Oracle Transparent Gateway Rdb on Alpha OpenVms Administrator's Guide
Release 8.1.7
Part Number A82918-01
Library
Product
Contents
Index
List of Tables
3-1 Installation Worksheet
3-2 Installation Guide
3-3 Installation Prompts and Responses
5-1 Data Type Conversions
7-1 Oracle Support Services Worksheet
B-1 Gateway Supported Views and Tables
B-2 Oracle Data Dictionary View Names and Rdb Equivalents
B-3 ALL_CATALOG
B-4 ALL_COL_COMMENTS
B-5 ALL_CONS_COLUMNS
B-6 ALL_CONSTRAINTS
B-7 ALL_IND_COLUMNS
B-8 ALL_INDEXES
B-9 ALL_OBJECTS
B-10 ALL_TAB_COLUMNS
B-11 ALL_TAB_COMMENTS
B-12 ALL_TABLES
B-13 ALL_TRIGGERS
B-14 ALL_VIEWS
B-15 DBA_CATALOG
B-16 DBA_COL_COMMENTS
B-17 DBA_OBJECTS
B-18 DBA_TAB_COLUMNS
B-19 DBA_TAB_COMMENTS
B-20 DBA_TABLES
B-21 DICT_COLUMNS
B-22 DICTIONARY
B-23 DUAL
B-24 USER_CATALOG
B-25 USER_COL_COMMENTS
B-26 USER_CONS_COLUMNS
B-27 USER_CONSTRAINTS
B-28 USER_INDEXES
B-29 USER_IND_COLUMNS
B-30 USER_OBJECTS
B-31 USER_TAB_COLUMNS
B-32 USER_TAB_COMMENTS
B-33 USER_TABLES
B-34 USER_TRIGGERS
B-35 USER_VIEWS
Copyright © 2001 Oracle Corporation.
All Rights Reserved.
Library
Product
Contents
Index
