Viewing and changing security settings
The Security tab of the Configuration page enables you to view and change settings that determine how CIS Administration handles user authentication.
- Select Settings > Configuration.
The Configuration page appears.
- Select Security.
The Security tab of the Configuration page appears.
- Fill in the fields as needed, and click Save.
Security tab of the Configuration page - Fields.
Field
Description
Inactivity timeout (minutes)
Number of minutes a CIS Administration session can be inactive before it times out and CIS Administration logs a user off.
Authentication expiration (hours)
Number of hours after which a user authentication is no longer valid and the user must log on again.
Password expiration (days)
Number of days before a user password expires and the user must change the password when logging on.
Minimum password length
Minimum number of characters a user password must contain.
Note: Allowed characters in passwords are upper and lowercase letters, digits, underscore (_), pound sign (#), and dollar sign ($).
Failed logon limit
Number of failed logon attempts a user can make before CIS Administration deactivates a user.
Audit verbosity level
- Any—Save all logon errors.
- Failures only—Save errors only when a logon fails.
- Inactive failures only—Save errors when the inactive period exceeds the value in the Security tab of the Configuration page.
