| Bookshelf Home | Contents | Index | PDF |    |
| Using Siebel Tools > Using Siebel Tools > Workspaces Administration > Canceling the Workspace Delivery ProcessBefore delivering a workspace, workspace administrators must change the status of that workspace to Submitted for Delivery to make it ready for the delivery process. After the status of the workspace is changed to Submitted for Delivery, it is a read-only workspace and end users or developers cannot perform any other repository changes on it until the merging process is completed. Any repository change to that workspace would make the delivery process fail. To cancel the workspace delivery process, avoid the delivery failures, and allow end users or developers to be able to make repository changes on the workspaces with the status of Submitted for Delivery, workspace administrators must revert the status of that workspace back to Checkpointed and Editable by using the Undo Submit for Delivery option under the Workspace menu or running the UndoSubmitForDelivery command from the Command Prompt window. NOTE: Only a workspace administrator who is also the owner of the MAIN workspace can cancel the workspace delivery process. If workspace users or workspace developers need to cancel their workspace delivery processes, they must submit the cancel requests to the workspace administrators. After the requests are approved, the workspace administrator will cancel the delivery processes as requested. To cancel the workspace delivery process using the Undo Submit for Delivery option
 To cancel the workspace delivery process using the Command Prompt window
 After the status of the workspace is reverted, end users and developers of that workspace must perform these steps before they can make any repository change on it: |
| Using Siebel Tools | Copyright © 2016, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
