Siebel Database Upgrade Guide > Performing the Siebel Repository Merge >
Generating Siebel Enterprise Integration Manager Temporary Columns
Environments: Development environment only.
Platforms: Windows, UNIX, IBM z/OS.
The repository merge process does not preserve Siebel Enterprise Integration Manager processing columns for custom mappings. You must generate the missing custom Siebel Enterprise Integration Manager processing columns again.
To generate Siebel Enterprise Integration Manager temporary columns
  1. In Siebel Tools, from the File menu, choose Open Repository, and then New Customer Repository.
  2. From the Tools menu, choose, Upgrade, and then Generate EIM Processing Columns.
    A dialog box displays.
  3. Click OK to generate Siebel Enterprise Integration Manager processing columns for custom mappings.
  4. In the Object Explorer window, choose New Customer Repository and verify that the Comment field shows UpgEimCol.
    This indicates that the Siebel Enterprise Integration Manager temporary columns were created successfully.
Related Topics
About the Siebel Repository Merge
Siebel Database Upgrade Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
