How to print: Complete the Purchase Order Purge Selection Screen.
For more information: See the sample report in PDF format.
Contents: See Purchase Order Inquiry (MPOI) for descriptions of the information on this report.
Note: Information on the purchase order detail lines is included on the report only if you select Detail at the Purchase Order Purge Selection Screen.
Order Billing History Purge Report
How to print: Complete the Purge Order Billing History Screen.
Contents:
• cutoff date for purging selected at the Purge Order Billing History Screen
• total number of non-consolidated Order Billing History records purged
• total number of consolidated Order Billing History records purged
________________________________
Contents SCVs Reports XML Messages Glossary
Copyright © 2020, Oracle and/or its affiliates. All rights reserved.
Legal Notices
