Siebel Database Upgrade Guide > Performing the Siebel Repository Merge >
Running the Siebel Postmerge Utilities
Environments: Development environment only.
Platforms: Windows, UNIX, IBM z/OS.
After the merge is completed successfully, run the postmerge utilities. These utilities make the following changes to user interface objects in the merged repository:
  • Convert certain flow-based form applets to grid-based.
  • Verify that new or customized screens, views, and applets from the Prior Customer Repository are configured correctly and can be accessed in the UI.
  • Revise multi-value group (MVG) applets so that they are shuttle-enabled.
  • If you selected Incorporate Custom Layout (ICL) during the repository merge, then the utilities list the UI objects that were affected.
  • Lists UI objects that have missing required fields.
If the postmerge utilities encounter a problem and exit before completing, then do the following, fix the problem in the merged repository, and then rerun the utilities.
To run the postmerge utilities
  1. If you are rerunning the postmerge utilities and want to save the existing log, then rename the log. The path to the log is as follows:
    SIEBEL_TOOLS_ROOT\reppatch\log\reputility.log
    If you do not rename the log, it will be overwritten.
  2. In Siebel Tools, from the Screens menu, choose Application Upgrader, and then Application Upgrade Object List.
  3. In the Application Upgrades list, select the record of the merge.
  4. In the Application Upgrades list, right-click and select Launch Post Merge Utility from the pop-up menu.
    A dialog box appears and displays the postmerge utilities log. When the utilities have finished, a message showing completion displays in the log.
    Do not launch more than one instance of the postmerge utilities.
Related Topics
About the Siebel Postmerge Utilities
About the Siebel Repository Merge
Siebel Incorporate Custom Layout Upgrade Option
Siebel Database Upgrade Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
