Siebel Database Upgrade Guide > Performing the Siebel Repository Merge >
Configuring Siebel Repository Objects to Inherit Upgrade Behavior
Environments: Development environment only.
You can link objects together so that one object inherits the upgrade behavior of another. You do this by specifying an upgrade ancestor for an object.
You can specify an upgrade ancestor for the following object types:
  • Applet
  • Business component
  • Integration object
  • Report
Before doing the repository merge, review new objects you have created and determine whether you want to specify an upgrade ancestor.
Specifying an Upgrade Ancestor
Use the following procedure to specify an upgrade ancestor.
To specify an upgrade ancestor
  1. Navigate to the object in Siebel Tools.
  2. Click in the Upgrade Ancestor field.
    A dialog box appears. It lists available upgrade ancestors.
  3. Select the desired upgrade ancestor and click Pick.
Viewing the Descendants or Copies of an Object
Use the following procedure to view the descendants or copies of an object.
To view the descendants or copies of an object
  1. Right-click the object.
  2. Select View descendants from the picklist.
    A dialog box appears and lists the descendants.
Related Topics
About the Siebel Repository Merge
About Inheriting Upgrade Behavior in a Siebel Upgrade
Siebel Database Upgrade Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
