This manual is designed to help you analyse the customer’s economic depenendecy by generating reports during the credit appraisal management process.
This manual is intended for the Customer Service Representatives (CSRs) and staff in charge of setting up new products in your bank.
The following are some of the acronyms and abbreviations you are likely to find in the manual:
Acronym | Description | ||
ELCM | Enterprise Limits and Collateral Management | ||
System/the system | Oracle FLEXCUBE system (unless otherwise specified). |
This manual is organized as follows:
Chapter | Description | ||
Chapter 1 | About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual | ||
Chapter 2 | Reports lists the possible reports that can be generated for the module. | ||
Chapter 3 | Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation. |
This User Manual may refer to all or some of the following icons.
Icons | Function | ||
Exit | |||
Add row | |||
Delete row | |||
Option List |
