Go to main content
SPARC and Netra SPARC S7-2 Series Servers Administration Guide
Exit Print View
Updated: June 2017
Change the Default Boot Device (OpenBoot)
Use this procedure to configure OpenBoot to boot from a specific device. This change is permanent but only takes effect after a reset.
  1. Obtain the ok prompt.
    See one of these tasks:
  2. Determine the name of the desired boot device.
    To see names of devices, type:
    ok devalias
  3. Configure the boot-device parameter with your desired boot device.
    ok setenv boot-device boot_device
    where boot_device is a valid device from which to boot.
  4. Reset the host.
    ok reset-all
Related Information
