| Oracle8i interMedia Using Oracle8i interMedia with the Web Release 8.1.5.2 A77033-01 |
This appendix describes the error messages that you may encounter using Oracle8i interMedia Web Agent.
To help you find and fix errors, Oracle8i interMedia Web Agent embeds object names, numbers, and character strings in some messages. In this appendix, these embedded variables are represented by string, number, date, or character.
All messages displayed by Oracle software are prefixed by text that indicates which program issued the message. Oracle8i interMedia Web Agent uses the prefix MWM. For lists of the prefixes used by other Oracle products, see Oracle8i Error Messages.
MWM-00013 request: method= string path=string client= string
Cause: An event was written to an error log file describing the request method, path information, and the client that issued the request.
Action: Review the associated error message to determine the reason for the error.
MWM-00018 waiting for number requests to finish
Cause: The configuration is being stopped and is waiting for the specified number of active requests to finish.
Action: No action is required.
MWM-00050 out of memory
Cause: The process exceeded its virtual memory quota or the operating system ran out of memory.
Action: If the operating system ran out of memory, reduce the number of running programs on the machine and retry the operation.
MWM-00065 error opening a binary message file
Cause: An error occurred attempting to open a binary message file.
Action: Verify that a message file using the appropriate language exists in the correct location.
MWM-00067 nonrecoverable initialization or termination error
Cause: A nonrecoverable error was encountered during initialization or termination.
Action: Typically, this is an internal error message not usually issued. Review the associated error messages to determine the reason for the failure. If the problem can be resolved, restart the relevant server component after fixing the problem. If you are using Oracle Application Server, you must restart the Oracle8i interMedia cartridge. If you are using a Netscape server, you must restart the server. If you are using Microsoft Internet Information Server (IIS), you must restart the IIS process. If the problem cannot be resolved, contact customer support.
MWM-00072 unable to locate an NLS boot file; continuing with default boot block
Cause: The NLS runtime environment was unable to locate an NLS boot file; the startup process is continuing with the linked-in default boot block settings.
Action: Verify the Oracle installation and the NLS configuration on your system.
MWM-00073 error allocating number bytes of memory
Cause: The process exceeded its virtual memory quota or the operating system ran out of memory allocating the specified number of bytes.
MWM-00102 error opening file string
Cause: An error occurred trying to open a file.
MWM-00103 error closing file string
Cause: An error occurred trying to close a file.
MWM-00104 error deleting file string
Cause: An error occurred deleting a file.
MWM-00105 error reading number bytes from file string
Cause: An error occurred reading from a file.
MWM-00106 error writing number bytes to file string
Cause: An error occurred writing to a file.
MWM-00107 error rewinding file string
Cause: An error occurred rewinding a file.
MWM-00108 string (O/S error number): accessing file string
Cause: An error occurred trying to access a file.
Action: Use the operating system (O/S) error message to determine the reason for the failure, then correct the problem.
MWM-00109 unknown (O/S error number): accessing file string
Cause: An error occurred trying to access a file. However, the operating system (O/S) was not able to provide the text of an error message.
Action: Use the operating system error code to determine the reason for the failure, then correct the problem.
MWM-00110 line starting with string too long in file string
Cause: The specified file contained a line too long to read.
Action: Edit the file and reduce the length of the line.
MWM-00116 error creating file string
Cause: An error occurred trying to create a file.
MWM-00120 error loading or unloading configuration file string
Cause: An error occurred trying to load or unload a configuration file.
MWM-00122 error in configuration file string at line number
Cause: An error was encountered at the specified line number while loading a configuration file.
MWM-00123 error in line: string
Cause: An error was encountered in the indicated line while loading a configuration file.
MWM-00124 no section name specified
Cause: No section name was specified using the [section-name] syntax.
Action: Supply a valid section name in the configuration file.
MWM-00125 duplicate section name string in configuration file
Cause: The configuration file contained a duplicate section name.
Action: Either change the spelling of one of the section names or merge the sections into a single section.
MWM-00126 configuration parameter specified outside a section
MWM-00127 invalid parameter name and value specification
Cause: A configuration parameter name and value were specified incorrectly.
Action: Specify configuration parameters using the name=value syntax in the configuration file.
MWM-00128 duplicate parameter name string found in section [string]
Cause: The named section in the configuration file contained a duplicate parameter name and value specification.
Action: Either change the spelling of one of the parameter names or remove the duplicate parameter.
MWM-00129 configuration file string was loaded but contained errors
Cause: The configuration file was loaded, but contained one or more syntax errors.
Action: Review the associated error message to determine the reason for the error, then correct the errors in the configuration file.
MWM-00140 error loading or unloading image string
Cause: An error occurred trying to load or unload a dynamically loadable image.
MWM-00141 error looking up symbol string in image string
Cause: An error occurred trying to look up a symbol in a dynamically loadable image.
Action: Determine the reason for the failure, then correct the problem.
MWM-00160 error loading or unloading Web agent string
Cause: An error occurred trying to load or unload a Web Agent.
MWM-00161 Web agent string does not exist or was not configured correctly
Cause: The specified Web Agent does not exist or was not configured correctly.
Action: Verify that the Web Agent name is spelled correctly and that the Web Agent is configured correctly.
MWM-00162 Web agent string is not available to process request
Cause: No Web Agent was specified, a Web Agent name was specified but was spelled incorrectly, or the Web Agent was not configured correctly.
Action: Verify that the Web Agent name is specified and spelled correctly and that the Web Agent is configured correctly.
MWM-00180 error adding virtual path string
Cause: An error was encountered while adding a virtual path.
MWM-00181 error adding named virtual path name string
Cause: An error was encountered while adding a named virtual path.
MWM-00182 duplicate virtual path string
Cause: An attempt was made to create a new virtual path that is identical to an existing virtual path.
Action: Modify the configuration file to ensure that multiple entities are not using the same virtual path.
MWM-00183 Web agent string does not support named virtual paths
Cause: The configuration file contains a named virtual path for the Web Agent. However, the Web Agent does not support named virtual paths.
Action: Remove the named virtual path from the configuration file.
MWM-00184 error allocating the virtual path table
Cause: An error occurred allocating the virtual path table.
Action: This error is most likely due to running out of memory. Review the associated error message to determine the precise reason for the error.
MWM-00200 required section [general] not found in configuration file
Cause: The configuration file did not contain the required [general] section.
Action: Include the required [general] section in the configuration file.
MWM-00201 required configuration parameter string not found in section [string]
Cause: A required configuration parameter was not found in the specified section of the configuration file.
Action: Add the required parameter in the specified section of the configuration file.
MWM-00205 nonrecoverable error loading or starting a configuration
Cause: A nonrecoverable error was encountered during startup.
Action: Review the associated error messages to determine the cause of the problem, such as a missing required parameter in the configuration file. After you fix the problem, restart the relevant server component. If you are using Oracle Application Server, you must restart the Oracle8i interMedia cartridge. If you are using a Netscape server, you must restart the server. If you are using Microsoft Internet Information Server (IIS), you must restart the IIS process.
MWM-00206 nonrecoverable error stopping or unloading a configuration
Cause: A nonrecoverable error was encountered during shutdown.
Action: Review the associated error messages and to determine the cause of the problem, such as a missing required parameter in the configuration file. After you fix the problem, restart the relevant server component. If you are using Oracle Application Server, you must restart the Oracle8i interMedia cartridge. If you are using a Netscape server, you must restart the server. If you are using Microsoft Internet Information Server (IIS), you must restart the IIS process.
MWM-00207 string (O/S error number)
Cause: The operating system returned an error status.
Action: Review the associated error message to determine the operation being performed, then correct the problem.
MWM-00208 unknown O/S error number
Cause: The operating system returned an unknown error status.
MWM-00209 administration user name and password not specified
Cause: Both the user name and password must be specified for the administration Web Agent.
Action: Modify the configuration file and add a user name and a password for the administration Web Agent.
MWM-00210 administration Web agent not found in configuration
Cause: The administration Web Agent was not found in the configuration file or was configured incorrectly.
Action: Modify the configuration file to configure the administration Web Agent correctly.
MWM-00211 Web server shutdown with number requests still active
Cause: The Web server requested a shutdown. However, there were still one or more requests still active.
Action: This condition can result in a Web server component terminating abnormally because the active requests cannot complete normally. Verify that the Web server is configured correctly.
MWM-00223 error executing a request
Cause: An error occurred executing a request.
MWM-00225 error setting HTTP authorization realm name
Cause: An error occurred setting the HTTP authorization realm name.
MWM-00228 error adding response header
Cause: An error occurred adding a response header.
MWM-00229 error sending response header
Cause: An error occurred sending the response header.
MWM-00232 error redirecting client request
Cause: An error occurred redirecting a client request.
MWM-00233 error, missing URL/URI information from Web server
Cause: The Web Agent cannot get the URL or URI information that it needs from the Web server.
Action: Verify that your Web server is configured correctly.
MWM-00234 error reading client request POST data
Cause: An error occurred reading client request POST data.
Action: Review the associated error message to determine the reason for the error. This error is most likely caused by a client session terminating before the server has processed the request. If this is the case, no action is necessary.
MWM-00236 error sending content, Web server sent number of number of bytes
Cause: An error occurred sending content to the client.
MWM-00237 error processing client authentication failure
Cause: An error occurred while processing the client authentication failure.
MWM-00252 unknown error number occurred reading POST data
Cause: An unknown error occurred reading POST data sent by the client.
Action: Review any related error messages written to the Web server's error log to determine the reason for the failure. This error is most likely caused by a client session terminating before the server has processed the request. If this is the case, no action is necessary.
MWM-00253 the request virtual path string does not map to a Web agent
Cause: A request was received for a virtual path that does not map to a Web agent's virtual path.
Action: For Netscape Enterprise and FastTrack Servers, verify that the virtual path named in the "from" parameter of the Oracle8i interMedia NameTrans directive corresponds to an Oracle8i interMedia virtual path in the configuration file.
For Apache Web Server, verify that the virtual path named in the Location directive corresponds to an Oracle8i interMedia virtual path in the configuration file.
For Oracle Application Server, verify that the virtual path used to register Oracle8i interMedia Web Agent using Oracle Application Server corresponds to an Oracle8i interMedia virtual path in the configuration file.
MWM-00402 unknown error number occurred reading POST data
Action: Review any related error messages written to the Netscape server's error log to determine the reason for the failure. This error is most likely caused by a client session terminating before the server has processed the request. If this is the case, no action is necessary.
MWM-00405 cannot find required pblock name/value pair string is missing
Cause: An error occurred finding a required pblock name/value pair.
MWM-00406 request aborted by server
Cause: An error occurred sending a response header or sending content.
Action: This error is most likely caused by a client session terminating before the server has processed the request. If this is the case, no action is necessary.
MWM-00407 network session terminated
Cause: The client session terminated before the server processed the request.
MWM-00408 unknown error status number
Cause: An unknown error occurred sending a response header or sending content.
MWM-00431 the request virtual path string does not map to a Web agent
Cause: A request was received for a virtual path that does not map to a Web agent virtual path.
Action: Verify that virtual paths used to register the Web Agents using Oracle Application Server match those specified in the configuration file.
MWM-00460 received notification for unregistered event number
Cause: Microsoft Internet Information Server (IIS) delivered a notification for an unregistered event.
Action: Verify that IIS is functioning correctly.
MWM-00461 extension URL is missing from the configuration file
Cause: The extension URL is not defined in the configuration file.
Action: Verify that the Web Agent is set up correctly. The configuration file should have an entry in the General section called iis_extension_url with the appropriate value for your environment.
MWM-00500 error loading or unloading the list of database agents
Cause: An error occurred trying to load or unload the list of database agents.
MWM-00501 error loading or unloading database agent string
Cause: An error occurred trying to load or unload the named database agent.
MWM-00503 database agent string does not exist
Cause: The specified database agent does not exist.
Action: Verify that the database agent name is spelled correctly.
MWM-00504 database agent string was not configured correctly
Cause: The specified database agent was not configured correctly.
Action: Review the initialization errors in the log file to determine the reason for the error, correct the problem, then reload the configuration.
MWM-00505 database agent name was not specified in database section name string
Cause: The database agent name is missing from the database agent section name.
Action: Specify a database agent name when configuring a database agent.
MWM-00521 OCI returned OCI_SUCCESS_WITH_INFO; string-number: message not available
Cause: An OCI operation completed with additional information. However, no message text was available for the indicated status code.
Action: Review the error code and any associated error messages to determine the reason for the condition.
MWM-00522 OCI returned OCI_SUCCESS_WITH_INFO; error number getting additional information
Cause: An OCI operation completed with additional information. However, an error occurred trying to retrieve the message associated with the condition.
Action: Review any associated error messages to determine the reason for the condition.
MWM-00523 OCI returned OCI_SUCCESS_WITH_INFO; no additional information available
Cause: An OCI operation completed with additional information. However, no additional status information is available for the operation.
MWM-00524 OCI returned OCI_ERROR; string-number: message not available
Cause: An OCI operation failed, but no error message was available for the indicated error code.
Action: Review the error code and any associated error messages to determine the reason for the failure.
MWM-00525 OCI returned OCI_ERROR; error number getting error message
Cause: An OCI operation failed, but an error occurred trying to retrieve the error message text associated with the error code.
Action: Review any associated error messages to determine the reason for the failure.
MWM-00526 OCI returned OCI_ERROR; no error information available
Cause: An OCI operation failed, but no additional error information is available for the failing operation.
MWM-00527 OCI returned OCI_NEED_DATA
Cause: An OCI operation required more data to complete.
MWM-00528 OCI returned OCI_NO_DATA
Cause: The OCI operation completed but returned no data.
MWM-00529 OCI returned OCI_INVALID_HANDLE
Cause: This is an internal error message not usually issued. However, this error may be reported if the PL/SQL procedure or SQL statement for a mediaget or mediaput request returned an invalid BLOB, CLOB, or BFILE handle.
Action: If this error occurs during the execution of a mediaget or mediaput request, verify that the PL/SQL procedure or SQL statement returned a valid BLOB, CLOB, or BFILE handle. If this error occurs for any other reason, contact customer support.
MWM-00540 error allocating an OCI handle of type number
Cause: An error occurred allocating an OCI handle of the indicated type.
MWM-00541 error freeing an OCI handle of type number
Cause: An error occurred freeing an OCI handle of the indicated type.
MWM-00542 error allocating an OCI descriptor of type number
Cause: An error occurred allocating an OCI descriptor of the indicated type.
MWM-00543 error freeing an OCI descriptor of type number
Cause: An error occurred freeing an OCI descriptor of the indicated type.
MWM-00544 error setting attribute number in an OCI handle of type number
Cause: An error occurred setting the indicated attribute in an OCI handle of the indicated type.
MWM-00545 error getting attribute number from an OCI handle of type number
Cause: An error occurred getting the indicated attribute from an OCI handle of the indicated type.
MWM-00546 OCI error attaching to database server using service name string
Cause: An error occurred attaching to the database using the indicated service name.
MWM-00547 OCI error detaching from database server using service name string
Cause: An error occurred detaching from the database using the indicated service name.
MWM-00548 OCI error beginning database session using service name string
Cause: An error occurred beginning a session to the database using the indicated service name.
MWM-00549 OCI error ending database session using service name string
Cause: An error occurred ending a database session using the indicated service name.
MWM-00550 OCI error committing a database transaction
Cause: An error occurred committing a database transaction.
MWM-00551 OCI error rolling back a database transaction
Cause: An error occurred rolling back a database transaction.
MWM-00552 error opening or closing a FILE locator
Cause: An error occurred opening or closing a FILE locator.
MWM-00553 error getting LOB data length
Cause: An error occurred getting the length of a LOB.
MWM-00554 error reading or writing LOB data
Cause: An error occurred reading or writing LOB data.
MWM-00555 error checking for temporary LOB
Cause: An error occurred checking for a temporary LOB.
MWM-00556 error freeing temporary LOB
Cause: An error occurred freeing a temporary LOB.
MWM-00600 error attaching to database using agent string
Cause: An error occurred attaching to a database server using the specified agent.
MWM-00601 user name and password required to use database agent
Cause: A user name and password were not supplied. To execute requests using the specified database agent, they must be supplied.
Action: The client must supply a valid user name and password to use the specified database agent.
MWM-00602 user name and password must not be specified to use agent
Cause: A user name and password were supplied. To execute requests using the specified database agent, they must not be supplied.
Action: All requests using the specified agent are executed using a fixed user name and password.
MWM-00603 number placeholders used to execute statement
Cause: An error occurred executing a statement. The indicated number of placeholders were used to execute the statement.
Action: Review the placeholders to determine the reason for the problem.
MWM-00604 OCI reported error number for placeholder string
Cause: OCI reported the specified error for the indicated placeholder while executing the statement.
Action: Use the error code to determine the reason for the problem.
MWM-00605 name: string, OCI type: number, len: number, ind: number, sts: number, value string
Cause: This message describes information about a specific bind parameter.
Action: Use this information to determine the cause of errors.
MWM-00606 name: string, OCI type: number, len: number, ind: number, sts: number, handle string
MWM-00607 error allocating or preparing a SQL statement
Cause: An error occurred allocating or preparing a SQL statement.
MWM-00608 error executing a SQL statement
Cause: An error occurred executing a SQL statement.
MWM-00609 error converting an Oracle date to text
Cause: An error occurred converting an Oracle date to text.
MWM-00610 error fetching a row from a result set
Cause: An error occurred fetching a row from a result set.
MWM-00611 zero-length placeholder name in SQL statement
Cause: A zero-length placeholder name was encountered in a SQL statement.
Action: Placeholder names must be at least one character long.
MWM-00613 error describing placeholder or column in result set
Cause: An error occurred describing the attributes of a placeholder or column in a result set.
MWM-00614 error defining column number
Cause: An error occurred defining a column.
MWM-00615 error binding a parameter or placeholder string
Cause: An error occurred binding a parameter or placeholder.
MWM-00616 invalid or unsupported PL/SQL argument IN/OUT direction
Cause: The IN/OUT direction of the indicated PL/SQL argument is not supported.
Action: Modify the PL/SQL procedure argument to specify IN, OUT, or IN/OUT, according to the usage of the argument.
MWM-00622 error describing PL/SQL procedure string
Cause: An error occurred describing a PL/SQL procedure and its arguments.
MWM-00623 unknown or unexpected error accessing database
Cause: An unknown or unexpected error occurred accessing a database.
MWM-00624 the specified PL/SQL procedure string was not found
Cause: The specified PL/SQL procedure was not found.
Action: Verify that the procedure name was specified correctly in the request URL and that it is accessible by the user name under which the request is executing.
MWM-00626 IN OUT parameter mode not supported for specified argument
Cause: Oracle8i interMedia Web Agent does not support the IN OUT parameter mode for the data type associated with the specified argument.
Action: Modify the PL/SQL procedure to specify the parameter mode as either IN or OUT as appropriate to the argument's usage.
MWM-00629 error defining column string
MWM-00630 name: string, OCI type: number, len: number, ind: number, sts: number, value number
Cause: This message describes information about a specific bind.
MWM-00631 the specified package or procedure is invalid
Cause: The object to be described is not valid. It has either compilation or authorization errors.
Action: Correct any compilation or authorization errors, then recompile the package or procedure.
MWM-00632 error describing procedure argument or column in result set string
Cause: An error occurred describing the attributes of a procedure argument or a column in a result set.
Action: Review the associated error messages to determine the reason for the error.
MWM-00700 error initializing the interMedia Web agent
Cause: An error occurred initializing Oracle8i interMedia Web Agent.
MWM-00701 error initializing interMedia database agent string
Cause: An error occurred initializing a database agent for Oracle8i interMedia Web Agent.
MWM-00702 invalid request class string
Cause: An invalid request class was specified for the indicated database agent.
Action: Specify a valid request class for the specified database agent.
MWM-00703 invalid authorized_SQL_statements class string
Cause: An invalid authorized_SQL_statements class was specified for the indicated database agent.
Action: Specify a valid authorized_SQL_statements class for the specified database agent.
MWM-00704 authorized_SQL_statements class for clipboard agent not ANY
Cause: A database agent with the request class clipboard did not specify the keyword ANY for the authorized_SQL_statements class.
Action: Specify the keyword ANY for the authorized_SQL_statements class for the clipboard database agent.
MWM-00705 all PL/SQL procedures not authorized for authorized_SQL_statements class ANY
Cause: When an Oracle8i interMedia database agent specifies the keyword ANY for the authorized_SQL_statements class, all PL/SQL procedures must be authorized, but they were not.
Action: Delete the authorized_SQL_procedures parameter or specify an asterisk (*) as the authorized_SQL_procedures parameter.
MWM-00706 invalid PL/SQL procedures name string in list: string
Cause: The PL/SQL procedure name was invalid. PL/SQL procedure names must consist of only alphanumeric characters and the underscore character, and must not be blank.
Action: Specify only valid PL/SQL procedures names in the list of authorized PL/SQL procedures.
MWM-00707 missing retrieve or upload agent string
Cause: A clipboard database agent specified a retrieve or upload database agent that does not exist in the configuration file.
Action: Specify a valid retrieve or upload database agent name.
MWM-00708 clipboard user name string does not match the database agent user name string
Cause: A clipboard user name was specified for a database agent that uses a fixed user name and password, but the clipboard user name does not match the database agent user name.
Action: Delete the clipboard user name parameter.
MWM-00709 reserved character character found in database agent name string
Cause: The specified database agent name includes reserved characters.
Action: Remove reserved characters from the name.
MWM-00710 reserved character character found in display name string
Cause: The specified display name includes reserved characters.
MWM-00720 invalid URL format in interMedia Web agent request
Cause: A client submitted a request with an invalid URL format.
Action: Modify the request to specify a valid URL format. For example, a mediaget request must specify at least the database agent name and the mediaget request name in the virtual path. See the documentation for full details on Oracle8i interMedia Web Agent URL formats.
MWM-00721 request did not specify a SQL statement or PL/SQL procedure name
Cause: A client submitted a request that did not specify a SQL statement or the name of a PL/SQL procedure.
Action: Modify the request to specify a valid SQL statement or the name of a PL/SQL procedure. See the documentation for full details on how SQL statements and PL/SQL procedure names are specified using Oracle8i interMedia Web Agent requests.
MWM-00725 a SQL SELECT statement returned an empty result set
Cause: A request failed because a SQL SELECT statement returned an empty result set.
Action: Verify that the requested data exists in the database.
MWM-00726 invalid use of reserved bind or define name string
Cause: An invalid reserved bind or define name was specified for the current request.
Action: Modify the request to specify a SQL statement that uses only those reserved bind and define names that are valid for the request.
MWM-00727 request returned NULL HTTP status
Cause: A request returned a NULL HTTP.
Action: Modify the request to return a valid HTTP status.
MWM-00728 invalid combination of HTTP status number, HTTP redirect URL string and HTML redirect URL string
Cause: A request returned an invalid combination of HTTP status, an HTTP redirect URL, and/or an HTML redirect URL.
Action: Modify the request to return either an HTTP redirect URL or an HTML redirect URL, and, optionally, an appropriate HTTP status.
MWM-00730 error creating database session to process request
Cause: An error occurred creating a database session to process a request.
MWM-00731 authentication failed for user name string for database agent string
Cause: An invalid user name and password were supplied for access to the specified database agent.
Action: Supply a valid user name and password.
MWM-00732 authentication failed for user name string for AGENTLIST request
Cause: An invalid user name and password were supplied for an AGENTLIST request.
MWM-00733 MEDIAGET request did not return a content MIME type
Cause: A mediaget request did not return a content MIME type.
Action: Verify that the PL/SQL procedure or the SQL statement specified as part of the mediaget request correctly returns a content MIME type using the correct reserved placeholder or result-set column name. See the documentation for full details on the reserved placeholder and result-set column names used by Oracle8i interMedia Web Agent. Verify that the information selected from the database has a valid, non-NULL content MIME type.
MWM-00734 MEDIAGET request returned NULL or zero-length content
Cause: A mediaget request returned NULL or zero-length content. It must return either a non-NULL LOB handle where the length of the LOB data is not zero or it must return some non-NULL VARCHAR2 character data.
Action: Verify that the PL/SQL procedure or the SQL statement specified as part of the mediaget request correctly returns content using one of the reserved placeholder or result-set column names. See the documentation for full details on the reserved placeholder and result-set column names used by Oracle8i interMedia Web Agent. Verify that the information selected from the database has valid, non-NULL content data.
MWM-00735 MEDIAGET request returned more than one content item
Cause: A mediaget request returned more than one content item.
Action: Verify that the PL/SQL procedure or the SQL statement specified as part of the mediaget request correctly returns exactly one non-NULL content item using one of the reserved placeholder or result-set column names. See the documentation for full details on the reserved placeholder and result-set column names used by Oracle8i interMedia Web Agent. Verify that the information selected from the database has exactly one valid, non-NULL content item.
MWM-00736 MEDIAGET request returned invalid content length string
Cause: A mediaget request returned an invalid content length.
Action: For optimal performance, a mediaget PL/SQL procedure or SQL statement may return the content length. Doing so avoids an additional round-trip between Oracle8i interMedia Web Agent and the database server. If provided, content length must be expressed as a valid number with a value greater than zero.
MWM-00738 Your MEDIAPUT request was processed successfully
Cause: Your mediaput request completed successfully.
MWM-00739 An error occurred processing your MEDIAGET or MEDIAPUT request
Cause: An error occurred processing your mediaget or mediaput request.
MWM-00740 MEDIAPUT request did not return a non-NULL content handle
Cause: A mediaput request did not return a non-NULL content handle, which is required to store the uploaded contents.
Action: Verify that the PL/SQL procedure or the SQL statement specified as part of the mediaput request correctly returns a LOB handle using one of the reserved placeholder or result-set column names. See the documentation for full details on the reserved placeholder and result-set column names used by Oracle8i interMedia Web Agent.
MWM-00741 MEDIAPUT request returned more than one non-NULL content handle
Cause: A mediaput request returned more than one non-NULL content handle.
Action: Verify that the PL/SQL procedure or the SQL statement specified as part of the mediaput request correctly returns exactly one non-NULL content LOB handle using one of the reserved placeholder or result-set column names. See the documentation for full details on the reserved placeholder and result-set column names used by Oracle8i interMedia Web Agent.
MWM-00742 no upload content provided for MEDIAPUT request in string
Cause: No upload content was provided for a mediaput request in the specified request variable.
Action: The mediaput request requires that content to be written to the database be presented using the specified request variable. The content must be at least one character or one byte in length and must be sent as POST data with an encryption type of multipart/form-data.
MWM-00743 request did not include the name of a database agent
Cause: The request did not include the name of a database agent.
Action: Modify the URL to include the name of a database agent.
MWM-00744 invalid interMedia Web agent request name string
Cause: An invalid Oracle8i interMedia Web Agent request name was specified in a request URL or for an Oracle8i interMedia Web Agent named virtual path.
Action: Modify the URL or named virtual path to specify a valid request name, such as mediaget. See the documentation for full details of the request types supported by Oracle8i interMedia Web Agent.
MWM-00745 invalid interMedia Web agent named virtual path string
Cause: An error was encountered in the specified named virtual path definition for Oracle8i interMedia Web Agent.
Action: Review the associated error message to determine the reason for the error, then correct the named virtual path definition of Oracle8i interMedia Web Agent in the configuration file.
MWM-00746 named virtual path requires PL/SQL procedure name or SQL statement
Cause: The named virtual path for a database agent was not specified correctly. A named virtual path requires either a PL/SQL procedure or a SQL statement, but not both.
Action: Modify the configuration file to specify either a PL/SQL procedure or a SQL statement.
MWM-00747 string requests may not be submitted using a named virtual path
Cause: The specified request used a named virtual path.
Action: Remove the named virtual path section from the configuration file.
MWM-00748 requests to database agent string must use a named virtual path
Cause: A request to the specified agent was not submitted using a named virtual path.
Action: If you want to allow access to the specified database agent without having to use a named virtual path, modify the configuration file. Specify either the keyword PROCEDURES or the keyword ANY as the authorized_SQL_statements parameter for the database agent. If you do not want to allow such access, review the associated request information to determine the identity of the client attempting to make unauthorized use of the specified database agent.
MWM-00749 database agent string is not authorized to execute PL/SQL procedure string
Cause: The specified database agent is not authorized to execute the named PL/SQL procedure.
Action: If you want to allow access to the specified database agent using the named PL/SQL procedure, add the procedure name to the list of authorized procedures for the database agent in the configuration file. If you do not want to allow such access, review the associated request information to determine the identity of the client attempting to make unauthorized use of the specified database agent.
MWM-00750 database agent string is not authorized to execute client-supplied SQL statements
Cause: The specified database agent is not authorized to execute client-supplied SQL statements.
Action: If you want to allow clients to execute client-supplied SQL statements using the specified database agent, modify the configuration file. Specify ANY as the authorized_SQL_statements parameter for the database agent. If you do not want to allow such access, review the associated request information to determine the identity of the client attempting to make unauthorized use of the specified database agent.
MWM-00751 database agent string is not authorized to process MEDIAPUT requests
Cause: The specified database agent is not authorized to process mediaput requests.
Action: If you want the database agent to process mediaput requests, modify the database agent in the configuration file to specify the keyword UPLOAD as the authorized_request_class parameter. If you do not, review the associated request information to determine the identity of the client attempting to make unauthorized use of the specified database agent.
MWM-00752 database agent string is not authorized to process clipboard requests
Cause: The specified database agent is not authorized to execute clipboard requests.
Action: Review the associated request information to determine the identity of the client attempting to make unauthorized use of the specified database agent.
MWM-00754 the parameter mode for the specified reserved argument is not IN
Cause: The parameter mode for the specified reserved argument is not IN.
Action: Modify the PL/SQL procedure to specify the argument's parameter mode as IN.
MWM-00755 the parameter mode for the specified reserved argument is not OUT
Cause: The parameter mode for the specified reserved argument is not OUT.
Action: Modify the PL/SQL procedure to specify the argument's parameter mode as OUT.
MWM-00756 the parameter mode for the request-specific argument is not IN
Cause: An argument that specifies the name of a query string or POST data request variable, or that specifies the name of an HTTP request argument, must use the IN parameter mode. However, the specified argument does not use the IN parameter mode.
MWM-00757 The database agent connection test completed successfully
Cause: The database agent connection test completed successfully.
MWM-00758 The database agent connection test failed
Cause: The database agent connection test failed.
MWM-00759 user name string does not match required user name string for agent string
Cause: The user name supplied did not match the user name required for access to the specified database agent.
Action: Supply the required user name.
MWM-00760 request returned invalid HTTP status number
Cause: A request returned an invalid HTTP status.
MWM-00800 authentication failed for user name string for administration request
Cause: An invalid user name and password were supplied for an administration request.
MWM-00801 invalid call to Online Administration
Cause: An invalid call was made for an administration request.
Action: Do not call administration functions directly. Always use the Online Administration tool.
