Setting a load-balancing machine online
- Select Admin > CIS Sync.
- Select Load Balancing.
The Load Balancing tab appears and displays status information about the machines being used for load balancing.
- In the Load Balancing table, click Edit next to the load-balancing machine whose status you want to change.
The Status and Offline Reason fields are enabled.
- In the Status column for the machine you want to change, select Online from the drop-down list.
- Click Update.
CIS places the machine online.
