Personal Express Installation and Configuration Guide
Release 6.3.1
A82801-01
Library
Contents
Index
Prev Up Next
Configuring for Relational Database Access, 2 of 8
Choosing a Connection Method
Connection options
Personal Express supports two types of connections to relational databases:
Availability of options
The connection you can use depends on the type of relational database you wish to access.
IF you are accessing . . .  THEN you can use . . .
an Oracle database such as Oracle7 or Oracle8,
OCI or ODBC.
a non-Oracle database,
ODBC only.
For connections to Oracle relational databases, OCI offers substantial benefits over ODBC, because you have access to the special features of Oracle without the restrictions imposed by an ODBC driver. In addition, a direct connection is always faster and more reliable.
Limitations of ODBC
Because the ODBC convention supports only standard SQL, ODBC drivers do not support the nonstandard, special features that might be available in a particular RDBMS. In addition, Express imposes further restrictions with an ODBC connection because of the differences among the various RDBMS. For example, Express does not support multiple-statement transaction processing through an ODBC connection; all changes are committed immediately.
Prev Up Next
Oracle
Copyright © 2000 Oracle Corporation.
All Rights Reserved.
Library
Contents
Index
