Oracle R Enterprise provides datastores that you can use to save Oracle R Enterprise proxy objects, as well as any R object, in an Oracle database. You can grant or revoke read privilege access to a datastore for one or more users. You can restore the saved objects in another R session. The objects in a datastore are also accessible to embedded R execution through both the R and the SQL interfaces.
This section describes the Oracle R Enterprise functions that you can use to create and manage datastores. The section contains the following topics:
