Go to main content
SPARC and Netra SPARC S7-2 Series Servers Administration Guide
Exit Print View
Updated: June 2017
SP Network Address Options
You can access the SP on your server in multiple ways. Consider the following options and choose the access method that is best for your environment.
You can physically connect to the SP using a serial connection or a network connection. The network connection can be configured to use a static IP address or DHCP (the default). Optionally, the servers can use an in-band network connection to the SP, rather than the default out-of-band NET MGT port.
For more information on each option, refer to this documentation:
  • To use a serial connection to the SP, refer to the information about connecting a terminal or emulator to the SER MGT port in the installation guide for the server.
  • To assign a static IP address to the SP, refer to the information about assigning a static IP address to the NET MGT port in the installation guide for the server.
  • To use an in-band connection to the SP, see Oracle ILOM In-Band (Sideband) Management.
Related Information
