46 Using Oracle Resource Manager for PDBs with SQL*Plus
You can use PL/SQL package procedures to administer Oracle Resource Manager (Resource Manager) to allocate resources to pluggable databases (PDBs) in a multitenant container database (CDB).
Before using Resource Manager for PDBs, meet the following requirements:
You understand how to configure and manage a CDB. See " Managing a Multitenant Environment" for information.
You understand how to use Oracle Resource Manager to allocate resources in a non-CDB. See "Managing Resources with Oracle Database Resource Manager" for information.
You can complete the tasks in this chapter using SQL*Plus or Oracle SQL Developer.
You can also administer the Resource Manager with the graphical user interface of Oracle Enterprise Manager Cloud Control (Cloud Control). For instructions about administering Resource Manager in a CDB with Cloud Control, see " Using Oracle Resource Manager for PDBs with Cloud Control" and the Cloud Control online help.
For simplicity, this chapter refers to PDBs, application roots, and application PDBs as “PDBs.”
- About Using Oracle Resource Manager with CDBs and PDBs
You can create CDB resource plans and PDB resource plans to manage resources for CDBs and PDBs. - Prerequisites for Using Resource Manager with a CDB
You must meet prerequisites before using Resource Manager with a CDB. - Creating a CDB Resource Plan for Individual PDBs
You use theDBMS_RESOURCE_MANAGER
package to create a CDB resource plan for individual PDBs and define the directives for the plan. - Creating a CDB Resource Plan with PDB Performance Profiles
package to create a CDB resource plan for PDB performance profiles and define the directives for the plan. Each PDB that uses a profile adopts the CDB resource plan for that profile. - Enabling and Disabling a CDB Resource Plan
A CDB resource plan manages the workloads for multiple PDBs that are contending for system and CDB resources. You can enable or disable a CDB resource plan. - Creating a PDB Resource Plan
You create a PDB resource plan in the same way that you create a resource plan for a non-CDB. You use procedures in theDBMS_RESOURCE_MANAGER
PL/SQL package to create the plan. - Enabling and Disabling a PDB Resource Plan
A PDB resource plan manages the workloads within a single PDB. You can enable or disable a PDB resource plan. - Maintaining Plans and Directives in a CDB
This section provides instructions for maintaining CDB resource plans, the default directive for PDBs, the autotask directive, and PDB resource plans. You perform maintenance tasks using theDBMS_RESOURCE_MANAGER
PL/SQL package. - Viewing Information About Plans and Directives in a CDB
You can view information about CDB resource plans, CDB resource plan directives, and predefined resource plans in a CDB. - Monitoring PDBs Managed by Oracle Database Resource Manager
A set of dynamic performance views enables you to monitor the results of your Oracle Database Resource Manager settings for PDBs.
Related Topics
Parent topic: Managing a Multitenant Environment
46.1 About Using Oracle Resource Manager with CDBs and PDBs
- About Managing Resources at the CDB Level and PDB Level
In a non-CDB, you can use Resource Manager to manage multiple workloads that are contending for system and database resources. However, in a CDB, you can have multiple workloads within multiple PDBs competing for system and CDB resources. - What Solutions Does Resource Manager Provide for a CDB?
Resource Manager can provide more efficient use of resources for a CDB. - CDB Resource Plans
In a CDB, PDBs might have different levels of priority. You can create CDB resource plans to distribute resources to different PDBs based on these priorities. - PDB Resource Plans
A CDB resource plan determines the amount of resources allocated to each PDB. A PDB resource plan determines how the resources allocated to a specific PDB are allocated to consumer groups within that PDB. - Background and Administrative Tasks and Consumer Groups
In a CDB, background and administrative tasks are mapped to the Resource Manager consumer groups that run them optimally. - Initialization Parameters That Control Memory for PDBs
Several initialization parameters can control the memory usage of a PDB. - Initialization Parameters That Limit I/O for PDBs
You can set theMAX_IOPS
initialization parameter and theMAX_MBPS
initialization parameter to limit the disk I/O generated by a PDB.
Parent topic: Using Oracle Resource Manager for PDBs with SQL*Plus
46.1.1 About Managing Resources at the CDB Level and PDB Level
In a CDB, Resource Manager can manage resources on two basic levels:
CDB level - Resource Manager can manage the workloads for multiple PDBs that are contending for system and CDB resources. You can specify how resources are allocated to PDBs, and you can limit the resource utilization of specific PDBs.
PDB level - Resource Manager can manage the workloads within each PDB.
Resource Manager allocates the resources in two steps:
It allocates a portion of the system's resources to each PDB.
In a specific PDB, it allocates a portion of system resources obtained in Step 1 to each session connected to the PDB.
All activity in the root is automatically managed by Resource Manager.
Parent topic: About Using Oracle Resource Manager with CDBs and PDBs
46.1.2 What Solutions Does Resource Manager Provide for a CDB?
When resource allocation decisions for a CDB are left to the operating system, you may encounter the following problems with workload management:
Inappropriate allocation of resources among PDBs
The operating system distributes resources equally among all active processes and cannot prioritize one task over another. Therefore, one or more PDBs might use an inordinate amount of the system resources, leaving the other PDBs starved for resources.
Inappropriate allocation of resources within a single PDB
One or more sessions connected to a single PDB might use an inordinate amount of the system resources, leaving other sessions connected to the same PDB starved for resources.
Inconsistent performance of PDBs
A single PDB might perform inconsistently when other PDBs are competing for more system resources or less system resources at various times.
Lack of resource usage data for PDBs
Resource usage data is critical for monitoring and tuning PDBs. It might be possible to use operating system monitoring tools to gather the resource usage data for a non-CDB if it is the only database running on the system. However, in a CDB, operating system monitoring tools are no longer as useful because there are multiple PDBs running on the system.
Resource Manager helps to overcome these problems by allowing the CDB more control over how hardware resources are allocated among the PDBs and within PDBs.
In a CDB with multiple PDBs, some PDBs typically are more important than others. The Resource Manager enables you to prioritize and limit the resource usage of specific PDBs.
With the Resource Manager, you can:
Specify that different PDBs should receive different shares of the system resources so that more resources are allocated to the more important PDBs
Limit the CPU usage of a particular PDB
Limit the number of parallel execution servers that a particular PDB can use
Limit the memory usage of a particular PDB
Specify the amount of memory guaranteed for a particular PDB
Specify the maximum amount of memory a particular PDB can use
Use PDB performance profiles for different sets of PDB
A performance profile for a set of PDBs can specify shares of system resources, CPU usage, and number of parallel execution servers. PDB performance profiles enable you to manage resources for large numbers of PDBs by specifying Resource Manager directives for profiles instead of individual PDBs.
Limit the resource usage of different sessions connected to a single PDB
Limit the I/O generated by specific PDBs
Monitor the resource usage of PDBs
46.1.3 CDB Resource Plans
- About CDB Resource Plans
A CDB resource plan allocates resources to its PDBs according to its set of resource plan directives (directives). - Shares for Allocating Resources to PDBs
To allocate resources among PDBs, you assign a share value to each PDB or to each PDB performance profile. A higher share value results in more guaranteed resources for a PDB or the PDBs that use the PDB performance profile. - Utilization Limits for PDBs
A utilization limit restrains the system resource usage of a specific PDB or a specific PDB performance profile. You can specify utilization limits for CPU, parallel execution servers, and memory. - The Default Directive for PDBs
When you do not explicitly define directives for a PDB, the PDB uses the default directive for PDBs.
46.1.3.1 About CDB Resource Plans
There is a parent-child relationship between a CDB resource plan and its directives. Each directive references one of the following:
A single PDB
A set of PDBs in a PDB performance profile
PDB performance profiles are a good way to configure CDB resource plan directives for a group of PDBs. For example, you might create a performance profile for "gold" PDBs, "silver" PDBs, and "bronze" PDBs. A PDB specifies its performance profile with the DB_PERFORMANCE_PROFILE
initialization parameter. You can specify PDB initialization parameters that control resources, such as SGA_TARGET
and PGA_AGGREGATE_LIMIT
, for a group of PDBs using PDB lockdown profiles. It is best practice to use matching names for PDB performance profiles and PDB lockdown profiles. In addition, it is best practice to put the PDB's performance profile in the PDB’s lockdown profile to prevent PDB owners from switching profiles.
You can specify directives for both individual PDBs and for PDB performance profiles in the same CDB. No two directives for the currently active plan can reference the same PDB or the same PDB performance profile.
The directives control allocation of the following resources to the PDBs:
CPU
Parallel execution servers
A directive can control the allocation of resources to PDBs based on the share value that you specify for each PDB or PDB performance profile. A higher share value results in more resources. For example, you can specify that one PDB is allocated double the resources allocated to a second PDB by setting the share value for the first PDB twice as high as the share value for the second PDB. Similarly, you can specify that one PDB performance profile is allocated double the resources allocated to a second PDB performance profile by setting the share value for the first PDB performance profile twice as high as the share value for the second PDB performance profile. The settings apply to the set of PDBs that use each profile.
You can also specify utilization limits for PDBs and PDB performance profiles. The utilization limit limits resource allocation to the PDB or PDB performance profile. For example, it can control how much CPU a PDB gets as a percentage of the total CPU available to the CDB.
You can use both shares and utilization limits together for precise control over the resources allocated to each PDB and PDB performance profile in a CDB.
See Also:
"About Restricting PDB Users for Enhanced Security" for more information about PDB lockdown profiles
Parent topic: CDB Resource Plans
46.1.3.2 Shares for Allocating Resources to PDBs
You specify a share value for a PDB using the CREATE_CDB_PLAN_DIRECTIVE
procedure in the DBMS_RESOURCE_MANAGER
package. The shares
parameter in this procedure specifies the share value for the PDB.
You specify a share value for a PDB performance profile using the CREATE_CDB_PROFILE_DIRECTIVE
package. The shares
parameter in this procedure specifies the share value for the PDB performance profile. Multiple PDBs can use the same PDB performance profile.
Figure 46-1 shows an example of three PDBs with share values specified for them in a CDB resource plan.
Figure 46-1 shows that the total number of shares is seven (3 plus 3 plus 1). The salespdb
and the servicespdb
PDB are each guaranteed 3/7th of the resources, while the hrpdb
PDB is guaranteed 1/7th of the resources. However, any PDB can use more than the guaranteed amount of a resource if there is no resource contention.
Table 46-1 shows the resources allocation to the PDBs in Figure 46-1 based on the share values, assuming that loads of the PDBs consume all of the system resources allocated.
Table 46-1 Resource Allocation for Sample PDBs
Resource | Resource Allocation |
CPU |
The See "CPU" for more information about this resource. |
Parallel execution servers |
Queued parallel queries from the See "Degree of Parallelism Limit" for more information about this resource. |
46.1.3.3 Utilization Limits for PDBs
Utilization limits for a PDB are set either by the CDB resource plan or by PDB initialization parameters. Table 46-2 describes utilization limits for PDBs and the Resource Manager action taken when a PDB reaches a utilization limit. For limits specified with a PDB performance profile, each limit applies to each PDB that uses the PDB performance profile.
Table 46-2 Utilization Limits for PDBs
Resource | Resource Utilization Limit | Resource Manager Action |
CPU |
The sessions connected to a PDB reach the CPU utilization limit for the PDB. This utilization limit for CPU is set by the You can also limit CPU for a PDB by setting the initialization parameter |
Resource Manager throttles the PDB sessions so that the CPU utilization for the PDB does not exceed the utilization limit. |
A PDB uses more than the value of the For example, if the |
Resource Manager queues parallel queries if the number of parallel execution servers used by the PDB would exceed the limit specified by the |
Memory |
Several initialization parameters can control the memory usage of a PDB. For example, the See "Initialization Parameters That Control Memory for PDBs" for more information about this resource. |
Oracle Database prevents the PDB from using more memory than the amount specified in a limiting initialization parameter. |
Figure 46-2 shows an example of three PDBs with shares and utilization limits specified for them in a CDB resource plan.
Figure 46-2 Shares and Utilization Limits in a CDB Resource Plan
Description of "Figure 46-2 Shares and Utilization Limits in a CDB Resource Plan"
Figure 46-2 shows that there are no utilization limits on the salespdb
and servicespdb
PDBs because utilization_limit
and parallel_server_limit
are both set to 100% for them. However, the hrpdb
PDB is limited to 70% of the applicable system resources because utilization_limit
are both set to 70%.
46.1.3.4 The Default Directive for PDBs
Table 46-3 shows the attributes of the initial default directive for PDBs.
Table 46-3 Initial Default Directive Attributes for PDBs
Directive Attribute | Value |
1 |
100 |
100 |
When a PDB is plugged into a CDB and no directive is defined for it, the PDB uses the default directive for PDBs.
You can create new directives for the new PDB. You can also change the default directive attribute values for PDBs by using the UPDATE_CDB_DEFAULT_DIRECTIVE
package.
When a PDB is unplugged from a CDB, the directive for the PDB is retained. If the same PDB is plugged back into the CDB, then it uses the directive defined for it if the directive was not deleted manually.
Figure 46-3 shows an example of the default directive in a CDB resource plan.
Figure 46-3 Default Directive in a CDB Resource Plan
Description of "Figure 46-3 Default Directive in a CDB Resource Plan"
Figure 46-3 shows that the default PDB directive specifies that the share
is 1, the utilization_limit
is 50%, and the parallel_server_limit
is 50%. Any PDB that is part of the CDB and does not have directives defined for it uses the default PDB directive. Figure 46-3 shows the PDBs marketingpdb
and testingpdb
using the default PDB directive. Therefore, marketingpdb
and testingpdb
each get 1 share and utilization limits of 50.
46.1.4 PDB Resource Plans
A PDB resource plan is similar to a resource plan for a non-CDB. Specifically, a PDB resource plan allocates resource among the consumer groups within a PDB. You can use a PDB resource plan to allocate the resources described in "The Types of Resources Managed by the Resource Manager".
When you create one or more PDB resource plans, the CDB resource plan for the PDB's CDB should meet certain requirements. Table 46-4 describes the requirements for the CDB resource plan and the results when the requirements are not met.
You create directives for a CDB resource plan by using the CREATE_CDB_PLAN_DIRECTIVE
package. You create directives for a PDB resource plan using the CREATE_PLAN_DIRECTIVE
procedure in the same package. When you create one or more PDB resource plans and there is no CDB resource plan, the CDB uses the DEFAULT_CDB_PLAN
that is supplied with Oracle Database.
Table 46-4 describes parameter values for PL/SQL procedures. The parameter values described in the "CDB Resource Plan Requirements" column are for the CREATE_CDB_PLAN_DIRECTIVE
procedure. The parameter values described in the "Results When Requirements Are Not Met" column are for the CREATE_PLAN_DIRECTIVE
procedure.
Table 46-4 CDB Resource Plan Requirements for PDB Resource Plans
Resource | CDB Resource Plan Requirements | Results When Requirements Are Not Met |
CPU |
One of the following requirements must be met:
These values can be set in a directive for the specific PDB or in a default directive. |
The CPU allocation policy of the PDB resource plan is not enforced. The CPU limit specified by the |
The parallel execution server allocation policy of the PDB resource plan is not enforced. The parallel server limit specified by the |
Memory |
A share value must be specified for the PDB using the This value can be set in a directive for the specific PDB or in a default directive. |
The memory allocation policy of the PDB resource plan is not enforced. |
Figure 46-4 shows an example of a CDB resource plan and a PDB resource plan.
Figure 46-4 A CDB Resource Plan and a PDB Resource Plan
Description of "Figure 46-4 A CDB Resource Plan and a PDB Resource Plan"
Figure 46-4 shows some of the directives in a PDB resource plan for the servicespdb
PDB. Other PDBs in the CDB can also have PDB resource plans.
In a CDB, the following restrictions apply to PDB resource plans:
A PDB resource plan cannot have subplans.
A PDB resource plan can have a maximum of eight consumer groups.
A PDB resource plan cannot have a multiple-level scheduling policy.
If you create a PDB using a non-CDB, and the non-CDB contains resource plans, then these resource plans might not conform to these restrictions. In this case, Oracle Database automatically transforms these resource plans into equivalent PDB resource plans that meet these requirements. The original resource plans and directives are recorded in the DBA_RSRC_PLANS
and DBA_RSRC_PLAN_DIRECTIVES
views with the LEGACY
status.
See Also:
46.1.5 Background and Administrative Tasks and Consumer Groups
Resource Manager uses the following rules to map a task to a consumer group:
A task is mapped to a consumer group in the container that starts the task. If a task starts in the root, then the task is mapped to a consumer group in the root. If the task starts in a PDB, then the task is mapped to a consumer group in the PDB.
When a task is started by an internal client using an internal API, the internal API determines the consumer group to which the task is mapped.
For example, a backup task uses an internal Oracle function. When
SYS
starts a backup task in the root, the backup task is mapped based on the Oracle function to theSYS_GROUP
consumer group in the root. -
When a task is started without using an internal API, the task is mapped to a consumer group based on the user-defined mapping rules.
For example, when
SYS
is mapped to theSYS_GROUP
consumer group, a task started bySYS
consumer group.
The following background and administrative tasks follow these rules:
Backup and recovery
Auditing
Replication and Advanced Queuing
Unplugging a PDB
Maintenance windows
46.1.6 Initialization Parameters That Control Memory for PDBs
When you set the following initialization parameters with the PDB as the current container, the parameters control the memory usage of the current PDB. When one or more of these parameters is set for a PDB, ensure that the CDB and the other PDBs have sufficient memory for their operations.
Table 46-5 Initialization Parameters That Control the Memory Usage of PDBs
Initialization Parameter | Description |
Sets the minimum, guaranteed buffer cache space for the PDB. The following requirements must be met:
These requirements do not apply if the When the
Sets the minimum, guaranteed shared pool space for the PDB. The following requirements must be met:
Sets the maximum PGA size for the PDB. The following requirements must be met:
Sets the target aggregate PGA size for the PDB. The following requirements must be met:
Sets the minimum SGA size for the PDB. The following requirements must be met:
These requirements do not apply if the The best practice is to limit the sum of the |
Sets the maximum SGA size for the PDB. The |
These initialization parameters control the memory usage of PDBs only if the following conditions are met:
The
NONCDB_COMPATIBLE
initialization parameter is set tofalse
in the CDB root. -
The
MEMORY_TARGET
initialization parameter is not set or is set to0
(zero) in the CDB root.
Example 46-1 Setting the Maximum Aggregate PGA Memory Available for a PDB
With the PDB as the current container, run the following SQL statement to set he PGA_AGGREGATE_LIMIT
initialization parameter both in memory and in the spfile to 90 megabytes:
ALTER SYSTEM SET PGA_AGGREGATE_LIMIT = 90M SCOPE = BOTH;
Example 46-2 Setting the Minimum SGA Size for a PDB
With the PDB as the current container, run the following SQL statement to set the SGA_MIN_SIZE
initialization parameter both in memory and in the spfile to 500 megabytes:
ALTER SYSTEM SET SGA_MIN_SIZE = 500M SCOPE = BOTH;
Related Topics
46.1.7 Initialization Parameters That Limit I/O for PDBs
You can set the MAX_IOPS
initialization parameter and the MAX_MBPS
A large amount of disk I/O can cause poor performance. Several factors can result in excess disk I/O, such as poorly designed SQL or index and table scans in high-volume transactions. If one PDB is generating a large amount of disk I/O, then it can degrade the performance of other PDBs in the same CDB.
Use one or both of the following initialization parameters to limit the I/O generated by a particular PDB:
The
MAX_IOPS
initialization parameter limits the number of I/O operations for each second. -
The
MAX_MBPS
initialization parameter limits the megabytes for I/O operations for each second.
Both limits are enforced if you set both initialization parameters for a single PDB.
If these initialization parameters are set with the CDB root as the current container, then the values become the default values for all of the containers in the CDB. If they are set with an application root as the current container, then the values become the default values for all of the application PDBs in the application container. When they are set with a PDB or application PDB as the current container, then the settings take precedence over the default settings in the CDB root or the application root. These parameters cannot be set in a non-CDB.
The default for both of these initialization parameters is 0 (zero). If these initialization parameters are set to 0 (zero) in a PDB, and the CDB root is set to 0, then there is no I/O limit for the PDB. If these initialization parameters are set to 0 (zero) in an application PDB, and its application root is set to 0, then there is no I/O limit for the application PDB.
Critical I/O operations, such as ones for the control file and password file are exempted from the limit and continue to run even if the limit is reached. However, all I/O operations, including critical I/O operations, are counted when the number of I/O operations and the megabytes for I/O operations are calculated.
You can use the DBA_HIST_RSRC_PDB_METRIC
view to calculate a reasonable I/O limit for a PDB. Consider the values in the following columns when calculating a limit: IOPS
, IOMBPS
, IOPS_THROTTLE_EXEMPT
, and IOMBPS_THROTTLE_EXEMPT
. The "rsmgr:io rate limit" wait event indicates that a limit was reached.
Example 46-3 Limiting the I/O Generated by a PDB
With the PDB as the current container, run the following SQL statement to set the MAX_IOPS
initialization parameter both in memory and in the spfile to a limit of 1,000 I/O operations for each second:
ALTER SYSTEM SET MAX_IOPS = 1000 SCOPE = BOTH;
Example 46-4 Limiting the Megabytes of I/O Generated by a PDB
With the PDB as the current container, run the following SQL statement to set the MAX_MBPS
initialization parameter both in memory and in the spfile to a limit of 5 megabytes of I/O for each second:
ALTER SYSTEM SET MAX_MBPS = 5 SCOPE = BOTH;
See Also:
Oracle Database Reference for more information about the
MAX_IOPS
initialization parameter -
MAX_MBPS
46.2 Prerequisites for Using Resource Manager with a CDB
Before you can use Resource Manager with a CDB, the following prerequisites must be met:
The CDB must exist and must contain PDBs.
See Creating and Configuring a CDB and Creating and Removing PDBs with SQL*Plus.
To complete a task that uses the
package, a user must haveADMINISTER_RESOURCE_MANAGER
system privilege.
46.3 Creating a CDB Resource Plan for Individual PDBs
You use the DBMS_RESOURCE_MANAGER
The general steps for creating a CDB resource plan for individual PDBs are the following:
- Create the pending area using the
CREATE_PENDING_AREA
procedure. - Create the CDB resource plan using the
CREATE_CDB_PLAN
procedure. - Create directives for the PDBs using the
procedure. - (Optional) Update the default PDB directive using the
procedure. - (Optional) Update the default autotask directive using the
UPDATE_CDB_AUTOTASK_DIRECTIVE
procedure. - Validate the pending area using the
VALIDATE_PENDING_AREA
procedure. - Submit the pending area using the
SUBMIT_PENDING_AREA
procedure.
- Creating a CDB Resource Plan for Individual PDBs: A Scenario
A scenario illustrates each of the steps involved in creating a CDB resource plan for individual PDBs.
46.3.1 Creating a CDB Resource Plan for Individual PDBs: A Scenario
The scenario assumes that you want to create a CDB resource plan for a CDB named newcdb
. The plan includes a directive for each PDB. In this scenario, you also update the default directive and the autotask directive.
The directives are defined using various procedures in the DBMS_RESOURCE_MANAGER
package. The attributes of each directive are defined using parameters in these procedures. Table 46-6 describes the types of directives in the plan.
Table 46-6 Attributes for PDB Directives in a CDB Resource Plan
Directive Attribute | Description |
Resource allocation share for CPU and parallel execution server resources. See "Shares for Allocating Resources to PDBs". |
Resource utilization limit for CPU. See "Utilization Limits for PDBs". |
Maximum percentage of parallel execution servers that a PDB can use. When the |
Table 46-7 describes how the CDB resource plan allocates resources to its PDBs using the directive attributes described in Table 46-6.
Table 46-7 Sample Directives for PDBs in a CDB Resource Plan
PDB | shares Directive | utilization_limit Directive | parallel_server_limit Directive |
3 |
Unlimited |
Unlimited |
3 |
Unlimited |
Unlimited |
1 |
70 |
70 |
Default |
1 |
50 |
50 |
Autotask |
1 |
75 |
75 |
The salespdb
and servicespdb
PDBs are more important than the other PDBs in the CDB. Therefore, they get a higher share (3), unlimited CPU utilization resource, unlimited parallel execution server resource, and unlimited memory resource.
The default directive applies to PDBs for which specific directives have not been defined. For this scenario, assume that the CDB has several PDBs that use the default directive. This scenario updates the default directive.
In addition, this scenario updates the autotask directive. The autotask directive applies to automatic maintenance tasks that are run in the root maintenance window.
The following tasks use the DBMS_RESOURCE_MANAGER
package to create the CDB resource plan and update the default and autotask directives for this scenario:
Create a pending area using the
CREATE_PENDING_AREA
procedure:exec DBMS_RESOURCE_MANAGER.CREATE_PENDING_AREA();
Create a CDB resource plan named
newcdb_plan
using theCREATE_CDB_PLAN
procedure:BEGIN DBMS_RESOURCE_MANAGER.CREATE_CDB_PLAN( plan => 'newcdb_plan', comment => 'CDB resource plan for newcdb'); END; /
Create the CDB resource plan directives for the PDBs using the
procedure. Each directive specifies how resources are allocated to a specific PDB.Table 46-7 describes the directives for the
salespdb
,servicespdb
, andhrpdb
PDBs in this scenario. Run the following procedures to create these directives:BEGIN DBMS_RESOURCE_MANAGER.CREATE_CDB_PLAN_DIRECTIVE( plan => 'newcdb_plan', pluggable_database => 'salespdb', shares => 3, utilization_limit => 100, parallel_server_limit => 100); END; / BEGIN DBMS_RESOURCE_MANAGER.CREATE_CDB_PLAN_DIRECTIVE( plan => 'newcdb_plan', pluggable_database => 'servicespdb', shares => 3, utilization_limit => 100, parallel_server_limit => 100); END; / BEGIN DBMS_RESOURCE_MANAGER.CREATE_CDB_PLAN_DIRECTIVE( plan => 'newcdb_plan', pluggable_database => 'hrpdb', shares => 1, utilization_limit => 70, parallel_server_limit => 70); END; /
All other PDBs in this CDB use the default PDB directive.
If the current default CDB resource plan directive for PDBs does not meet your requirements, then update the directive using the
procedure.The default directive applies to PDBs for which specific directives have not been defined. See "The Default Directive for PDBs" for more information.
Table 46-7 describes the default directive that PDBs use in this scenario. Run the following procedure to update the default directive:
BEGIN DBMS_RESOURCE_MANAGER.UPDATE_CDB_DEFAULT_DIRECTIVE( plan => 'newcdb_plan', new_shares => 1, new_utilization_limit => 50, new_parallel_server_limit => 50); END; /
If the current autotask CDB resource plan directive does not meet your requirements, then update the directive using the
procedure.The autotask directive applies to automatic maintenance tasks that are run in the root maintenance window.
Table 46-7 describes the autotask directive in this scenario. Run the following procedure to update the autotask directive:
BEGIN DBMS_RESOURCE_MANAGER.UPDATE_CDB_AUTOTASK_DIRECTIVE( plan => 'newcdb_plan', new_shares => 1, new_utilization_limit => 75, new_parallel_server_limit => 75); END; /
procedure:exec DBMS_RESOURCE_MANAGER.VALIDATE_PENDING_AREA();
SUBMIT_PENDING_AREA
procedure:exec DBMS_RESOURCE_MANAGER.SUBMIT_PENDING_AREA();
Parent topic: Creating a CDB Resource Plan for Individual PDBs
46.4 Creating a CDB Resource Plan with PDB Performance Profiles
The general steps for creating a CDB resource plan with PDB performance profiles are the following:
- For each PDB that will use a profile, set the
initialization parameter and specify the profile name. - Create the pending area using the
CREATE_PENDING_AREA
CREATE_CDB_PLAN
procedure. - Create directives for the PDB performance profiles using the
SUBMIT_PENDING_AREA
procedure.
- Creating a CDB Resource Plan for PDB Performance Profiles: A Scenario
A scenario illustrates each of the steps involved in creating a CDB resource plan for PDB performance profiles.
46.4.1 Creating a CDB Resource Plan for PDB Performance Profiles: A Scenario
. The plan includes a directive for each PDB performance profile. In this scenario, you also update the default directive and the autotask directive.
In the CDB resource plan, you give each profile a name. In each PDB, you set the DB_PERFORMANCE_PROFILE
initialization parameter to specify which PDB performance profile the PDB uses.
package. The attributes of each directive are defined using parameters in these procedures. Table 46-8 describes the types of directives in the plan.
Table 46-8 Attributes for PDB Performance Profile Directives in a CDB Resource Plan
Table 46-9 describes how the CDB resource plan allocates resources to its PDB performance profiles using the directive attributes described in Table 46-8.
Table 46-9 Sample Directives for PDB Performance Profiles in a CDB Resource Plan
3 |
Unlimited |
Unlimited |
2 |
40 |
40 |
1 |
20 |
20 |
Default |
1 |
10 |
10 |
Autotask |
2 |
60 |
60 |
The PDBs that use the gold
PDB performance profile are more important than the other PDBs in the CDB. Therefore, they get a higher share (3), unlimited CPU utilization resource, and unlimited parallel execution server resource.
The PDBs that use the silver
PDB performance profile are of moderate importance. Therefore, they get a share of 2. They are guaranteed a minimum of 40 percent of the CPU utilization resource and parallel execution server resource.
The PDBs that use the bronze
PDB performance profile are the least important PDBs in the CDB. Therefore, they get the lowest share (1). They are guaranteed a minimum of 20 percent of the CPU utilization resource and parallel execution server resource.
Complete the following steps to create the CDB resource plan for PDB performance profiles and update the default and autotask directives for this scenario:
initialization parameter to the name of the profile that the PDB will use.-
Run an
ALTER SYSTEM
statement to set the parameter.For example, with the PDB as the current container, run the following SQL statement:
ALTER SYSTEM SET DB_PERFORMANCE_PROFILE=gold SCOPE=spfile;
Close the PDB:
ALTER PLUGGABLE DATABASE CLOSE IMMEDIATE;
Open the PDB:
ALTER PLUGGABLE DATABASE OPEN;
CREATE_PENDING_AREA
newcdb_plan
gold
,silver
, andbronze
profiles in this scenario. Run the following procedures to create these directives:BEGIN DBMS_RESOURCE_MANAGER.CREATE_CDB_PROFILE_DIRECTIVE( plan => 'newcdb_plan', profile => 'gold', shares => 3, utilization_limit => 100, parallel_server_limit => 100); END; / BEGIN DBMS_RESOURCE_MANAGER.CREATE_CDB_PROFILE_DIRECTIVE( plan => 'newcdb_plan', profile => 'silver', shares => 2, utilization_limit => 40, parallel_server_limit => 40); END; / BEGIN DBMS_RESOURCE_MANAGER.CREATE_CDB_PROFILE_DIRECTIVE( plan => 'newcdb_plan', profile => 'bronze', shares => 1, utilization_limit => 20, parallel_server_limit => 20); END; /
BEGIN DBMS_RESOURCE_MANAGER.UPDATE_CDB_DEFAULT_DIRECTIVE( plan => 'newcdb_plan', new_shares => 1, new_utilization_limit => 10, new_parallel_server_limit => 10); END; /
BEGIN DBMS_RESOURCE_MANAGER.UPDATE_CDB_AUTOTASK_DIRECTIVE( plan => 'newcdb_plan', new_shares => 1, new_utilization_limit => 60, new_parallel_server_limit => 60); END; /
SUBMIT_PENDING_AREA
46.5 Enabling and Disabling a CDB Resource Plan
- Enabling a CDB Resource Plan
You enable the Resource Manager for a CDB by setting theRESOURCE_MANAGER_PLAN
initialization parameter in the root. - Disabling a CDB Resource Plan
You disable the Resource Manager for a CDB by unsetting theRESOURCE_MANAGER_PLAN
46.5.1 Enabling a CDB Resource Plan
You enable the Resource Manager for a CDB by setting the RESOURCE_MANAGER_PLAN
This parameter specifies the top plan, which is the plan to be used for the current CDB instance. If no plan is specified with this parameter, then the Resource Manager is not enabled.
Before enabling a CDB resource plan, complete the prerequisites described in "Prerequisites for Using Resource Manager with a CDB".
To enable a CDB resource plan:
In SQL*Plus, ensure that the current container is the root.
Perform one of the following actions:
Use an
ALTER
SYSTEM
statement to set theRESOURCE_MANAGER_PLAN
initialization parameter to the CDB resource plan.The following example sets the CDB resource plan to
newcdb_plan
using anALTER
SYSTEM
statement:ALTER SYSTEM SET RESOURCE_MANAGER_PLAN = 'newcdb_plan';
In a text initialization parameter file, set the
initialization parameter to the CDB resource plan, and restart the CDB.The following example sets the CDB resource plan to
newcdb_plan
in an initialization parameter file:RESOURCE_MANAGER_PLAN = 'newcdb_plan'
You can also schedule a CDB resource plan change with Oracle Scheduler.
46.5.2 Disabling a CDB Resource Plan
You disable the Resource Manager for a CDB by unsetting the RESOURCE_MANAGER_PLAN
If you disable a CDB resource plan, then some directives in PDB resource plans become disabled. See "PDB Resource Plans" for information about the CDB resource plan requirements for PDB resource plans.
Before disabling a CDB resource plan, complete the prerequisites described in "Prerequisites for Using Resource Manager with a CDB".
To disable a CDB resource plan:
Use an
ALTER
SYSTEM
statement to unset theRESOURCE_MANAGER_PLAN
initialization parameter for the CDB.The following example unsets the
initialization parameter using anALTER
SYSTEM
statement:ALTER SYSTEM SET RESOURCE_MANAGER_PLAN = '';
In an initialization parameter file, unset the
initialization parameter, and restart the CDB.The following example unsets the
initialization parameter in an initialization parameter file:RESOURCE_MANAGER_PLAN =
To shut down and restart a CDB, see "Shutting Down a CDB Instance" and "Starting Up a Database".
Parent topic: Enabling and Disabling a CDB Resource Plan
46.6 Creating a PDB Resource Plan
You create a PDB resource plan in the same way that you create a resource plan for a non-CDB. You use procedures in the DBMS_RESOURCE_MANAGER
A CDB resource plan allocates a portion of the system's resources to a PDB. A PDB resource plan determines how this portion is allocated within the PDB.
The following is a summary of the steps required to create a PDB resource plan:
- In SQL*Plus, ensure that the current container is a PDB.
- Create a pending area using the
CREATE_PENDING_AREA
procedure. - Create, modify, or delete consumer groups using the
CREATE_CONSUMER_GROUP
procedure. - Map sessions to consumer groups using the
SET_CONSUMER_GROUP_MAPPING
procedure. - Create the PDB resource plan using the
CREATE_PLAN
procedure. - Create PDB resource plan directives using the
SUBMIT_PENDING_AREA
procedure.
Ensure that the current container is a PDB and that the user has the required privileges when you complete these steps. See "Creating a Complex Resource Plan" for detailed information about completing these steps.
You also have the option of creating a simple resource plan that is adequate for many situations using the CREATE_SIMPLE_PLAN
procedure. See "Creating a Simple Resource Plan ".
Some restrictions apply to PDB resource plans. See "PDB Resource Plans" for information.
46.7 Enabling and Disabling a PDB Resource Plan
- Enabling a PDB Resource Plan
You enable a PDB resource plan by setting theRESOURCE_MANAGER_PLAN
initialization parameter to the plan with anALTER
SYSTEM
statement when the current container is the PDB. - Disabling a PDB Resource Plan
You disable a PDB resource plan by unsetting theRESOURCE_MANAGER_PLAN
initialization parameter in the PDB.
46.7.1 Enabling a PDB Resource Plan
You enable a PDB resource plan by setting the RESOURCE_MANAGER_PLAN
initialization parameter to the plan with an ALTER
SYSTEM
If no plan is specified with this parameter, then no PDB resource plan is enabled for the PDB.
Before enabling a PDB resource plan, complete the prerequisites described in "Prerequisites for Using Resource Manager with a CDB".
To enable a PDB resource plan:
Use an
ALTER
SYSTEM
initialization parameter to the PDB resource plan.
You can also schedule a PDB resource plan change with Oracle Scheduler.
Example 46-5 Enabling a PDB Resource Plan
The following example sets the PDB resource plan to salespdb_plan
ALTER SYSTEM SET RESOURCE_MANAGER_PLAN = 'salespdb_plan';
46.7.2 Disabling a PDB Resource Plan
You disable a PDB resource plan by unsetting the RESOURCE_MANAGER_PLAN
Before disabling a PDB resource plan, complete the prerequisites described in "Prerequisites for Using Resource Manager with a CDB".
To disable a PDB resource plan:
Use an
ALTER
SYSTEM
initialization parameter for the PDB.
Example 46-6 Disabling a PDB Resource Plan
The following example disables the PDB resource plan.
See Also:
Parent topic: Enabling and Disabling a PDB Resource Plan
46.8 Maintaining Plans and Directives in a CDB
This section provides instructions for maintaining CDB resource plans, the default directive for PDBs, the autotask directive, and PDB resource plans. You perform maintenance tasks using the DBMS_RESOURCE_MANAGER
PL/SQL package.
- Managing a CDB Resource Plan
Managing a CDB resource plan includes tasks such as updating the plan, creating, updating, or deleting plan directives for PDBs, and updating default directives. - Modifying a PDB Resource Plan
You can use theDBMS_RESOURCE_MANAGER
package to modify a PDB resource plan in the same way you would modify the resource plan for a non-CDB.
46.8.1 Managing a CDB Resource Plan
- Updating a CDB Resource Plan
You can update a CDB resource plan to change its comment using theUPDATE_CDB_PLAN
procedure. - Managing CDB Resource Plan Directives for a PDB
You can create, update, and delete CDB resource plan directives for a PDB. - Managing CDB Resource Plan Directives for a PDB Performance Profile
You can create, update, and delete CDB resource plan directives for a PDB performance profile. - Updating the Default Directive for PDBs in a CDB Resource Plan
You can update the default directive for PDBs in a CDB resource plan using theUPDATE_CDB_DEFAULT_DIRECTIVE
procedure. The default directive applies to PDBs for which specific directives have not been defined. - Updating the Default Directive for Maintenance Tasks in a CDB Resource Plan
You can update the autotask directive in a CDB resource plan using theUPDATE_CDB_AUTOTASK_DIRECTIVE
procedure. The autotask directive applies to automatic maintenance tasks that are run in the root maintenance window. - Deleting a CDB Resource Plan
You can delete a CDB resource plan using theDELETE_CDB_PLAN
procedure.
Parent topic: Maintaining Plans and Directives in a CDB
46.8.1.1 Updating a CDB Resource Plan
You can update a CDB resource plan to change its comment using the UPDATE_CDB_PLAN
procedure.
Before updating a CDB resource plan, complete the prerequisites described in "Prerequisites for Using Resource Manager with a CDB".
To update a CDB resource plan:
Create a pending area:
Run the
UPDATE_CDB_PLAN
procedure, and enter a new comment in thenew_comment
parameter.For example, the following procedure changes the comment for the
newcdb_plan
CDB resource plan:BEGIN DBMS_RESOURCE_MANAGER.UPDATE_CDB_PLAN( plan => 'newcdb_plan', new_comment => 'CDB plan for PDBs in newcdb'); END; /
Validate the pending area:
Submit the pending area:
See Also:
Parent topic: Managing a CDB Resource Plan
46.8.1.2 Managing CDB Resource Plan Directives for a PDB
- Creating New CDB Resource Plan Directives for a PDB
When you create a PDB in a CDB, you can create a CDB resource plan directive for the PDB using theCREATE_CDB_PLAN_DIRECTIVE
procedure. The directive specifies how resources are allocated to the new PDB. - Updating CDB Resource Plan Directives for a PDB
You can update the CDB resource plan directive for a PDB using theUPDATE_CDB_PLAN_DIRECTIVE
procedure. The directive specifies how resources are allocated to the PDB. - Deleting CDB Resource Plan Directives for a PDB
You can delete the CDB resource plan directive for a PDB using theDELETE_CDB_PLAN_DIRECTIVE
procedure.
46.8.1.2.1 Creating New CDB Resource Plan Directives for a PDB
When you create a PDB in a CDB, you can create a CDB resource plan directive for the PDB using the CREATE_CDB_PLAN_DIRECTIVE
Before creating a new CDB resource plan directive for a PDB, complete the prerequisites described in "Prerequisites for Using Resource Manager with a CDB".
To create a new CDB resource plan directive for a PDB:
Run the
procedure, and specify the appropriate values for the new PDB.For example, the following procedure allocates resources to a PDB named
operpdb
in thenewcdb_plan
CDB resource plan:BEGIN DBMS_RESOURCE_MANAGER.CREATE_CDB_PLAN_DIRECTIVE( plan => 'newcdb_plan', pluggable_database => 'operpdb', shares => 1, utilization_limit => 20, parallel_server_limit => 30); END; /
See Also:
Parent topic: Managing CDB Resource Plan Directives for a PDB
46.8.1.2.2 Updating CDB Resource Plan Directives for a PDB
You can update the CDB resource plan directive for a PDB using the UPDATE_CDB_PLAN_DIRECTIVE
Before updating a CDB resource plan directive for a PDB, complete the prerequisites described in "Prerequisites for Using Resource Manager with a CDB".
To update a CDB resource plan directive for a PDB:
Run the
procedure, and specify the new resource allocation values for the PDB.For example, the following procedure updates the resource allocation to a PDB named
operpdb
in thenewcdb_plan
CDB resource plan:BEGIN DBMS_RESOURCE_MANAGER.UPDATE_CDB_PLAN_DIRECTIVE( plan => 'newcdb_plan', pluggable_database => 'operpdb', new_shares => 1, new_utilization_limit => 10, new_parallel_server_limit => 20); END; /
See Also:
46.8.1.2.3 Deleting CDB Resource Plan Directives for a PDB
You can delete the CDB resource plan directive for a PDB using the DELETE_CDB_PLAN_DIRECTIVE
procedure.
You might delete the directive for a PDB if you unplug or drop the PDB. However, you can retain the directive, and if the PDB is plugged into the CDB in the future, the existing directive applies to the PDB.
Before deleting a CDB resource plan directive for a PDB, complete the prerequisites described in "Prerequisites for Using Resource Manager with a CDB".
To delete a CDB resource plan directive for a PDB:
Run the
procedure, and specify the CDB resource plan and the PDB.For example, the following procedure deletes the directive for a PDB named
operpdb
in thenewcdb_plan
CDB resource plan:BEGIN DBMS_RESOURCE_MANAGER.DELETE_CDB_PLAN_DIRECTIVE( plan => 'newcdb_plan', pluggable_database => 'operpdb'); END; /
See Also:
46.8.1.3 Managing CDB Resource Plan Directives for a PDB Performance Profile
- Creating New CDB Resource Plan Directives for a PDB Performance Profile
You can create a CDB resource plan directive for the a new PDB performance profile using theCREATE_CDB_PROFILE_DIRECTIVE
procedure. The directive specifies how resources are allocated to the all PDBs that use the new profile. - Updating CDB Resource Plan Directives for a PDB Performance Profile
You can update the CDB resource plan directive for a PDB performance profile using theUPDATE_CDB_PROFILE_DIRECTIVE
procedure. The directive specifies how resources are allocated to the PDBs that use the PDB performance profile. - Deleting CDB Resource Plan Directives for a PDB Performance Profile
You can delete the CDB resource plan directive for a PDB performance profile using theDELETE_CDB_PROFILE_DIRECTIVE
procedure.
46.8.1.3.1 Creating New CDB Resource Plan Directives for a PDB Performance Profile
You can create a CDB resource plan directive for the a new PDB performance profile using the CREATE_CDB_PROFILE_DIRECTIVE
Before creating a new CDB resource plan directive for a PDB performance profile, complete the prerequisites described in "Prerequisites for Using Resource Manager with a CDB".
To create a new CDB resource plan directive for a PDB performance profile:
Run the
procedure, and specify the appropriate values for the new PDB performance profile.For example, the following procedure allocates resources to a PDB performance profile named
copper
in thenewcdb_plan
CDB resource plan:BEGIN DBMS_RESOURCE_MANAGER.CREATE_CDB_PROFILE_DIRECTIVE( plan => 'newcdb_plan', profile => 'copper', shares => 1, utilization_limit => 20, parallel_server_limit => 30); END; /
For a PDB to use the new profile, the PDB must have theDB_PERFORMANCE_PROFILE
initialization parameter set to the profile name.
See Also:
46.8.1.3.2 Updating CDB Resource Plan Directives for a PDB Performance Profile
You can update the CDB resource plan directive for a PDB performance profile using the UPDATE_CDB_PROFILE_DIRECTIVE
Before updating a CDB resource plan directive for a PDB performance profile, complete the prerequisites described in "Prerequisites for Using Resource Manager with a CDB".
To update a CDB resource plan directive for a PDB performance profile:
Run the
procedure, and specify the new resource allocation values for the PDB performance profile.For example, the following procedure updates the resource allocation for a PDB performance profile named
copper
in thenewcdb_plan
CDB resource plan:BEGIN DBMS_RESOURCE_MANAGER.UPDATE_CDB_PROFILE_DIRECTIVE( plan => 'newcdb_plan', profile => 'copper', new_shares => 1, new_utilization_limit => 10, new_parallel_server_limit => 20); END; /
See Also:
46.8.1.3.3 Deleting CDB Resource Plan Directives for a PDB Performance Profile
You can delete the CDB resource plan directive for a PDB performance profile using the DELETE_CDB_PROFILE_DIRECTIVE
procedure.
You might delete the directive for a PDB performance profile if no PDBs use the profile.
Before deleting a CDB resource plan directive for a PDB performance profile, complete the prerequisites described in "Prerequisites for Using Resource Manager with a CDB".
To delete a CDB resource plan directive for a PDB performance profile:
Run the
procedure, and specify the CDB resource plan and the PDB performance profile.For example, the following procedure deletes the directive for a PDB named
operpdb
in thenewcdb_plan
CDB resource plan:BEGIN DBMS_RESOURCE_MANAGER.DELETE_CDB_PLAN_DIRECTIVE( plan => 'newcdb_plan', profile => 'operpdb'); END; /
See Also:
46.8.1.4 Updating the Default Directive for PDBs in a CDB Resource Plan
You can update the default directive for PDBs in a CDB resource plan using the UPDATE_CDB_DEFAULT_DIRECTIVE
Before updating the default directive for PDBs in a CDB resource plan, complete the prerequisites described in "Prerequisites for Using Resource Manager with a CDB".
To update the default directive for PDBs in a CDB resource plan:
Run the
procedure, and specify the appropriate default resource allocation values.For example, the following procedure updates the default directive for PDBs in the
newcdb_plan
CDB resource plan:BEGIN DBMS_RESOURCE_MANAGER.UPDATE_CDB_DEFAULT_DIRECTIVE( plan => 'newcdb_plan', new_shares => 2, new_utilization_limit => 40); END; /
See Also:
46.8.1.5 Updating the Default Directive for Maintenance Tasks in a CDB Resource Plan
You can update the autotask directive in a CDB resource plan using the UPDATE_CDB_AUTOTASK_DIRECTIVE
Before updating the default directive for maintenance tasks in a CDB resource plan, complete the prerequisites described in "Prerequisites for Using Resource Manager with a CDB".
To update the autotask directive for maintenance tasks in a CDB resource plan:
Run the
procedure, and specify the appropriate autotask resource allocation values.For example, the following procedure updates the autotask directive for maintenance tasks in the
newcdb_plan
CDB resource plan:BEGIN DBMS_RESOURCE_MANAGER.UPDATE_CDB_AUTOTASK_DIRECTIVE( plan => 'newcdb_plan', new_shares => 2, new_utilization_limit => 60); END; /
See Also:
46.8.1.6 Deleting a CDB Resource Plan
You can delete a CDB resource plan using the DELETE_CDB_PLAN
procedure.
The resource plan must be disabled. You might delete a CDB resource plan if the plan is no longer needed. You can enable a different CDB resource plan, or you can disable Resource Manager for the CDB.
Before deleting a CDB resource plan, complete the prerequisites described in "Prerequisites for Using Resource Manager with a CDB".
To delete a CDB resource plan:
Run the
DELETE_CDB_PLAN
procedure, and specify the CDB resource plan.For example, the following procedure deletes the
newcdb_plan
CDB resource plan:BEGIN DBMS_RESOURCE_MANAGER.DELETE_CDB_PLAN( plan => 'newcdb_plan'); END; /
46.8.2 Modifying a PDB Resource Plan
You can use the DBMS_RESOURCE_MANAGER
Before modifying a PDB resource plan, complete the prerequisites described in "Prerequisites for Using Resource Manager with a CDB".
To modify a PDB resource plan:
Modify the PDB resource plan by completing one or more of the following tasks:
Update a consumer group using the
UPDATE_CONSUMER_GROUP
procedure. -
Delete a consumer group using the
DELETE_CONSUMER_GROUP
procedure. -
Update a resource plan using the
UPDATE_PLAN
procedure. -
Delete a resource plan using the
DELETE_PLAN
procedure. -
Update a resource plan directive using the
UPDATE_PLAN_DIRECTIVE
procedure. -
Delete a resource plan directive using the
DELETE_PLAN_DIRECTIVE
procedure.
See "Maintaining Consumer Groups, Plans, and Directives" for instructions about completing these tasks.
See Also:
46.9 Viewing Information About Plans and Directives in a CDB
- Viewing CDB Resource Plans
An example illustrates using theDBA_CDB_RSRC_PLANS
view to display all of the CDB resource plans defined in the CDB. - Viewing CDB Resource Plan Directives
An example illustrates using theDBA_CDB_RSRC_PLAN_DIRECTIVES
view to display all of the directives defined in all of the CDB resource plans in the CDB.
See Also:
46.9.1 Viewing CDB Resource Plans
An example illustrates using the DBA_CDB_RSRC_PLANS
Run the following query in the root:
COLUMN PLAN FORMAT A30 COLUMN STATUS FORMAT A10 COLUMN COMMENTS FORMAT A35 SELECT PLAN, STATUS, COMMENTS FROM DBA_CDB_RSRC_PLANS ORDER BY PLAN;
Your output looks similar to the following:
PLAN STATUS COMMENTS ------------------------------ ---------- ----------------------------------- DEFAULT_CDB_PLAN Default CDB plan DEFAULT_MAINTENANCE_PLAN Default CDB maintenance plan NEWCDB_PLAN CDB plan for PDBs in newcdb ORA$INTERNAL_CDB_PLAN Internal CDB plan
The DEFAULT_CDB_PLAN
is a default CDB plan that is supplied with Oracle Database. You can use this default plan if it meets your requirements.
Plans in the pending area have a status of PENDING
. Plans in the pending area are being edited. Any plan that is not in the pending area has a NULL
status.
See Also:
Parent topic: Viewing Information About Plans and Directives in a CDB
46.9.2 Viewing CDB Resource Plan Directives
An example illustrates using the DBA_CDB_RSRC_PLAN_DIRECTIVES
COLUMN PLAN HEADING 'Plan' FORMAT A11 COLUMN PLUGGABLE_DATABASE HEADING 'Pluggable|Database' FORMAT A13 COLUMN SHARES HEADING 'Shares' FORMAT 999 COLUMN UTILIZATION_LIMIT HEADING 'Utilization|Limit' FORMAT 999 COLUMN PARALLEL_SERVER_LIMIT HEADING 'Parallel|Server|Limit' FORMAT 999 SELECT PLAN, PLUGGABLE_DATABASE, SHARES, UTILIZATION_LIMIT, PARALLEL_SERVER_LIMIT FROM DBA_CDB_RSRC_PLAN_DIRECTIVES ORDER BY PLAN;
Parallel Pluggable Utilization Server Plan Database Shares Limit Limit ----------- ------------- ------ ----------- -------- DEFAULT_CDB ORA$DEFAULT_P 1 100 100 _PLAN DB_DIRECTIVE DEFAULT_CDB ORA$AUTOTASK 90 100 _PLAN DEFAULT_MAI ORA$AUTOTASK 90 100 NTENANCE_PL AN DEFAULT_MAI ORA$DEFAULT_P 1 100 100 NTENANCE_PL DB_DIRECTIVE AN NEWCDB_PLAN HRPDB 1 70 70 NEWCDB_PLAN SALESPDB 3 100 100 NEWCDB_PLAN ORA$DEFAULT_P 1 50 50 DB_DIRECTIVE NEWCDB_PLAN ORA$AUTOTASK 1 75 75 NEWCDB_PLAN SERVICESPDB 3 100 100
This output shows the directives for the newcdb_plan
created in "Creating a CDB Resource Plan: A Scenario" and modified in "Managing a CDB Resource Plan".
The ORA$DEFAULT_PDB_DIRECTIVE
is the default directive for PDBs. See "The Default Directive for PDBs".
See Also:
46.10 Monitoring PDBs Managed by Oracle Database Resource Manager
Use the following dynamic performance views to help you monitor the results of your Oracle Database Resource Manager settings for PDBs:
V$RSRCPDBMETRIC
V$RSRCPDBMETRIC_HISTORY
The V$RSRCPDBMETRIC
view provides current statistics on resource consumption for PDBs, including CPU usage, parallel execution, I/O generated, and memory usage.
In addition, historical statistics are available through the DBA_HIST_RSRC_PDB_METRIC
view, which contains Automatic Workload Repository (AWR) snapshots.
The columns in the V$RSRCPDBMETRIC_HISTORY
view are the same as the columns in the V$RSRCPDBMETRIC
view. The only difference between these views is that the V$RSRCPDBMETRIC
view contains metrics for the past one minute only, whereas the V$RSRCPDBMETRIC_HISTORY
view contains metrics for the last 60 minutes.
The V$RSRCPDBMETRIC
and V$RSRCPDBMETRIC_HISTORY
views record statistics for resources that are not currently being managed by Resource Manager when the STATISTICS_LEVEL
initialization parameter is set to ALL
or TYPICAL
- Monitoring CPU Usage for PDBs
TheV$RSRCPDBMETRIC
view enables you to track CPU metrics in milliseconds, in terms of number of sessions, or in terms of utilization for the past one minute. It provides real-time metrics for each PDB and is very useful in scenarios where you are running workloads and want to continuously monitor CPU resource utilization. - Monitoring Parallel Execution for PDBs
TheV$RSRCPDBMETRIC
view enables you to track parallel statements and parallel server use for PDBs. - Monitoring the I/O Generated by PDBs
TheV$RSRCPDBMETRIC
view enables you to track the amount of I/O generated by PDBs. - Monitoring Memory Usage for PDBs
TheV$RSRCPDBMETRIC
view enables you to track the amount memory used by PDBs.
See Also:
Oracle Database SQL Tuning Guide for more information about real-time SQL monitoring
46.10.1 Monitoring CPU Usage for PDBs
The V$RSRCPDBMETRIC
CPU usage for a PDB is managed with the active CDB resource plan of the PDB's CDB. You can use this view to compare the maximum possible CPU utilization and average CPU utilization percentage for PDBs with other PDB settings such as CPU time used, time waiting for CPU, average number of sessions that are consuming CPU, and number of sessions that are waiting for CPU allocation. For example, you can view the amount of CPU resources a PDB used and how long it waited for resource allocation. Or, you can view how many sessions from each PDB are executed against the total number of active sessions.
Tracking CPU Consumption in Terms of CPU Utilization for PDBs
To track CPU consumption in terms of CPU utilization, use the CPU_UTILIZATION_LIMIT
and AVG_CPU_UTILIZATION
columns. AVG_CPU_UTILIZATION
lists the average percentage of the server's CPU that is consumed by a PDB. CPU_UTILIZATION_LIMIT
represents the maximum percentage of the server's CPU that a PDB can use. This limit is set using the UTILIZATION_LIMIT
directive attribute.
The following query displays this information by showing the container ID (CON_ID
) and name of each PDB:
COLUMN PDB_NAME FORMAT A10 SELECT r.CON_ID, p.PDB_NAME, r.CPU_UTILIZATION_LIMIT, r.AVG_CPU_UTILIZATION FROM V$RSRCPDBMETRIC r, CDB_PDBS p WHERE r.CON_ID = p.CON_ID;
Tracking CPU Consumption and Throttling for PDBs
Use the CPU_CONSUMED_TIME
and CPU_TIME_WAIT
columns to track CPU consumption and throttling in milliseconds for each PDB. The column NUM_CPUS
represents the number of CPUs that Resource Manager is managing.
COLUMN PDB_NAME FORMAT A10 SELECT r.CON_ID, p.PDB_NAME, r.CPU_CONSUMED_TIME, r.CPU_WAIT_TIME, r.NUM_CPUS FROM V$RSRCPDBMETRIC r, CDB_PDBS p WHERE r.CON_ID = p.CON_ID;
Tracking CPU Consumption and Throttling in Terms of Number of Sessions for PDBs
To track the CPU consumption and throttling in terms of number of sessions, use the RUNNING_SESSIONS_LIMIT
, AVG_RUNNING_SESSIONS
, and AVG_WAITING_SESSIONS
columns. RUNNING_SESSIONS_LIMIT
lists the maximum number of sessions from a particular PDB that can be running at any time. This limit is defined by the UTILIZATION_LIMIT
directive attribute that you set for the PDB. AVG_RUNNING_SESSIONS
lists the average number of sessions that are consuming CPU, and AVG_WAITING_SESSIONS
lists the average number of sessions that are waiting for CPU.
COLUMN PDB_NAME FORMAT A10 SELECT r.CON_ID, p.PDB_NAME, r.RUNNING_SESSIONS_LIMIT, r.AVG_RUNNING_SESSIONS, r.AVG_WAITING_SESSIONS FROM V$RSRCPDBMETRIC r, CDB_PDBS p WHERE r.CON_ID = p.CON_ID;
46.10.2 Monitoring Parallel Execution for PDBs
The V$RSRCPDBMETRIC
Parallel execution servers for a PDB are managed with the active CDB resource plan of the PDB's CDB. To track parallel statements and parallel server use for PDBs, use the AVG_ACTIVE_PARALLEL_STMTS
, AVG_QUEUED_PARALLEL_STMTS
, AVG_ACTIVE_PARALLEL_SERVERS
, AVG_QUEUED_PARALLEL_SERVERS
, and PARALLEL_SERVERS_LIMIT
columns.
and AVG_ACTIVE_PARALLEL_SERVERS
list the average number of parallel statements running and the average number of parallel servers used by the parallel statements. AVG_QUEUED_PARALLEL_STMTS
and AVG_QUEUED_PARALLEL_SERVERS
list the average number of parallel statements queued and average number of parallel servers that were requested by queued parallel statements. PARALLEL_SERVERS_LIMIT
lists the number of parallel servers allowed to be used by the PDB.
COLUMN PDB_NAME FORMAT A10 SELECT r.CON_ID, p.PDB_NAME, r.AVG_ACTIVE_PARALLEL_STMTS, r.AVG_QUEUED_PARALLEL_STMTS, r.AVG_ACTIVE_PARALLEL_SERVERS, r.AVG_QUEUED_PARALLEL_SERVERS, r.PARALLEL_SERVERS_LIMIT FROM V$RSRCPDBMETRIC r, CDB_PDBS p WHERE r.CON_ID = p.CON_ID;
46.10.3 Monitoring the I/O Generated by PDBs
The V$RSRCPDBMETRIC
I/O is limited for a PDB by setting the MAX_IOPS
initialization parameter or the MAX_MBPS
initialization parameter in the PDB. Use this view to compare the I/O generated by PDBs in terms of the number of operations each second and the number of megabytes each second.
Tracking the Number of I/O Operations Generated Each Second by PDBs
To track the I/O operations generated each second by PDBs during the previous minute, use the IOPS
column.
COLUMN PDB_NAME FORMAT A10 SELECT r.CON_ID, p.PDB_NAME, r.IOPS FROM V$RSRCPDBMETRIC r, CDB_PDBS p WHERE r.CON_ID = p.CON_ID;
Tracking the Number Megabytes Generated for I/O Operations Each Second by PDBs
To track number of megabytes generated for I/O operations each second by PDBs during the previous minute, use the IOMBPS
column.
COLUMN PDB_NAME FORMAT A10 SELECT r.CON_ID, p.PDB_NAME, r.IOMBPS FROM V$RSRCPDBMETRIC r, CDB_PDBS p WHERE r.CON_ID = p.CON_ID;
46.10.4 Monitoring Memory Usage for PDBs
The V$RSRCPDBMETRIC
Use this view to track the amount of SGA, PGA, buffer cache, and shared pool memory currently used by PDBs.
To track the current memory usage, in bytes, for specific PDBs, use the SGA_BYTES
, PGA_BYTES
, BUFFER_CACHE_BYTES
, and SHARED_POOL_BYTES
columns.
COLUMN PDB_NAME FORMAT A10 SELECT r.CON_ID, p.PDB_NAME, r.SGA_BYTES, r.PGA_BYTES, r.BUFFER_CACHE_BYTES, r.SHARED_POOL_BYTES FROM V$RSRCPDBMETRIC r, CDB_PDBS p WHERE r.CON_ID = p.CON_ID;
