Previous Topic
Next Topic
Book Contents
Registering an InForm Adapter
  1. Select Admin, and select Register Adapters.
    The Find Adapter view of the CIS Administration Register Adapters page appears.
  2. Type the URL that identifies the location of the adapter.
    • For a directly accessible (non-SSL) InForm Adapter:
      http://MACHINE/informAdapter/centraladmin/centraladminservice.svc
      where MACHINE is the name of the computer on which the adapter is installed.
    • For a secure (SSL) InForm Adapter:
      https://F5_LOADBALANCER_MACHINE/TRIALNAME/informAdapter/centraladmin/centraladminservice.svc
      where:
      • F5_LOADBALANCER_MACHINE is the name of the F5 load balancer server.
      • TRIALNAME is the name of a study registered with the InForm Adapter.
  3. Enter the display name for the adapter, and click Add.
    The adapter appears in the table. Repeat these steps for each adapter that you want to register. If you do not want to register an adapter, use the Remove button to remove the adapter.
  4. After adding all the adapters you want to register, click Next.
    The Register Adapters view of the CIS Administration Register Adapters page appears. This page displays details about the adapters you want to register.
  5. Review the list of adapters to verify that the information is correct for each adapter. You can use the Previous button to return to the Find Adapter page to make corrections.
  6. Click Finish.
    The adapters are registered, and details about each adapter appear in the Register Adapters view of the CIS Administration Register Adapters page.
Send Feedback
