Go to main content
SPARC and Netra SPARC S7-2 Series Servers Administration Guide
Exit Print View
Updated: June 2017
Display the Firmware Versions
The /HOST property displays information about the firmware versions on the host. The output includes the overall system firmware version and the versions of firmware components, such as Oracle ILOM, OpenBoot, and POST.
Note -  You also can determine the versions of firmware in the server and of specific components, such as a drive controller, with the fwupdate command. The fwupdate command is provided in the Oracle Hardware Management Pack, which is included in Oracle Solaris 11.3. For information about using fwpudate, refer to the Oracle Server CLI Tools for Oracle Solaris 11.3 User's Guide.
  1. Display the current host property values.
    -> show /HOST
    Refer to the Oracle ILOM Administrator's Guide for Configuration and Maintenance Firmware Release 3.2.x in Oracle ILOM 3.2 Documentation Library for more information about the show /HOST command.
  2. Examine the output to find the version listed for the system firmware or firmware component you wanted.
Related Information
