward three-dimensional FFT
N1 × N2 × N3, Real
image:(N1 over 2) + 1) times N2 times                                                   N3 ,Complex
LDX1=2 × LDY1
LDX2N2
LDY1image:N1 over 2 plus 1
LDY2 = LDX2
LDX1N1
LDX2N2
LDY2N2
CFFTS3
OPT = 1 complex-to-real inverse three-dimensional FFT
image:((N1 over 2)+1) x N2 x N3 , Complex
N1 × N2 × N3, Real
LDX2N2
LDY1=2 × LDX1
LDY2=LDX2
LDX2N2
LDY1 ≥ 2 × LDX1
LDY1 is even
LDY2N2
CFFTC3
OPT = -1 complex-to-complex forward three-dimensional FFT
N1 × N2 × N3, Complex
LDX1N1
LDX2N2
LDY1=LDX1
LDY2=LDX2
LDX1N1
LDX2N2
LDY1N1
LDY2N2
OPT = 1 complex-to-complex inverse three-dimensional FFT
LDX1N1
LDX2N2
LDY1=LDX1
LDY2=LDX2
LDX1N1
LDX2N2
LDY1N1
LDY2N2
Note -  Note the following about the table Table 14:
  • LDX1 is first leading dimension of input array.
  • LDX2 is the second leading dimension of the input array.
  • LDY1 is the first leading dimension of the output array.
  • LDY2 is the second leading dimension of the output array.
  • N3 is the third dimension of the FFT problem.
  • When calling routines with OPT = 0 to initialize the routine, the only error checking that is done is to determine if N1, N2, N3 < 0.
Example 7-4 shows how to compute the three-dimensional real-to-complex FFT and complex-to-real FFT of a three-dimensional array.
Example 13  Three-Dimensional Real-to-Complex FFT and Complex-to-Real FFT of a Three-Dimensional Array
my_system% cat testsc3.f
       PROGRAM TESTSC3
       IMPLICIT NONE
       INTEGER LW, NCPUS, IERR, I, J, K, USING_THREADS, IFAC(128*3)
       INTEGER, PARAMETER :: N1 = 3, N2 = 4, N3 = 2, LDX1 = N1,
      $                      LDX2 = N2, LDY1 = N1/2+1, LDY2 = N2,
      $                      LDR1 = 2*(N1/2+1), LDR2 = N2
       REAL, PARAMETER :: ONE = 1.0, SCALE = ONE/(N1*N2*N3)
       REAL :: V(LDR1,LDR2,N3), X(LDX1,LDX2,N3), Z(LDR1,LDR2,N3),
      $        TRIGS(2*(N1+N2+N3))
       COMPLEX :: Y(LDY1,LDY2,N3)
       WRITE(*,*)
      $'Three-dimensional complex-to-real and real-to-complex FFT'
       WRITE(*,*)
* compute workspace size required
       LW = (MAX(MAX(N1,2*N2),2*N3) + 16*N3) * NCPUS
       ALLOCATE(SW(LW))
      $    (/ .1, .2, .3, .4, .5, .6, .7, .8, .9,1.0,1.1,1.2,
      $     4.1,1.2,2.3,3.4,6.5,1.6,2.7,4.8,7.9,1.0,3.1,2.2/),
      $     SHAPE=(/LDX1,LDX2,N3/))
       V = RESHAPE(SOURCE =
      $    (/.1,.2,.3,0.,.4,.5,.6,0.,.7,.8,.9,0.,1.0,1.1,1.2,0.,
      $     4.1,1.2,2.3,0.,3.4,6.5,1.6,0.,2.7,4.8,7.9,0.,
      $     1.0,3.1,2.2,0./), SHAPE=(/LDR1,LDR2,N3/))
       WRITE(*,*) 'X ='
       DO K = 1, N3
          DO I = 1, N1
             WRITE(*,'(5(F5.1,2X))') (X(I,J,K), J = 1, N2)
          END DO
          WRITE(*,*)
       END DO
* Initialize trig table and get factors of N1, N2 and N3
       CALL SFFTC3(0,N1,N2,N3,ONE,X,LDX1,LDX2,Y,LDY1,LDY2,TRIGS,
      $            IFAC,SW,0,IERR)
* Compute 3-dimensional out-of-place forward FFT.
* cannot do an in-place transform because LDX1 < 2*(N1/2+1)
       CALL SFFTC3(-1,N1,N2,N3,ONE,X,LDX1,LDX2,Y,LDY1,LDY2,TRIGS,
      $            IFAC,SW,0,IERR)
       WRITE(*,*)'Y ='
       DO K = 1, N3
          DO I = 1, N1/2+1
             WRITE(*,'(5(A1, F5.1,A1,F5.1,A1,2X))')('(',REAL(Y(I,J,K)),
      $              ',',AIMAG(Y(I,J,K)),')', J = 1, N2)
          END DO
          WRITE(*,*)
       END DO
* Compute 3-dimensional in-place forward FFT.
       CALL SFFTC3(-1,N1,N2,N3,ONE,V,LDR1,LDR2,V,LDR1/2,LDR2,TRIGS,
      $            IFAC,SW,LW,IERR)
       CALL PRINT_REAL_AS_COMPLEX(N1/2+1, N2, N3, V, LDR1/2, LDR2)
* Compute 3-dimensional out-of-place inverse FFT.
* First leading dimension of Z (LDR1) must be even
       CALL CFFTS3(1,N1,N2,N3,SCALE,Y,LDY1,LDY2,Z,LDR1,LDR2,TRIGS,
      $            IFAC,SW,0,IERR)
       DO K = 1, N3
         DO I = 1, N1
            WRITE(*,'(5(F5.1,2X))') (Z(I,J,K), J = 1, N2)
         END DO
         WRITE(*,*)
       END DO
* Compute 3-dimensional in-place inverse FFT.
       CALL CFFTS3(1,N1,N2,N3,SCALE,Y,LDY1,LDY2,Y,2*LDY1,LDY2,
      $            TRIGS,IFAC,SW,LW,IERR)
       CALL PRINT_COMPLEX_AS_REAL(N1, N2, N3, Y, 2*LDY1, LDY2)
       DEALLOCATE(SW)
       END PROGRAM TESTSC3
       REAL A(LD1, LD2, *)
       DO K = 1, N3
          DO I = 1, N1
          END DO
          WRITE(*,*)
       END DO
       END
       COMPLEX A(LD1, LD2), *)
       DO K = 1, N3
          DO I = 1, N1
          END DO
          WRITE(*,*)
       END DO
       END
my_system% f95 -dalign testsc3.f -xlibrary=sunperf
my_system% a.out
X =
0.1 0.4 0.7 1.0
0.2 0.5 0.8 1.1
0.3 0.6 0.9 1.2
4.1 3.4 2.7 1.0
1.2 6.5 4.8 3.1
2.3 1.6 7.9 2.2
Y =
( 48.6, 0.0) ( -9.6, -3.4) ( 3.4, 0.0) ( -9.6, 3.4)
( -4.2, -1.0) ( 2.5, -2.7) ( 1.0, 8.7) ( 9.5, -0.7)
(-33.0, 0.0) (  6.0, 7.0) ( -7.0,  0.0) (  6.0, -7.0)
(  3.0, 1.7) ( -2.5, 2.7) ( -1.0, -8.7) ( -9.5,  0.7)
0.1 0.4 0.7 1.0
0.2 0.5 0.8 1.1
0.3 0.6 0.9 1.2
4.1 3.4 2.7 1.0
1.2 6.5 4.8 3.1
2.3 1.6 7.9 2.2
0.1 0.4 0.7 1.0
0.2 0.5 0.8 1.1
0.3 0.6 0.9 1.2
4.1 3.4 2.7 1.0
1.2 6.5 4.8 3.1
2.3 1.6 7.9 2.2
Comments
When doing an in-place real-to-complex or complex-to-real transform, care must be taken to ensure the size of the input array is large enough to hold the results. For example, if the input is of type complex stored in a complex array with first leading dimension N, then to use the same array to store the real results, its first leading dimension as a real output array would be 2 × N. Conversely, if the input is of type real stored in a real array with first leading dimension 2 × N, then to use the same array to store the complex results, its first leading dimension as a complex output array would be N. Leading dimension requirements for in-place and out-of-place transforms can be found in Table 12, Table 13, and Table 14.
In the linear and multi-dimensional FFT, the transform between real and complex data through a real-to-complex or complex-to-real transform can be confusing because N1 real data points correspond to image:N1 over 2 plus 1 complex data points. N1 real data points do map to N1 complex data points, but because there is conjugate symmetry in the complex data, only image:N1 over 2 plus 1 data points need to be stored as input in the complex-to-real transform and as output in the real-to-complex transform. In the multi-dimensional FFT, symmetry exists along all the dimensions, not just in the first. However, the two-dimensional and three-dimensional FFT routines store the complex data of the second and third dimensions in their entirety.
While the FFT routines accept any size of N1, N2 and N3, FFTs can be computed most efficiently when values of N1, N2 and N3 can be decomposed into relatively small primes. A real-to-complex or a complex-to-real transform can be computed most efficiently when
The function xFFTOPT can be used to determine the optimal sequence length, as shown in Example 14. Given an input sequence length, the function returns an optimal length that is closest in size to the original length.
Example 14   RFFTOPT Example
my_system% cat fft_ex01.f
      PROGRAM TEST
      INTEGER         N, N1, N2, N3, RFFTOPT
C
      N = 1024
      N1 = 1019
      N2 = 71
      N3 = 49
C
      PRINT *, 'N Original  N Suggested'
      PRINT '(I5, I12)', (N, RFFTOPT(N))
      PRINT '(I5, I12', (N1, RFFTOPT(N1))
      PRINT '(I5, I12)', (N2, RFFTOPT(N2))
      PRINT '(I5, I12)', (N3, RFFTOPT(N3))
      END
my_system% f95 -dalign fft_ex01.f -library=sunperf
my_system% a.out
 1024        1024
 1019        1024
   71          72
   49          49
