Oracle8i interMedia Locator User's Guide and Reference
Release 8.1.5
Prev Next
This guide describes how to use Oracle8i interMedia Locator.
Oracle8i interMedia Locator requires Oracle8i or Oracle8i Enterprise Edition.
For information about the differences between Oracle8i and Oracle8i Enterprise Edition and the features and options that are available to you, see Getting to Know Oracle8i.
Intended Audience
This guide is intended for anyone who is interested in storing, retrieving, and manipulating locator point data in an Oracle database, including developers of locator specialization services.
This guide contains the following chapters and appendixes:
Chapter 1
Introduces Oracle8i interMedia Locator; explains locator-related concepts.
Chapter 2
Describes the Oracle8i interMedia Locator functions, the geocoding service, and the locator operator, along with examples of their use.
Appendix A
Describes how to run the sample application and includes a source listing of that program.
Appendix B
Lists exceptions raised and potential errors, their causes, and user actions to correct them.
Related Documents
For information added after the release of this guide, refer to the online README.TXT file in your ORACLE_HOME directory. Depending on your operating system, this file may be in:
Please see your operating-system specific installation guide for more information.
For more information about using this product in a development environment, see the following documents in the Release 8.1.5 Oracle8i documentation set:
In this guide, Oracle8i interMedia Locator is sometimes referred to as interMedia Locator.
In examples, an implied carriage return occurs at the end of each line, unless otherwise noted. You must press the Return key at the end of a line of input.
The following conventions are also used in this guide:
Convention  Meaning
Vertical ellipsis points in an example mean that information not directly related to the example has been omitted.
Horizontal ellipsis points in statements or commands mean that parts of the statement or command not directly related to the example have been omitted.
boldface text
Boldface text indicates a term defined in the text, the glossary, or in both locations.
italic text
Italic text is used for emphasis, for book titles, and variable names.
Angle brackets enclose user-supplied names.
Brackets enclose optional clauses from which you can choose one or none.
Copyright © 1999 Oracle Corporation.
All Rights Reserved.
